| 以下是网上看到的例程: 没能理解,求解。
 int
 main(void)
 volatile unsigned long ulLoop;
 // Enable the GPIO port that is used for the on-board LED.
 SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOG;
 // Do a dummy read to insert a few cycles after enabling the peripheral.
 ulLoop = SYSCTL_RCGC2_R;
 // Enable the GPIO pin for the LED (PG2).  Set the direction as output, and
 // enable the GPIO pin for digital function.
 GPIO_PORTG_DIR_R = 0x04;
 GPIO_PORTG_DEN_R = 0x04;
 // Loop forever.
 while(1)
 // Turn on the LED.
 GPIO_PORTG_DATA_R |= 0x04;
 // Delay for a bit.
 for(ulLoop = 0; ulLoop < 20; ulLoop++)
 // Turn off the LED.
 GPIO_PORTG_DATA_R &= ~(0x04);
 // Delay for a bit.
