在VS2005下生成创建运行一个WinCE6.0平台
3314|0
 楼主| tedyu 发表于 2009-3-4 17:58 | 显示全部楼层 |阅读模式
在VS2005下生成创建运行一个WinCE6.0平台(二)Create&nbsp;an&nbsp;OS&nbsp;design2009-<br /><br />1.&nbsp;Select&nbsp;File&nbsp;|&nbsp;New&nbsp;|&nbsp;Project…&nbsp;from&nbsp;the&nbsp;Visual&nbsp;Studio&nbsp;menu.<br /><br />2.&nbsp;Select&nbsp;the&nbsp;Platform&nbsp;Builder&nbsp;for&nbsp;CE&nbsp;6.0&nbsp;project&nbsp;type&nbsp;in&nbsp;the&nbsp;New&nbsp;Project&nbsp;dialog.<br /><br />3.&nbsp;Select&nbsp;OS&nbsp;Design&nbsp;under&nbsp;Visual&nbsp;Studio&nbsp;installed&nbsp;templates.<br /><br />4.&nbsp;Type&nbsp;TrainingOSDesign&nbsp;in&nbsp;the&nbsp;Name&nbsp;field.&nbsp;The&nbsp;solution&nbsp;name&nbsp;will&nbsp;default&nbsp;to&nbsp;TrainingOSDesign&nbsp;as&nbsp;well.<br /><br />5.&nbsp;Click&nbsp;OK.&nbsp;Visual&nbsp;Studio&nbsp;will&nbsp;launch&nbsp;the&nbsp;Windows&nbsp;Embedded&nbsp;CE&nbsp;6.0&nbsp;OS&nbsp;Design&nbsp;Wizard.<br /><br />6.&nbsp;Click&nbsp;Next.<br /><br />7.&nbsp;In&nbsp;the&nbsp;list&nbsp;of&nbsp;available&nbsp;BSPs,&nbsp;select&nbsp;TrainingBSP:&nbsp;ARMV4I&nbsp;and&nbsp;click&nbsp;Next.<br /><br />8.&nbsp;From&nbsp;the&nbsp;list&nbsp;of&nbsp;available&nbsp;design&nbsp;templates,&nbsp;select&nbsp;PDA&nbsp;Device&nbsp;and&nbsp;click&nbsp;Next.<br /><br />9.&nbsp;From&nbsp;the&nbsp;list&nbsp;of&nbsp;available&nbsp;design&nbsp;variants,&nbsp;select&nbsp;Mobile&nbsp;Handheld&nbsp;and&nbsp;click&nbsp;Next.&nbsp;The&nbsp;Applications&nbsp;&&nbsp;Media&nbsp;configuration&nbsp;window&nbsp;will&nbsp;appear.<br /><br />10.&nbsp;Deselect&nbsp;.NET&nbsp;Compact&nbsp;Framework&nbsp;2.0&nbsp;and&nbsp;ActiveSync&nbsp;and&nbsp;click&nbsp;Next.&nbsp;The&nbsp;Networking&nbsp;&&nbsp;Communications&nbsp;configuration&nbsp;window&nbsp;will&nbsp;appear.<br /><br />11.&nbsp;Deselect&nbsp;TCP/IPv6&nbsp;Support.<br /><br />12.&nbsp;Expand&nbsp;the&nbsp;Personal&nbsp;Area&nbsp;Network&nbsp;(PAN)&nbsp;node,&nbsp;and&nbsp;deselect&nbsp;Bluetooth.<br /><br />13.&nbsp;Click&nbsp;Next,&nbsp;and&nbsp;then&nbsp;Finish&nbsp;to&nbsp;complete&nbsp;the&nbsp;Windows&nbsp;Embedded&nbsp;CE&nbsp;6.0&nbsp;Design&nbsp;Wizard.<br /><br />14.&nbsp;Click&nbsp;Acknowledge&nbsp;on&nbsp;the&nbsp;Catalog&nbsp;Item&nbsp;Notification&nbsp;dialog.<br /><br />15.&nbsp;Click&nbsp;on&nbsp;the&nbsp;Catalog&nbsp;Items&nbsp;View&nbsp;tab&nbsp;to&nbsp;display&nbsp;the&nbsp;Catalog.(视图==》其它窗口也可)<br /><br />16.&nbsp;Click&nbsp;on&nbsp;the&nbsp;Filter&nbsp;drop&nbsp;down&nbsp;box&nbsp;in&nbsp;the&nbsp;upper&nbsp;left&nbsp;hand&nbsp;corner.&nbsp;Observe&nbsp;the&nbsp;different&nbsp;filtering&nbsp;options.