使用官方测试实例,串口2可以i接收数据,发送数据端口检测不到。程序如下:
/******************* IO配置函数 *******************/
void GPIO_config(void)
GPIO_InitTypeDef GPIO_InitStructure; //结构定义
GPIO_InitStructure.Pin = GPIO_Pin_1;//GPIO_Pin_6 | GPIO_Pin_7; //指定要初始化的IO, GPIO_Pin_0 ~ GPIO_Pin_7
GPIO_InitStructure.Mode = GPIO_PullUp; //指定IO的输入或输出方式,GPIO_PullUp,GPIO_HighZ,GPIO_OUT_OD,GPIO_OUT_PP
GPIO_Inilize(GPIO_P1,&GPIO_InitStructure); //初始化
/*************** 串口初始化函数 *****************/
void UART_config(void)
COMx_InitDefine COMx_InitStructure; //结构定义
COMx_InitStructure.UART_Mode = UART_8bit_BRTx; //模式, UART_ShiftRight,UART_8bit_BRTx,UART_9bit,UART_9bit_BRTx
COMx_InitStructure.UART_BaudRate = 115200ul;//57600ul; //波特率, 110 ~ 115200
COMx_InitStructure.UART_RxEnable = ENABLE; //接收允许, ENABLE或DISABLE
COMx_InitStructure.UART_Interrupt = ENABLE; //中断允许, ENABLE或DISABLE
COMx_InitStructure.UART_Priority = Priority_0; //指定中断优先级(低到高) Priority_0,Priority_1,Priority_2,Priority_3
COMx_InitStructure.UART_P_SW = UART2_SW_P10_P11;//UART2_SW_P46_P47; //切换端口, UART2_SW_P10_P11,UART2_SW_P46_P47
UART_Configuration(UART2, &COMx_InitStructure); //初始化串口2 UART1,UART2,UART3,UART4
PrintString2("STC8 UART2 Test Programme!\r\n"); //UART2发送一个字符串
void main(void)
u8 i;
GPIO_config();
UART_config();
EA = 1;
while (1)
delay_ms(1);
if(COM2.RX_TimeOut > 0) //超时计数
if(--COM2.RX_TimeOut == 0)
if(COM2.RX_Cnt > 0)
for(i=0; i<COM2.RX_Cnt; i++) TX2_write2buff(RX2_Buffer[i]); //收到的数据原样返回
COM2.RX_Cnt = 0;
