[单片机芯片] 请教CH552模拟CH340的参考程序是如何发送和接收的。
3095|7
 楼主| qqtfh 发表于 2021-4-21 21:36 | 显示全部楼层 |阅读模式
#include "./Public/CH554.H"
#include "./Public/Debug.H"
#include <stdio.h>
#include <string.h>
#define THIS_ENDP0_SIZE         DEFAULT_ENDP0_SIZE
UINT8X        Ep0Buffer[THIS_ENDP0_SIZE] _at_ 0x0000;                                //端点0 OUT&IN缓冲区,必须是偶地址
UINT8X        Ep2Buffer[2*MAX_PACKET_SIZE] _at_ 0x0008;                              //端点2 IN&OUT缓冲区,必须是偶地址
UINT8X  Ep1Buffer[MAX_PACKET_SIZE] _at_ 0x00a0;
UINT8   SetupReq,SetupLen,Ready,Count,FLAG,UsbConfig;
PUINT8  pDescr;        //USB配置标志
USB_SETUP_REQ   SetupReqBuf;                                                       //暂存Setup包
UINT8   num = 0;
#define UsbSetupBuf     ((PUSB_SETUP_REQ)Ep0Buffer)
sbit Ep2InKey = P1^5;                                                              //K1按键
#pragma  NOAREGS
/*设备描述符*/
UINT8C DevDesc[18]={0x12,0x01,0x10,0x01,0xff,0x00,0x02,0x08,                   //设备描述符
                    0x86,0x1a,0x23,0x55,0x04,0x03,0x00,0x00,
                    0x00,0x01};
UINT8C CfgDesc[39]={0x09,0x02,0x27,0x00,0x01,0x01,0x00,0x80,0xf0,              //配置描述符,接口描述符,端点描述符
                          0x09,0x04,0x00,0x00,0x03,0xff,0x01,0x02,0x00,
                    0x07,0x05,0x82,0x02,0x20,0x00,0x00,                        //批量上传端点
                                0x07,0x05,0x02,0x02,0x20,0x00,0x00,                        //批量下传端点
                                      0x07,0x05,0x81,0x03,0x08,0x00,0x01};                       //中断上传端点
UINT8C DataBuf[26]={0x30,0x00,0xc3,0x00,0xff,0xec,0x9f,0xec,0xff,0xec,0xdf,0xec,
                    0xdf,0xec,0xdf,0xec,0x9f,0xec,0x9f,0xec,0x9f,0xec,0x9f,0xec,
                    0xff,0xec};
/*字符串描述符 略*/
// unsigned char  code LangDes[]={0x04,0x03,0x09,0x04};           //语言描述符
// unsigned char  code SerDes[]={
//                           0x28,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//                           0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//                           0x00,0x00,0x00,0x00,0x00,0x49,0x00,0x43,0x00,0x42,
//                           0x00,0x43,0x00,0x31,0x00,0x00,0x00,0x00,0x00,0x00
//                           };                                   //字符串描述符
UINT8X UserEp2Buf[64];                                            //用户数据定义
* Function Name  : Enp2BlukIn()
* Description    : USB设备模式端点2的批量上传
* Input          : None
* Output         : None
* Return         : None
void Enp2BlukIn( )
    memcpy( Ep2Buffer+MAX_PACKET_SIZE, UserEp2Buf, sizeof(UserEp2Buf));        //加载上传数据
    UEP2_T_LEN = THIS_ENDP0_SIZE;                                              //上传最大包长度
    UEP2_CTRL = UEP2_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_ACK;                  //有数据时上传数据并应答ACK
    while(UEP2_CTRL&UEP_T_RES_ACK);                                            //等待传输完成
* Function Name  : DeviceInterrupt()
* Description    : CH559USB中断处理函数
void    DeviceInterrupt( void ) interrupt INT_NO_USB using 1                    //USB中断服务程序,使用寄存器组1
    UINT8 len,i;
    if(UIF_TRANSFER)                                                            //USB传输完成标志
        switch (USB_INT_ST & (MASK_UIS_TOKEN | MASK_UIS_ENDP))
        case UIS_TOKEN_IN | 2:                                                  //endpoint 2# 端点批量上传
             UEP2_T_LEN = 0;                                                    //预使用发送长度一定要清空
//            UEP1_CTRL ^= bUEP_T_TOG;                                          //如果不设置自动翻转则需要手动翻转
            UEP2_CTRL = UEP2_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_NAK;           //默认应答NAK
            break;
        case UIS_TOKEN_OUT | 2:                                                 //endpoint 2# 端点批量下传