&nbsp;The&nbsp;filter&nbsp;controls&nbsp;the&nbsp;items&nbsp;that&nbsp;are&nbsp;displayed&nbsp;in&nbsp;the&nbsp;catalog.&nbsp;Ensure&nbsp;that&nbsp;All&nbsp;Catalog&nbsp;Items&nbsp;in&nbsp;Catalog&nbsp;is&nbsp;selected.<br /><br />17.&nbsp;Observe&nbsp;the&nbsp;selection&nbsp;boxes&nbsp;and&nbsp;icons&nbsp;in&nbsp;the&nbsp;catalog.&nbsp;Selection&nbsp;boxes&nbsp;with&nbsp;a&nbsp;green&nbsp;check&nbsp;mark&nbsp;indicate&nbsp;an&nbsp;item&nbsp;that&nbsp;was&nbsp;specifically&nbsp;selected&nbsp;as&nbsp;a&nbsp;part&nbsp;of&nbsp;the&nbsp;OS&nbsp;design.&nbsp;Selection&nbsp;boxes&nbsp;with&nbsp;a&nbsp;green&nbsp;square&nbsp;indicate&nbsp;an&nbsp;item&nbsp;that&nbsp;was&nbsp;brought&nbsp;in&nbsp;to&nbsp;the&nbsp;OS&nbsp;design&nbsp;as&nbsp;a&nbsp;dependency.&nbsp;Selection&nbsp;boxes&nbsp;that&nbsp;are&nbsp;not&nbsp;marked&nbsp;indicate&nbsp;items&nbsp;that&nbsp;are&nbsp;not&nbsp;included&nbsp;in&nbsp;the&nbsp;OS&nbsp;design&nbsp;but&nbsp;are&nbsp;available&nbsp;to&nbsp;be&nbsp;added.<br /><br />18.&nbsp;Locate&nbsp;a&nbsp;catalog&nbsp;item&nbsp;with&nbsp;a&nbsp;green&nbsp;square&nbsp;in&nbsp;its&nbsp;checkbox.<br /><br />19.&nbsp;Right&nbsp;click&nbsp;on&nbsp;the&nbsp;catalog&nbsp;item&nbsp;and&nbsp;choose&nbsp;Reasons&nbsp;for&nbsp;Inclusion&nbsp;of&nbsp;Item.&nbsp;The&nbsp;Remove&nbsp;Dependent&nbsp;Catalog&nbsp;Item&nbsp;dialog&nbsp;box&nbsp;displays&nbsp;the&nbsp;catalog&nbsp;items&nbsp;you<br /><br />20.&nbsp;Close&nbsp;the&nbsp;Remove&nbsp;Dependent&nbsp;Catalog&nbsp;Item&nbsp;dialog&nbsp;box.<br /><br />21.&nbsp;Expand&nbsp;the&nbsp;Core&nbsp;OS&nbsp;|&nbsp;CEBASE&nbsp;|&nbsp;Applications&nbsp;–&nbsp;End&nbsp;User&nbsp;|&nbsp;Active&nbsp;Sync&nbsp;node&nbsp;in&nbsp;the&nbsp;catalog.<br /><br />22.&nbsp;Right&nbsp;click&nbsp;on&nbsp;Active&nbsp;Sync&nbsp;system&nbsp;cpl(此项有两处,path1:$(_WINCEROOT)publicDataSyncoakctlpanelsystem;path2:$(_WINCEROOT)publicDataSyncoakctlpanel)&nbsp;and&nbsp;select&nbsp;Display&nbsp;In&nbsp;Solution&nbsp;View.&nbsp;The&nbsp;view&nbsp;will&nbsp;change&nbsp;to&nbsp;the&nbsp;Solution&nbsp;Explorer&nbsp;tab(解决方案资源浏览器).&nbsp;The&nbsp;subproject&nbsp;containing&nbsp;the&nbsp;Active&nbsp;Sync&nbsp;component&nbsp;is&nbsp;displayed.&nbsp;This&nbsp;is&nbsp;a&nbsp;great&nbsp;way&nbsp;to&nbsp;navigate&nbsp;the&nbsp;source&nbsp;code&nbsp;that&nbsp;is&nbsp;available&nbsp;as&nbsp;part&nbsp;of&nbsp;Windows&nbsp;Embedded&nbsp;CE&nbsp;6.0.<br /><br />23.&nbsp;Select&nbsp;the&nbsp;Catalog&nbsp;Items&nbsp;View&nbsp;tab&nbsp;to&nbsp;display&nbsp;the&nbsp;OS&nbsp;design&nbsp;catalog.<br /><br />24.