[技术问答] N76E616 Watch_Dog例程WDT没复位????
2596|4
 楼主| 因火生烟 发表于 2021-5-23 10:44 | 显示全部楼层 |阅读模式
void main (void)
    /* Note
       MCU power on system clock is HIRC (11.0592MHz), so Fsys = 11.0592MHz
    Set_All_GPIO_Quasi_Mode();                   //in Common.c
    #if DEBUG_PORT == 0
        InitialUART0_Timer1_Type1(115200);            /* 9600 Baud Rate*/
    #elif DEBUG_PORT == 1
        InitialUART1_Timer3(115200);                  /* 9600 Baud Rate*/
    #endif
    Show_FW_Version_Number_To_PC();
    printf ("\n*===================================================================");
    printf ("\n*  Name: N76E616 Watch Dog Timer Demo Code.");
    printf ("\n*===================================================================\n");
    /* Change system closk source */
    #if SYS_CLK_EN == 1
        #if   SYS_SEL == 0
            System_Clock_Select(E_HXTEN);   //Fosc = 2~16MHz XTAL
        #elif SYS_SEL == 1
            System_Clock_Select(E_LXTEN);   //Fosc = 32.768KHz XTAL
        #elif SYS_SEL == 2
            System_Clock_Select(E_HIRCEN);  //Fosc = 11.0592MHz Internal RC
        #elif SYS_SEL == 3
            System_Clock_Select(E_LIRCEN);  //Fosc = 10KHz Internal RC
        #elif SYS_SEL == 4
            System_Clock_Select(E_OSCEN);   //Fosc = OSC-In External OSC
        #endif
    #endif
    #if SYS_DIV_EN == 1
        CKDIV = SYS_DIV;                        //Fsys = Fosc / (2* CLKDIV) = Fcpu
    #endif
        TA = 0x0AA;
        TA = 0x055;
    #if   PRE_SCALAR == 0
        WDCON = 0x00;
    #elif PRE_SCALAR == 1
        WDCON = 0x01;
    #elif PRE_SCALAR == 2
        WDCON = 0x02;
    #elif PRE_SCALAR == 3
        WDCON = 0x03;
    #elif PRE_SCALAR == 4
        WDCON = 0x04;
    #elif PRE_SCALAR == 5
        WDCON = 0x05;
    #elif PRE_SCALAR == 6
        WDCON = 0x06;
    #elif PRE_SCALAR == 7
        WDCON = 0x07;
    #endif
    set_WDTEN;                                  //WDT run
    while(1);
jasontu 发表于 2021-5-24 10:41 | 显示全部楼层
config的wdt要打開。
杨寅辉 发表于 2021-5-24 11:14 | 显示全部楼层
是的,下载配置的时候,看门狗也是需要打开的。你程序中明细没有打开的。
datouyuan 发表于 2021-6-25 11:19 | 显示全部楼层
config的wdt要打开后会一直复位。
无法通过clr_WDTEN指令关闭wdt。
另外喂狗指令是啥?
Candic12e 发表于 2021-6-25 11:48 | 显示全部楼层
喂狗指令就是复位一下看门狗吧