            if ( U_TOG_OK )                                                     // 不同步的数据包将丢弃
                len = USB_RX_LEN;                                               //接收数据长度,数据从Ep2Buffer首地址开始存放
                for ( i = 0; i < len; i ++ )
                    Ep2Buffer[MAX_PACKET_SIZE+i] = Ep2Buffer[i];         // OUT数据取反到IN由计算机验证
                UEP2_T_LEN = len;
                UEP2_CTRL = UEP2_CTRL & ~ MASK_UEP_T_RES | UEP_T_RES_ACK;       // 允许上传
            break;
        case UIS_TOKEN_SETUP | 0:                                               //SETUP事务
            len = USB_RX_LEN;
            if(len == (sizeof(USB_SETUP_REQ)))
                SetupLen = UsbSetupBuf->wLengthL;
                if(UsbSetupBuf->wLengthH || SetupLen > 0x7F )
                    SetupLen = 0x7F;                                             // 限制总长度
                len = 0;                                                         // 默认为成功并且上传0长度
                SetupReq = UsbSetupBuf->bRequest;
                if ( ( UsbSetupBuf->bRequestType & USB_REQ_TYP_MASK ) != USB_REQ_TYP_STANDARD )/*HID类命令*/
                                        switch( SetupReq )
                                                case 0xC0:
                                                  pDescr = &DataBuf[num];
                                                  len = 2;
                                                  if(num<24)
                                                        num += 2;
                                                        else
        num = 24;
        break;
                                                case 0x40:
                                                        len = 9;   //保证状态阶段,这里只要比8大,且不等于0xff即可
                                                        break;
                                                default:
        len = 0xFF;        /*命令不支持*/
        break;
                                        if ( SetupLen > len )
                                                SetupLen = len;    //限制总长度
                                        len = SetupLen >= THIS_ENDP0_SIZE ? THIS_ENDP0_SIZE : SetupLen;//本次传输长度
                                        memcpy(Ep0Buffer,pDescr,len);                            //加载上传数据
                                        SetupLen -= len;
                                        pDescr += len;
                else                                                             //标准请求
                    switch(SetupReq)                                             //请求码
                    case USB_GET_DESCRIPTOR:
                        switch(UsbSetupBuf->wValueH)
                        case 1:                                                  //设备描述符
                            pDescr = DevDesc;                                    //把设备描述符送到要发送的缓冲区
                            len = sizeof(DevDesc);
                            break;
                        case 2:                                                  //配置描述符
                            pDescr = CfgDesc;                                    //把设备描述符送到要发送的缓冲区
                            len = sizeof(CfgDesc);
                            break;
                        default:
                            len = 0xff;                                          //不支持的命令或者出错
                            break;
                        SetupLen -= len;
                        pDescr += len;
                        break;
                    case USB_SET_ADDRESS:
                        SetupLen = UsbSetupBuf->wValueL;                         //暂存USB设备地址
                        break;
                    case USB_GET_CONFIGURATION:
                        Ep0Buffer[0] = UsbConfig;
