// MSP430F21x2 Demo - ADC10, DTC Sample A2-0, AVcc, Single Sequence, DCO
// Description: Sample A2/A1/A0 as single sequence with reference to AVcc.
// Software sets ADC10SC to trigger sample sequence. In Mainloop MSP430 waits
// in LPM0 to save power until ADC10 conversion complete, ADC10_ISR(DTC) will
// force exit from any LPMx in Mainloop on reti. ADC10_ISR will force LPM0
// exit. ADC10 internal oscillator times sample period (16x) and conversion
// (13x). DTC transfers conversion code to RAM 200h - 206h. P1.0 set at start
// of conversion burst, reset on completion.
// MSP430F21x2
// /|\| XIN|-
// --|RST XOUT|-
// >---|P2.2/A2 P1.0|-->LED
// >---|P2.1/A1 |
// >---|P2.0/A0 |
// A. Dannenberg
// Texas Instruments Inc.
// December 2007
// Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include "msp430x21x2.h"
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
ADC10CTL1 = INCH_2 + CONSEQ_1; // A2/A1/A0, single sequence
ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
ADC10DTC1 = 0x03; // 3 conversions
ADC10AE0 |= 0x07; // P2.2,1,0 ADC10 option select
P1DIR |= 0x01; // Set P1.0 output
for (;;)
ADC10CTL0 &= ~ENC;
while (ADC10CTL1 & BUSY); // Wait if ADC10 core is active
ADC10SA = 0x200; // Data buffer start
P1OUT |= 0x01; // P1.0 = 1
ADC10CTL0 |= ENC + ADC10SC; // Sampling and conversion start
__bis_SR_register(CPUOFF + GIE); // LPM0, ADC10_ISR will force exit
P1OUT &= ~0x01; // P1.0 = 0
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
__bic_SR_register_on_exit(CPUOFF); // Clear CPUOFF bit from 0(SR)
