GD32F405RGT6 ADC+DMA传输,开启DMA传输完成中断程序卡死
4105|6
 楼主| MYBMYB 发表于 2021-7-2 08:52 | 显示全部楼层 |阅读模式
DMA不开中断读到的ADC值正常,开启DMA传输完成中断,程序不进DMA中断,程序死在某个地方了
#include "bsp_adc.h"
#include "USART0.h"
#include "iic.h"
volatile uint16_t adc_read_data[2]={0x0000};//DMAÊý¾Ý´æ·Å»º´æ  adc_read_data_length
volatile uint16_t adc_data_dispose[adc_channel_number][adc_read_data_length]={0x0000};//ADCÊý¾Ý´¦Àí»º´æ
void ADC_GPIO_Config(void)
        // ʹÄÜ GPIO ʱÖÓ
        rcu_periph_clock_enable(RCU_GPIOA);
        // ÅäÖÃ IO
        gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_0|GPIO_PIN_1);//PA0¡¢PA1 Ä£ÄâÊäÈë
void ADC_Mode_Config(void)
  // ¿ªÆôADCʱÖÓ
        rcu_periph_clock_enable(RCU_ADC1);
        adc_clock_config(ADC_ADCCK_PCLK2_DIV8);//ʱÖÓ8·ÖƵ
        adc_deinit();//¸´Î»ADCÅäÖÃ
        adc_channel_length_config(ADC1,ADC_REGULAR_CHANNEL,2);//ADCͨµÀÊýÁ¿ÅäÖÃ
        adc_regular_channel_config(ADC1,0, ADC_CHANNEL_0, ADC_SAMPLETIME_144);//ͨµÀÅäÖÃ
        adc_regular_channel_config(ADC1,1, ADC_CHANNEL_1, ADC_SAMPLETIME_144);//ͨµÀÅäÖÃ
        adc_external_trigger_config(ADC1,ADC_REGULAR_CHANNEL,ENABLE);//¹Ø±ÕÍⲿ´¥·¢
        adc_data_alignment_config(ADC1,ADC_DATAALIGN_RIGHT);//Êý¾ÝÓÒ¶ÔÆë
        adc_resolution_config(ADC1,ADC_RESOLUTION_12B);//12λ·Ö±æÂÊ
        adc_dma_mode_enable(ADC1);//ADC0µÄDMAʹÄÜ
        adc_dma_request_after_last_enable(ADC1);//
        adc_special_function_config(ADC1,ADC_SCAN_MODE, ENABLE);//¶àͨµÀ¿ªÆôɨÃèģʽ
        adc_special_function_config(ADC1,ADC_CONTINUOUS_MODE, ENABLE);//Ñ­»·Á¬Ðø²É¼¯
        adc_enable(ADC1);//ʹÄÜADC0
        delay_ms(10);
        adc_calibration_enable(ADC1);//ADC0У׼
        adc_software_trigger_enable(ADC1, ADC_REGULAR_CHANNEL);//Èí¼þÆô¶¯×ª»»
void DMA_init(void){
        dma_single_data_parameter_struct dma_init_struct;
  /*¿ªÆôDMAʱÖÓ*/
        rcu_periph_clock_enable(RCU_DMA1);//ʹÄÜDMA1ʱÖÓ
        //DMA ADC½ÓÊÕÅäÖÃ
        dma_deinit(DMA1, DMA_CH2);//¸´Î»DMA1ͨµÀ0
        dma_init_struct.periph_addr = (uint32_t)(&ADC_RDATA(ADC1));//ÍâÉèµØÖ·
        dma_init_struct.periph_inc = DMA_PERIPH_INCREASE_DISABLE;//ÍâÉèµØÖ·²»±ä
        dma_init_struct.memory0_addr = (uint32_t)adc_read_data;//ÄÚ´æµØÖ·
        dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;//ÄÚ´æµØÖ·ÔöÁ¿Ä£Ê½
        dma_init_struct.periph_memory_width = DMA_PERIPH_WIDTH_16BIT;//Êý¾Ý¿í¶È16λ
        dma_init_struct.circular_mode=DMA_CIRCULAR_MODE_DISABLE;//DMA_CIRCULAR_MODE_ENABLE;//Ñ­»·Ä£Ê½
        dma_init_struct.direction = DMA_PERIPH_TO_MEMORY;//ÍâÉèµ½ÄÚ´æ
        dma_init_struct.number = 2;//adc_read_data_length;//Êý¾Ý³¤¶È