                        if ( SetupLen >= 1 )
                            len = 1;
                        break;
                    case USB_SET_CONFIGURATION:
                        UsbConfig = UsbSetupBuf->wValueL;
                        break;
                    case 0x0A:
                        break;
                    case USB_CLEAR_FEATURE:                                      //Clear Feature
                        if ( ( UsbSetupBuf->bRequestType & USB_REQ_RECIP_MASK ) == USB_REQ_RECIP_ENDP )// 端点
                            switch( UsbSetupBuf->wIndexL )
                            case 0x82:
                                UEP2_CTRL = UEP2_CTRL & ~ ( bUEP_T_TOG | MASK_UEP_T_RES ) | UEP_T_RES_NAK;
                                break;
                            case 0x81:
                                UEP1_CTRL = UEP1_CTRL & ~ ( bUEP_T_TOG | MASK_UEP_T_RES ) | UEP_T_RES_NAK;
                                break;
                            case 0x02:
                                UEP2_CTRL = UEP2_CTRL & ~ ( bUEP_R_TOG | MASK_UEP_R_RES ) | UEP_R_RES_ACK;
                                break;
                            default:
                                len = 0xFF;                                       // 不支持的端点
                                break;
                        else
                            len = 0xFF;                                           // 不是端点不支持
                        break;
                    case USB_SET_FEATURE:                                         /* Set Feature */
                        if( ( UsbSetupBuf->bRequestType & 0x1F ) == 0x00 )        /* 设置设备 */
                            if( ( ( ( UINT16 )UsbSetupBuf->wValueH << 8 ) | UsbSetupBuf->wValueL ) == 0x01 )
                                if( CfgDesc[ 7 ] & 0x20 )
                                    /* 设置唤醒使能标志 */
                                else
                                    len = 0xFF;                                    /* 操作失败 */
                            else
                        else if( ( UsbSetupBuf->bRequestType & 0x1F ) == 0x02 )    /* 设置端点 */
                            if( ( ( ( UINT16 )UsbSetupBuf->wValueH << 8 ) | UsbSetupBuf->wValueL ) == 0x00 )
                                switch( ( ( UINT16 )UsbSetupBuf->wIndexH << 8 ) | UsbSetupBuf->wIndexL )
                                case 0x82:
                                    UEP2_CTRL = UEP2_CTRL & (~bUEP_T_TOG) | UEP_T_RES_STALL;/* 设置端点2 IN STALL */
                                    break;
                                case 0x02:
                                    UEP2_CTRL = UEP2_CTRL & (~bUEP_R_TOG) | UEP_R_RES_STALL;/* 设置端点2 OUT Stall */
                                    break;
                                case 0x81:
                                    UEP1_CTRL = UEP1_CTRL & (~bUEP_T_TOG) | UEP_T_RES_STALL;/* 设置端点1 IN STALL */
                                    break;
                                default:
                                    break;
                            else
                        else
                        break;
                    case USB_GET_STATUS:
                        Ep0Buffer[0] = 0x00;
                        Ep0Buffer[1] = 0x00;
                        if ( SetupLen >= 2 )
                            len = 2;
                        else
                            len = SetupLen;
                        break;
                    default:
                        len = 0xff;                                                  //操作失败
                        break;
            else
                len = 0xff;                                                          //包长度错误
            if(len == 0xff)
