新唐这个io的宏定义,简直太爽了,
有没有同感
- #define GPIO_PIN_DATA(port, pin) (*((volatile uint32_t *)((GPIO_PIN_DATA_BASE+(0x40*(port))) + ((pin)<<2)))) /*!< Pin Data Input/Output \hideinitializer */
- #define PA0 GPIO_PIN_DATA(0, 0 ) /*!< Specify PA.0 Pin Data Input/Output \hideinitializer */
- #define PA1 GPIO_PIN_DATA(0, 1 ) /*!< Specify PA.1 Pin Data Input/Output \hideinitializer */
- #define PA2 GPIO_PIN_DATA(0, 2 ) /*!< Specify PA.2 Pin Data Input/Output \hideinitializer */
- #define PA3 GPIO_PIN_DATA(0, 3 ) /*!< Specify PA.3 Pin Data Input/Output \hideinitializer */
- #define PA4 GPIO_PIN_DATA(0, 4 ) /*!< Specify PA.4 Pin Data Input/Output \hideinitializer */
- #define PA5 GPIO_PIN_DATA(0, 5 ) /*!< Specify PA.5 Pin Data Input/Output \hideinitializer */
- #define PA6 GPIO_PIN_DATA(0, 6 ) /*!< Specify PA.6 Pin Data Input/Output \hideinitializer */
- #define PA7 GPIO_PIN_DATA(0, 7 ) /*!< Specify PA.7 Pin Data Input/Output \hideinitializer */
- #define PA8 GPIO_PIN_DATA(0, 8 ) /*!< Specify PA.8 Pin Data Input/Output \hideinitializer */
- #define PA9 GPIO_PIN_DATA(0, 9 ) /*!< Specify PA.9 Pin Data Input/Output \hideinitializer */
- #define PA10 GPIO_PIN_DATA(0, 10) /*!< Specify PA.10 Pin Data Input/Output \hideinitializer */
- #define PA11 GPIO_PIN_DATA(0, 11) /*!< Specify PA.11 Pin Data Input/Output \hideinitializer */