&nbsp;Enter&nbsp;the&nbsp;text&nbsp;Internet&nbsp;Explorer&nbsp;6.0&nbsp;Sample&nbsp;into&nbsp;the&nbsp;search&nbsp;text&nbsp;box&nbsp;to&nbsp;the&nbsp;right&nbsp;of&nbsp;the&nbsp;filter&nbsp;button.&nbsp;Press&nbsp;Enter&nbsp;or&nbsp;click&nbsp;the&nbsp;green&nbsp;arrow.&nbsp;The&nbsp;path&nbsp;Core&nbsp;OS&nbsp;|&nbsp;CEBASE&nbsp;|&nbsp;Internet&nbsp;Client&nbsp;Services&nbsp;|&nbsp;Browser&nbsp;Application&nbsp;|&nbsp;Internet&nbsp;Explorer&nbsp;6.0&nbsp;for&nbsp;Windows&nbsp;Embedded&nbsp;CE&nbsp;–&nbsp;Standard&nbsp;Components&nbsp;should&nbsp;be&nbsp;expanded.<br /><br />25.&nbsp;Select&nbsp;the&nbsp;Internet&nbsp;Explorer&nbsp;6.0&nbsp;Sample&nbsp;Browser&nbsp;catalog&nbsp;item.<br /><br />26.&nbsp;Enter&nbsp;the&nbsp;text&nbsp;ipconfig&nbsp;into&nbsp;the&nbsp;Search&nbsp;box&nbsp;and&nbsp;press&nbsp;Enter.&nbsp;The&nbsp;Network&nbsp;Utilities&nbsp;(IpConfig,&nbsp;Ping,&nbsp;Route)&nbsp;will&nbsp;be&nbsp;highlighted.(此时提示一对话框,意思是要从根目录搜索,无碍)<br /><br /><br /><br /><br />27.&nbsp;Add&nbsp;the&nbsp;networking&nbsp;utilities&nbsp;to&nbsp;your&nbsp;design&nbsp;by&nbsp;selecting&nbsp;the&nbsp;component.<br /><br />28.&nbsp;Enter&nbsp;the&nbsp;text&nbsp;wceload&nbsp;into&nbsp;the&nbsp;Search&nbsp;box&nbsp;and&nbsp;press&nbsp;Enter.&nbsp;The&nbsp;Cab&nbsp;File&nbsp;Installer&nbsp;/Uninstaller&nbsp;component&nbsp;will&nbsp;be&nbsp;highlighted.<br /><br /><br />29.&nbsp;Add&nbsp;the&nbsp;Cab&nbsp;File&nbsp;Installer&nbsp;/Uninstaller&nbsp;utility&nbsp;to&nbsp;your&nbsp;OS&nbsp;design.<br /><br />30.&nbsp;Enter&nbsp;the&nbsp;text&nbsp;sysgen_dotnetv2_support&nbsp;into&nbsp;the&nbsp;Search&nbsp;box&nbsp;and&nbsp;press&nbsp;Enter.&nbsp;The&nbsp;OS&nbsp;Dependencies&nbsp;for&nbsp;.NET&nbsp;Compact&nbsp;Framework&nbsp;2.0&nbsp;component&nbsp;will&nbsp;be&nbsp;highlighted.<br /><br />31.&nbsp;Add&nbsp;the&nbsp;OS&nbsp;Dependencies&nbsp;for&nbsp;.NET&nbsp;Compact&nbsp;Framework&nbsp;2.0&nbsp;to&nbsp;your&nbsp;OS&nbsp;design.<br /><br />32.&nbsp;Select&nbsp;Build&nbsp;|&nbsp;Configuration&nbsp;Manager…&nbsp;from&nbsp;the&nbsp;Visual&nbsp;Studio&nbsp;menu&nbsp;to&nbsp;bring&nbsp;up&nbsp;the&nbsp;Configuration&nbsp;Manager&nbsp;dialog&nbsp;box.<br /><br />33.&nbsp;Select&nbsp;TrainingBSP&nbsp;ARMV4I&nbsp;Release&nbsp;from&nbsp;the&nbsp;Active&nbsp;solution&nbsp;configuration&nbsp;drop&nbsp;down&nbsp;box.&nbsp;Close&nbsp;the&nbsp;dialog&nbsp;box.<br /><br />34.&nbsp;Select&nbsp;the&nbsp;Solution&nbsp;Explorer&nbsp;view&nbsp;by&nbsp;selecting&nbsp;the&nbsp;Solution&nbsp;Explorer&nbsp;tab.<br /><br />35.