        dma_init_struct.priority = DMA_PRIORITY_HIGH;//ÓÅÏȼ¶¸ß
        dma_single_data_mode_init(DMA1, DMA_CH2, dma_init_struct);//³õʼ»¯DMA1ͨµÀ0
        dma_channel_subperipheral_select(DMA1, DMA_CH2, DMA_SUBPERI1);//DMAͨµÀÍâÉèÑ¡Ôñ
        nvic_irq_enable(DMA1_Channel2_IRQn, 0, 1);//DMA1ͨµÀ0ÖжÏÓÅÏȼ¶ÅäÖÃ
        dma_interrupt_flag_clear(DMA1,DMA_CH2,DMA_CHXCTL_FTFIE);//Çå³ýDMA1ͨµÀ0´«ÊäÍê³ÉÖжϠ
        dma_interrupt_enable(DMA1,DMA_CH2,DMA_CHXCTL_FTFIE);//¿ªÆôDMA1ͨµÀ0´«ÊäÍê³ÉÖжÏ
        dma_channel_enable(DMA1, DMA_CH2);//ʹÄÜDMA1ͨµÀ0(¿ªÆô½ÓÊÕ)
//        nvic_irq_enable(DMA1_Channel0_IRQn, 1, 1);//DMA1ͨµÀ0ÖжÏÓÅÏȼ¶ÅäÖÃ
//        dma_interrupt_flag_clear(DMA1,DMA_CH0,DMA_CHXCTL_FTFIE);//Çå³ýDMA1ͨµÀ0´«ÊäÍê³ÉÖжÏ
//        dma_interrupt_enable(DMA1,DMA_CH0,DMA_CHXCTL_FTFIE);//¿ªÆôDMA1ͨµÀ0´«ÊäÍê³ÉÖжÏ
void ADC_Init(void)
        ADC_GPIO_Config();
        DMA_init();
        ADC_Mode_Config();
void DMA1_Channel2_IRQHandler(void)
                USART0SendByte(0x44);
    if((dma_interrupt_flag_get(DMA1,DMA_CH2,DMA_CHXCTL_FTFIE)==SET)&&(dma_flag_get(DMA1,DMA_CH2,DMA_CHXCTL_FTFIE)==SET))//´«ÊäÍê³ÉÖжÏ
//                        for(adc_i=0;adc_i<adc_read_data_length;adc_i++){//½«µÚÒ»¸öͨµÀ´ÓDMA»º´æ¸´ÖƵ½ADC´¦Àí»º´æ
//                                adc_data_dispose[0][adc_i]=adc_read_data[adc_i*2];
//                        for(adc_i=0;adc_i<adc_read_data_length;adc_i++){//½«µÚ¶þ¸öͨµÀ´ÓDMA»º´æ¸´ÖƵ½ADC´¦Àí»º´æ
//                                adc_data_dispose[1][adc_i]=adc_read_data[adc_i*2+1];
//                        USART0SendByte(0xFF);
//                        USART0SendByte((uint8_t)(adc_data_dispose[0][6]>>8));//²âÊÔ
//                        USART0SendByte((uint8_t)adc_data_dispose[0][6]);//²âÊÔ
//                        USART0SendByte(0x66);
//                        USART0SendByte((uint8_t)(adc_data_dispose[1][7]>>8));//²âÊÔ
//                        USART0SendByte((uint8_t)adc_data_dispose[1][7]);//²âÊÔ
        dma_interrupt_flag_clear(DMA1,DMA_CH2,DMA_CHXCTL_FTFIE);//Çå³ý´«ÊäÍê³ÉÖжÏ
 楼主| MYBMYB 发表于 2021-7-2 08:56 | 显示全部楼层
各位大佬帮忙给看一下有什么问题
sonicll 发表于 2021-7-2 09:19 | 显示全部楼层
你ADC使用的是DMA1_CH2,中断配置的却是DMA1_CH0?
 楼主| MYBMYB 发表于 2021-7-2 09:26 | 显示全部楼层
DMA1_CH0是注销掉的。
使用的是这一段
 楼主| MYBMYB 发表于 2021-7-2 09:32 | 显示全部楼层
这一段
这一段
这一段
sonicll 发表于 2021-7-2 09:41 | 显示全部楼层
你开了中断以后,能看到DMA传输过数据吗,还有你说的程序卡死,卡死在什么位置,能把卡死时内核寄存器值(就是有PC、SP、xPSR那一栏)截个图看看吗
 楼主| MYBMYB 发表于 2021-7-2 09:56 | 显示全部楼层
你开了中断以后,能看到DMA传输过数据吗,还有你说的程序卡死,卡死在什么位置,能把卡死时内核寄存器值(就 ...
DMA有传输数据,中断服务函数一次都没进,我是用串口下载调试程序,看不到在哪卡死了,也看不到内核寄存器值
