stm32cubemx中freertosV10.0.1与cmsis_v2配合是否有问题
2302|0
 楼主| xsq21dz 发表于 2021-6-3 12:02 | 显示全部楼层 |阅读模式
在cmsis_os2.c中有:#if defined(SysTick)
/* FreeRTOS tick timer interrupt handler prototype */
extern void xPortSysTickHandler (void);
  SysTick handler implementation that also clears overflow flag.
void SysTick_Handler (void) {
  /* Clear overflow flag */
  SysTick->CTRL;
  /* Call tick handler */
  xPortSysTickHandler();
#endif /* SysTick */
在FreeRTOSConfig.h有#define xPortSysTickHandler SysTick_Handler
在port.c
void xPortSysTickHandler( void )
        /* The SysTick runs at the lowest interrupt priority, so when this interrupt
        executes all interrupts must be unmasked.  There is therefore no need to
        save and then restore the interrupt mask value as its value is already
        known. */
        portDISABLE_INTERRUPTS();
                /* Increment the RTOS tick. */
                if( xTaskIncrementTick() != pdFALSE )
                        /* A context switch is required.  Context switching is performed in
                        the PendSV interrupt.  Pend the PendSV interrupt. */
                        portNVIC_INT_CTRL_REG = portNVIC_PENDSVSET_BIT;
        portENABLE_INTERRUPTS();