                SetupReq = 0xFF;
                UEP0_CTRL = bUEP_R_TOG | bUEP_T_TOG | UEP_R_RES_STALL | UEP_T_RES_STALL;//STALL
            else if(len <= THIS_ENDP0_SIZE)                                         //上传数据或者状态阶段返回0长度包
                UEP0_T_LEN = len;
                UEP0_CTRL = bUEP_R_TOG | bUEP_T_TOG | UEP_R_RES_ACK | UEP_T_RES_ACK;//默认数据包是DATA1,返回应答ACK
            else
                UEP0_T_LEN = 0;  //虽然尚未到状态阶段,但是提前预置上传0长度数据包以防主机提前进入状态阶段
            break;
        case UIS_TOKEN_IN | 0:                                                      //endpoint0 IN
            switch(SetupReq)
                len = SetupLen >= THIS_ENDP0_SIZE ? THIS_ENDP0_SIZE : SetupLen;     //本次传输长度
                memcpy( Ep0Buffer, pDescr, len );                                   //加载上传数据
                SetupLen -= len;
                pDescr += len;
                UEP0_T_LEN = len;
                UEP0_CTRL ^= bUEP_T_TOG;                                            //同步标志位翻转
                break;
                USB_DEV_AD = USB_DEV_AD & bUDA_GP_BIT | SetupLen;
                UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_NAK;
                break;
            default:
                UEP0_T_LEN = 0;                                                      //状态阶段完成中断或者是强制上传0长度数据包结束控制传输
                break;
            break;
        case UIS_TOKEN_OUT | 0:  // endpoint0 OUT
            len = USB_RX_LEN;
            if(SetupReq == 0x09)
                if(Ep0Buffer[0])
                    printf("Light on Num Lock LED!\n");
                else if(Ep0Buffer[0] == 0)
                    printf("Light off Num Lock LED!\n");
            UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_ACK;//默认数据包是DATA0,返回应答ACK
            break;
        default:
            break;
        UIF_TRANSFER = 0;                                                           //写0清空中断
    if(UIF_BUS_RST)        //设备模式USB总线复位中断
        UEP1_CTRL = bUEP_AUTO_TOG | UEP_R_RES_ACK;
        UEP2_CTRL = bUEP_AUTO_TOG | UEP_R_RES_ACK | UEP_T_RES_NAK;
        USB_DEV_AD = 0x00;
        UIF_SUSPEND = 0;
        UIF_TRANSFER = 0;
        UIF_BUS_RST = 0;                                                             //清中断标志
    if (UIF_SUSPEND)        //USB总线挂起/唤醒完成
        UIF_SUSPEND = 0;
        if ( USB_MIS_ST & bUMS_SUSPEND )                                             //挂起
#ifdef DE_PRINTF
            printf( "zz" );                                                          //睡眠状态
#endif
            while ( XBUS_AUX & bUART0_TX )
                ;    //等待发送完成
            SAFE_MOD = 0x55;
            SAFE_MOD = 0xAA;
            WAKE_CTRL = bWAK_BY_USB | bWAK_RXD0_LO;                                   //USB或者RXD0有信号时可被唤醒
            PCON |= PD;                                                               //睡眠
            SAFE_MOD = 0x55;
            SAFE_MOD = 0xAA;
            WAKE_CTRL = 0x00;
    else {        //意外的中断,不可能发生的情况
        USB_INT_FG = 0xFF;                                                             //清中断标志
//      printf("UnknownInt  N");
* Function Name  : USBDeviceCfg()
* Description    : USB设备模式配置
* Input          : None
* Output         : None
* Return         : None
void USBDeviceCfg()
    USB_CTRL = 0x00;                                                           //清空USB控制寄存器
    USB_CTRL &= ~bUC_HOST_MODE;                                                //该位为选择设备模式
    USB_CTRL |=  bUC_DEV_PU_EN | bUC_INT_BUSY | bUC_DMA_EN;                    //USB设备和内部上拉使能,在中断期间中断标志未清除前自动返回NAK
    USB_DEV_AD = 0x00;                                                         //设备地址初始化
//     USB_CTRL |= bUC_LOW_SPEED;
//     UDEV_CTRL |= bUD_LOW_SPEED;                                                //选择低速1.5M模式
