前面在使用CH579M-R1开发板时,便利用它对U盘的读写能力实现了图片显示功能,当时是利用按键触发翻页处理,这次则是在CH32V103开发板上再次重现了该功能,且将手动翻页改为延时自动翻页。 彩色OLED屏、米客方德4Gb T卡与CH32V103开发板的连接关系如图1所示。 图1 整体构成
   在图片中的浏览过程中,其演示效果如图2~图4所示。 图2 卡通画效果
图3 油画效果
图4 国画效果
   在程序中,进行相关语句定义有: #define LCD_W 160 #define LCD_H 80   #define OLED_SCLK_Set()  GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_SET) //CLK #define OLED_SCLK_Clr()  GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_RESET)   #define OLED_SDIN_Set()  GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_SET) //DIN #define OLED_SDIN_Clr()  GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_RESET)   #define OLED_RST_Set()   GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_SET) //RES #define OLED_RST_Clr()   GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_RESET)   #define OLED_DC_Set()    GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_SET) //DC #define OLED_DC_Clr()    GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_RESET)   #define OLED_CS_Set()    GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_SET) //CS #define OLED_CS_Clr()    GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_RESET)   #define OLED_BLK_Set()   GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_SET)//BLK #define OLED_BLK_Clr()   GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_RESET)   相应的引脚功能配置函数为: void App_OledInit(void) {    GPIO_InitTypeDef GPIO_InitStructure;                                         //定义一个GPIO_InitTypeDef类型的结构体    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);                     //使能与LED相关的GPIO端口时钟    GPIO_InitStructure.GPIO_Pin =GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6; //配置GPIO引脚    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                           //设置GPIO模式为推挽输出    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                          //设置GPIO口输出速度    GPIO_Init(GPIOB,&GPIO_InitStructure);                                       //调用库函数,初始化GPIOA    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);                     //使能与LED相关的GPIO端口时钟    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;                      //配置GPIO引脚    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                           //设置GPIO模式为推挽输出    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                          //设置GPIO口输出速度    GPIO_Init(GPIOA,&GPIO_InitStructure);                                       //调用库函数,初始化GPIOA   GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);                                  //设置引脚输出高电平 }   实现数码相框的主程序为: int main() {     UINT8 s, c, i,B,w=0;     UINT16 TotalCount,z;    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);     Delay_Init();     USART_Printf_Init(115200);     printf("SystemClk:%d\r\n",SystemCoreClock);     printf("USBHD HOSTTest\r\n");     USBHD_ClockCmd(RCC_USBCLKSource_PLLCLK_1Div5,ENABLE);     pHOST_RX_RAM_Addr = RxBuffer;     pHOST_TX_RAM_Addr = TxBuffer;     USB_HostInit();     CHRV3LibInit();     printf( "Wait DeviceIn\r\n" );     App_OledInit();     Lcd_Init();     LCD_Clear(BLACK);     LCD_Address_Set(0,0,159,79);     while ( 1 )     {             s = ERR_SUCCESS;             if ( R8_USB_INT_FG& RB_UIF_DETECT )             {                 R8_USB_INT_FG =RB_UIF_DETECT ;                 s =AnalyzeRootHub( );                 if ( s ==ERR_USB_CONNECT )   FoundNewDev = 1;             }               if ( FoundNewDev || s== ERR_USB_CONNECT )             {                 FoundNewDev =0;                 mDelaymS( 200);                 s =InitRootDevice( Com_Buffer );                 if ( s == ERR_SUCCESS)                 {                     CHRV3DiskStatus= DISK_USB_ADDR;                     for ( i = 0; i != 10;i ++ )                     {                         printf( "Wait DiskReady\n" );                         s =CHRV3DiskReady( );                         if ( s == ERR_SUCCESS)                         {                             break;                         }                        mDelaymS( 50 );                     }                       B=1;                     z=0;                     if ( CHRV3DiskStatus>= DISK_MOUNTED )                     {                       LOOP:                       z=0;                      LCD_Address_Set(0,0,159,79);                       if(B==1)                       {                       if(w==0) strcpy( (PCHAR)mCmdParam.Open.mPathName, "/C51/MOLED2.BIN" );                       if(w==1) strcpy( (PCHAR)mCmdParam.Open.mPathName, "/C51/MOLED1.BIN" );                       if(w==2) strcpy( (PCHAR)mCmdParam.Open.mPathName, "/C51/MOLED.BIN" );                         。。。                         s =CHRV3FileOpen( );                       if ( s ==ERR_MISS_DIR || s == ERR_MISS_FILE )                       {                           printf( "no find\n" );                       }                       else                       {                           while(z<256)                           {                          TotalCount = 100;                           printf( "read char :\n",TotalCount );                           while ( TotalCount )                           {                                if ( TotalCount >(MAX_PATH_LEN-1) )  c = MAX_PATH_LEN-1;                                else c = TotalCount;                               mCmdParam.ByteRead.mByteCount = c;                               mCmdParam.ByteRead.mByteBuffer= &buf[0];                               s = CHRV3ByteRead( );                                 TotalCount -= mCmdParam.ByteRead.mByteCount;                                for ( i=0;i!=mCmdParam.ByteRead.mByteCount; i++ )                               {                                      LCD_WR_DATA8(buf);                               }                                if ( mCmdParam.ByteRead.mByteCount < c )                               {                                    printf( "\n" );                                    printf( "file end\n" );                                    break;                               }                           }                           printf( "%3d", z );                           z++;                           }                             printf( "Close\n" );                           i =CHRV3FileClose( );                          mStopIfError( i );                           mDelaymS(2000);                            w++;                           if(w==N) w=0;                        }                       }                      mDelaymS(1000);                       goto LOOP;                     }                 }             }             mDelaymS( 100 );             SetUsbSpeed( 1 );         } }   经程序的编译处理,其占用存储空间的情况如下图所示。  |