&nbsp;In&nbsp;the&nbsp;Solution&nbsp;Explorer&nbsp;window,&nbsp;right&nbsp;click&nbsp;on&nbsp;the&nbsp;TrainingOSDesign&nbsp;project&nbsp;and&nbsp;choose&nbsp;Properties.&nbsp;This&nbsp;will&nbsp;launch&nbsp;the&nbsp;Property&nbsp;Pages&nbsp;dialog&nbsp;for&nbsp;your&nbsp;OS&nbsp;design.<br /><br />36.&nbsp;Expand&nbsp;the&nbsp;Configuration&nbsp;Properties&nbsp;tree&nbsp;and&nbsp;click&nbsp;on&nbsp;the&nbsp;Build&nbsp;Options&nbsp;node.(项目==》属性)<br /><br />37.&nbsp;Ensure&nbsp;the&nbsp;following&nbsp;build&nbsp;options&nbsp;are&nbsp;set:<br />·&nbsp;Enable&nbsp;eboot&nbsp;space&nbsp;in&nbsp;memory<br />·&nbsp;Enable&nbsp;kernel&nbsp;debugger<br />·&nbsp;Enable&nbsp;KITL<br />·&nbsp;Enable&nbsp;profiling<br /><br />38.&nbsp;Select&nbsp;OK<br /><br />39.&nbsp;Select&nbsp;Build&nbsp;|&nbsp;Build&nbsp;TrainingOSDesign&nbsp;from&nbsp;the&nbsp;Visual&nbsp;Studio&nbsp;menu.<br /><br />40.&nbsp;Select&nbsp;Target&nbsp;|&nbsp;Connectivity&nbsp;Options…&nbsp;from&nbsp;the&nbsp;Visual&nbsp;Studio&nbsp;menu.&nbsp;The&nbsp;Target&nbsp;Device&nbsp;Connectivity&nbsp;Options&nbsp;dialog&nbsp;will&nbsp;appear&nbsp;showing&nbsp;the&nbsp;Kernel&nbsp;Service&nbsp;Map&nbsp;configuration&nbsp;for&nbsp;the&nbsp;CE&nbsp;Device&nbsp;named&nbsp;connection.<br /><br />41.&nbsp;Select&nbsp;Device&nbsp;Emulator&nbsp;(DMA)&nbsp;from&nbsp;the&nbsp;Download&nbsp;drop&nbsp;down&nbsp;box.<br /><br />42.&nbsp;Select&nbsp;Device&nbsp;Emulator&nbsp;(DMA)&nbsp;from&nbsp;the&nbsp;Transport&nbsp;drop&nbsp;down&nbsp;box.<br /><br />43.&nbsp;Select&nbsp;KdStub&nbsp;from&nbsp;the&nbsp;Debugger&nbsp;drop&nbsp;down&nbsp;box.<br /><br />44.&nbsp;Next&nbsp;to&nbsp;the&nbsp;Download&nbsp;drop&nbsp;down&nbsp;menu&nbsp;click&nbsp;Settings.<br /><br />45.&nbsp;Select&nbsp;the&nbsp;Display&nbsp;tab&nbsp;in&nbsp;the&nbsp;Emulator&nbsp;Properties&nbsp;dialog&nbsp;box.<br /><br />46.&nbsp;Change&nbsp;the&nbsp;Screen&nbsp;width&nbsp;to&nbsp;640&nbsp;pixels&nbsp;and&nbsp;the&nbsp;Screen&nbsp;height&nbsp;to&nbsp;480&nbsp;pixels.<br /><br />47.&nbsp;Select&nbsp;the&nbsp;Network&nbsp;tab&nbsp;in&nbsp;the&nbsp;Emulator&nbsp;Properties&nbsp;dialog&nbsp;box.<br /><br />48.&nbsp;Check&nbsp;the&nbsp;box&nbsp;beside&nbsp;Enable&nbsp;NE2000…<br /><br />49.&nbsp;Click&nbsp;on&nbsp;OK<br /><br />50.&nbsp;Select&nbsp;Apply&nbsp;to&nbsp;save&nbsp;the&nbsp;new&nbsp;device&nbsp;configuration.<br /><br />51.&nbsp;Select&nbsp;Close&nbsp;to&nbsp;close&nbsp;the&nbsp;dialog&nbsp;box.<br /><br />52.&nbsp;Select&nbsp;Target&nbsp;|&nbsp;Attach&nbsp;Device&nbsp;from&nbsp;the&nbsp;Visual&nbsp;Studio&nbsp;menu.&nbsp;<br /><br />成功启动的图像,只是启动的有点慢,差点害的我以为又是黑屏呢<br /><br />&nbsp;<br />
