|   函数传入的WS2812RGBvalue函数255,254,253这3个数据不见了,keilv4调试以及单片机发送的的3个0x00.
 下面这个图是发的是255,255,255,keilv4调试截图
   用这下面这段代码发送的数据没有异常
 void LightingControl()
 //switch (WS2812Control)
 //case 0:WS2812RGBvalue(0, Gv, 0, 4); break;
 //case 1:WS2812RGBvalue(17, Gv, 17, 4); break;
 //case 2:WS2812RGBvalue(Gv, 17, 17, 4); break;
 //case 3:WS2812RGBvalue(Gv, 0, Gv, 4); break;
 //case 4:WS2812RGBvalue(0, 0, Gv, 4); break;
 //case 5:WS2812RGBvalue(47, Gv, Gv, 4); break;
 //case 6:WS2812RGBvalue(Gv, Gv, 9, 4); break;
 //case 7:WS2812RGBvalue(Gv, Gv, Gv, 4); break;
 //case 8:WS2812RGBvalue(255, 255, 255, 4); break;
 //default:
 //        break;
 /**T0中断函数**/
 void InterruptTimer0() interrupt INT_NO_TMR0 using 1
 TH0 = T0RH;
 TL0 = T0RL;
 //eveFlag = 0;
 if (cFlag)
 Gv = Gv + 2;
 if (Gv >= 240)
 cFlag = 0;
 else
 Gv = Gv - 2;
 if (Gv <= 20)
 cFlag = 1;
 下图是STC8A调试以及实际发生数据的截图,没有问题
 下面是CH552T驱动WS2812的源程序
  CH552WS2812.zip
(144.74 KB, 下载次数: 6)
