| 大神帮我看看这个串口CRC校验程序怎么理解,CRC算法跟网上的一样的crc16吧 //the following is MCU code for CRC16 ,please refer.
 #define RxCountMax 18
 unsigned short RxBuf[RxCountMax];
 unsigned short TxBuf[10];
 unsigned short RxCnt;
 unsigned short TxCnt;
 unsigned short Rx50msCnt;
 unsigned long pAddr1,pAddr2,pAddr3,pAddr4;
 //Receive interrupt routine
 void voRxIsr(void)
 unsigned short i,CRC_RX,CRC_Tmp;
 RxBuf[RxCnt] = Rx.data;                                //acquire data
 RxCnt++;
 if(RxCnt == RxCountMax) {
 CRC_Tmp =  CRC_CHECK(RxBuf,16);          //CRC Calculation
 CRC_RX = ((unsigned short)RxBuf[RxCountMax-1]<<8) + RxBuf[RxCountMax-2];
 if(CRC_Tmp == CRC_RX){
 pAddr1 = ((ULONG)(RxBuf[0x3])<<24)|((ULONG)(RxBuf[0x2])<<16)|((ULONG)(RxBuf[0x1])<<8)|RxBuf[0x0];
 pAddr2 = ((ULONG)(RxBuf[0x7])<<24)|((ULONG)(RxBuf[0x6])<<16)|((ULONG)(RxBuf[0x5])<<8)|RxBuf[0x4];
 pAddr3 = ((ULONG)(RxBuf[0xB])<<24)|((ULONG)(RxBuf[0xA])<<16)|((ULONG)(RxBuf[0x9])<<8)|RxBuf[0x8];
 pAddr4 = ((ULONG)(RxBuf[0xF])<<24)|((ULONG)(RxBuf[0xE])<<16)|((ULONG)(RxBuf[0xD])<<8)|RxBuf[0xC];
 RxCnt = 0;
 Rx50msCnt = 0;
 //to add--Clear Receive Data Register Fll flag;
 //Transfer interrupt routine
 void voTxIsr(void)
 if(TxCnt <= 9){
 Tx.Register = TxBuf[TxCnt];
 //Clear Tx interrupt flag
 TxCnt++;
 if(TxCnt >= 10){
 //send interrupt disable
 //Monitor routine Execute every T Period time
 void voMonitor(void)
 unsigned short ChxData[4],CRC_Tmp,i;
 Rx50msCnt++;
 if(Rx50msCnt >=500) {
 RxCnt = 0;
 Rx50msCnt = 0;
 ChxData[0].sw = *(unsigned short *)pAddr1;
 ChxData[1].sw = *(unsigned short *)pAddr2;
 ChxData[2].sw = *(unsigned short *)pAddr3;
 ChxData[3].sw = *(unsigned short *)pAddr4;
 for(i=0;i<4;i++){
 TxBuf[2*i+0] = ChxData[i].sb.low;         // ch[i] low byte
 TxBuf[2*i+1] = ChxData[i].sb.hi;          // ch[i] hi byte
 CRC_Tmp = CRC_CHECK(TxBuf,8);
 TxBuf[8] = CRC_Tmp&0xff;
 TxBuf[9] = CRC_Tmp>>8;
 //send first data
 Tx.Register = TxBuf[0];                         //send begin
 //Enalbe TXD interrupt
 TxCnt = 1;
