[AT32F407] AT32F407VGT7的CAN2是不是有问题啊?不发送也有波形
5616|11
 楼主| fuquan19801117 发表于 2021-7-9 08:25 | 显示全部楼层 |阅读模式
CAN2初始化后发送一次数据,用示波器测量始终有波行输出,频率有规则40K,驱动是按官方CAN1的改的,调试多次未解决,怀疑是否芯片问题。
 楼主| fuquan19801117 发表于 2021-7-9 08:33 | 显示全部楼层
示波器测量图片
 楼主| fuquan19801117 发表于 2021-7-9 08:34 | 显示全部楼层
        GPIO_InitType GPIO_InitStructure;
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_13;
        GPIO_InitStructure.GPIO_MaxSpeed = GPIO_MaxSpeed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pins = GPIO_Pins_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_PU;
        RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_CAN2, ENABLE);
引脚配置
 楼主| fuquan19801117 发表于 2021-7-9 08:35 | 显示全部楼层
        CAN_InitType  CAN_InitStructure;
        CAN_FilterInitType          CAN_FilterInitStructure = {0};
        CAN_InitStructure.CAN_TTC = DISABLE;
        CAN_InitStructure.CAN_ABO = ENABLE;
        CAN_InitStructure.CAN_AWU = ENABLE;
        CAN_InitStructure.CAN_NART = DISABLE;
        CAN_InitStructure.CAN_RFL = DISABLE;
        CAN_InitStructure.CAN_TFP = DISABLE;
        CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
        CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
        switch (bulv)
          case 1000:
                                CAN_InitStructure.CAN_BS1 = CAN_BS1_8tq;
                                CAN_InitStructure.CAN_BS2 = CAN_BS2_3tq;
                                CAN_InitStructure.CAN_Prescaler = 10;
                  break;
                case 800:
                                CAN_InitStructure.CAN_BS1 = CAN_BS1_10tq;
                                CAN_InitStructure.CAN_BS2 = CAN_BS2_2tq;
                  break;
          case 500:
                                CAN_InitStructure.CAN_BS1 = CAN_BS1_2tq;
                                CAN_InitStructure.CAN_BS2 = CAN_BS2_1tq;
                                CAN_InitStructure.CAN_Prescaler = 60;
                  break;
          case 250:
                                CAN_InitStructure.CAN_Prescaler = 40;
                  break;
                case 100:
                                CAN_InitStructure.CAN_BS1 = CAN_BS1_14tq;
                                CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
                  break;
                case 50:
                                CAN_InitStructure.CAN_Prescaler = 120;
                  break;
                case 20:
                                CAN_InitStructure.CAN_Prescaler = 300;
                  break;
          default:
                                CAN_InitStructure.CAN_Prescaler =10;
                  break;
        CAN_Init(CAN2, &CAN_InitStructure);       ///<SYSCLK=240M,  APB1CLK=120M, CAN Baudrate=(240/2)*1000K)/((1+9)*(3+7+2)) = 1000K
  CAN_FilterInitStructure.CAN_FilterNumber=0;
        CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
        CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
        CAN_FilterInitStructure.CAN_FilterIdHigh=0x0;
        CAN_FilterInitStructure.CAN_FilterIdLow=0x0;
        CAN_FilterInitStructure.CAN_FilterMskIdHigh=0x0;
        CAN_FilterInitStructure.CAN_FilterMskIdLow=0x0;
        CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
        CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
        CAN_FilterInit(CAN2, &CAN_FilterInitStructure);
  CAN_INTConfig(CAN2,CAN_INT_RFP0,ENABLE);
CAN配置
        NVIC_InitType  NVIC_InitStructure = {0};
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn ;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x10;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
CAN2中断配置
林堪堪 发表于 2021-7-9 09:30 | 显示全部楼层
CAN没输出但是pin有输出的话,首先排除一下这个pin上其他功能有没有开起来。你这边PB12/PB13的话可能是TMR1或SPI2。你可以看看数据手册的引脚定义这一节,看看有没有别的功能开启。
 楼主| fuquan19801117 发表于 2021-7-9 09:59 | 显示全部楼层
问题找到了,借鉴了STM32的,查到的
什么原因呢,是使用CAN2要开CAN1的时钟吗?  发表于 2022-8-28 20:28
zhengshuai888 发表于 2021-7-10 13:58 来自手机 | 显示全部楼层
是什么原因呢?
084425 发表于 2021-7-10 14:18 | 显示全部楼层
没接负载的话自动重传开着没ACK,就会一直重发
Henryko 发表于 2022-9-7 21:39 | 显示全部楼层
楼主,是因为什么原因啊?
Undshing 发表于 2022-10-5 21:04 | 显示全部楼层
楼主原因是啥啊?