    USB_CTRL &= ~bUC_LOW_SPEED;
    UDEV_CTRL &= ~bUD_LOW_SPEED;                                             //选择全速12M模式,默认方式
          UDEV_CTRL = bUD_PD_DIS;  // 禁止DP/DM下拉电阻
    UDEV_CTRL |= bUD_PORT_EN;                                                  //使能物理端口
* Function Name  : USBDeviceEndPointCfg()
* Description    : USB设备模式端点配置,模拟兼容HID设备,除了端点0的控制传输,还包括端点2批量上下传
* Input          : None
* Output         : None
* Return         : None
void USBDeviceEndPointCfg()
        UEP1_DMA = Ep1Buffer;                                                      //端点1 发送数据传输地址
    UEP2_DMA = Ep2Buffer;                                                      //端点2 IN数据传输地址
    UEP2_3_MOD = 0xCC;                                                         //端点2/3 单缓冲收发使能
    UEP2_CTRL = bUEP_AUTO_TOG | UEP_T_RES_NAK | UEP_R_RES_ACK;                 //端点2自动翻转同步标志位,IN事务返回NAK,OUT返回ACK
    UEP1_CTRL = bUEP_AUTO_TOG | UEP_T_RES_NAK;                                 //端点1自动翻转同步标志位,IN事务返回NAK
        UEP0_DMA = Ep0Buffer;                                                      //端点0数据传输地址
    UEP4_1_MOD = 0X40;                                                         //端点1上传缓冲区;端点0单64字节收发缓冲区
    UEP0_CTRL = UEP_R_RES_ACK | UEP_T_RES_NAK;                                 //手动翻转,OUT事务返回ACK,IN事务返回NAK
* Function Name  : USBDeviceIntCfg()
* Description    : USB设备模式中断初始化
* Input          : None
* Output         : None
* Return         : None
void USBDeviceIntCfg()
    USB_INT_EN |= bUIE_SUSPEND;                                               //使能设备挂起中断
    USB_INT_EN |= bUIE_TRANSFER;                                              //使能USB传输完成中断
    USB_INT_EN |= bUIE_BUS_RST;                                               //使能设备模式USB总线复位中断
    USB_INT_FG |= 0x1F;                                                       //清中断标志
    IE_USB = 1;                                                               //使能USB中断
    EA = 1;        //允许单片机中断
main()
    UINT8 i;
    CfgFsys( );                                                           //CH559时钟选择配置
    mDelaymS(5);                                                          //修改主频等待内部晶振稳定,必加
    mInitSTDIO( );                                                        //串口0初始化
#ifdef DE_PRINTF
    printf("start ...\n");
#endif
    USBDeviceCfg();
    USBDeviceEndPointCfg();                                               //端点配置
    USBDeviceIntCfg();                                                    //中断初始化
        UEP0_T_LEN = 0;
    UEP1_T_LEN = 0;                                                       //预使用发送长度一定要清空
    while(1)
上面是官网下载的,CH559模拟CH340 USB转串口的参考程序。我改成CH552是可以识别出CH341A,但是没看懂发送和接收应该如何调用。main()中也没有调用发送和接收。另外,如果想要发送64byte以上数据,应该如何操作。求指点。对沁恒的USB了解不够,刚接触。以前有用过STM32F103C8T6的USB,但是是用库实现的,对USB的详细过程理解得不透。
WCHTech2 发表于 2021-4-22 09:33 | 显示全部楼层
您好,发送和接收见中断函数
,一包数据超过32字节的话需要拆包发送
 楼主| qqtfh 发表于 2021-4-22 15:05 | 显示全部楼层
您好,发送和接收见中断函数
,一包数据超过32字节的话需要拆包发送
谢谢您,每次问问题都能得到准确的回复。感觉真好。
 楼主| qqtfh 发表于 2021-4-25 23:10 | 显示全部楼层
您好,发送和接收见中断函数
,一包数据超过32字节的话需要拆包发送
可否结合这个例子,写个简单的发送接收的代码吗?
WCHTech2 发表于 2021-4-26 09:37 | 显示全部楼层
这个就是接收和发送的例子,看代码:
例程中就是将接收到的数据取反上传回去。Ep2Buffer前64字节是上传的数据缓存区,后64字节是接收数据缓存区。
上传数据是只需将数据准备好,置ACK即可。
 楼主| qqtfh 发表于 2021-4-26 11:22 | 显示全部楼层
这个就是接收和发送的例子,看代码:
例程中就是将接收到的数据取反上传回去。Ep2Buffer前64字节是上传 ...
               /* len = sendLen;                                               //接收数据长度,数据从Ep2Buffer首地址开始存放
                    Ep2Buffer[MAX_PACKET_SIZE+i] = Ep2Buffer;         // OUT数据取反到IN由计算机验证
                UEP2_T_LEN = sendLen;
改成这样
然后调用是
USB_INT_ST|=2;
memcpy( Ep2Buffer, SendBuf+i*32, sendLen);
while(!U_TOG_OK)_delay_ms(1);
然而没有反应。
拨打技术支持的电话吧:025-52632854  发表于 2021-4-26 13:08
慢动作 发表于 2021-4-30 21:51 | 显示全部楼层
这算简单的发送接收的代码吗?
