学习:arm内核种类
2000|0
 楼主| gangwa258123456 发表于 2012-3-22 00:19 | 显示全部楼层 |阅读模式
家族架构内核特色高速缓存 (I/D)/MMU常规 MIPS 于 MHz应用
ARM1ARMv1ARM1
ARM2ARMv2ARM2Architecture 2 加入了MUL(乘法)指令4 MIPS @ 8MHzAcorn Archimedes,Chessmachine
ARMv2aARM250Integrated MEMC (MMU),图像与IO处理器。Architecture 2a 加入了SWP和SWPB(置换)指令。无,MEMC1a7 MIPS @ 12MHzAcorn Archimedes
ARM3ARMv2aARM2a首次在ARM架构上使用处理器高速缓存均为4K12 MIPS @ 25MHzAcorn Archimedes
ARM6ARMv3ARM610v3 架构首创支援寻址32位的内存(针对26位)均为4K28 MIPS @ 33MHzAcorn Risc PC 600,Apple Newton
ARM7ARMv3
ARM7TDMIARMv4TARM7TDMI(-S)三级流水线15 MIPS @ 16.8 MHzGame Boy Advance,Nintendo DS,iPod
ARM710T均为8KB, MMU36 MIPS @ 40 MHzAcorn Risc PC 700,Psion 5 series,Apple eMate 300
ARM720T均为8KB, MMU60 MIPS @ 59.8 MHzZipit
ARM740TMPU
ARMv5TEJARM7EJ-SJazelle DBX
StrongARMARMv4
ARM8ARMv4
ARM9TDMIARMv4TARM9TDMI五级流水线
ARM920T16KB/16KB, MMU200 MIPS @ 180 MHzArmadillo,GP32,GP2X(第一颗内核), Tapwave Zodiac(Motorola i. MX1)
ARM922T8KB/8KB, MMU
ARM940T4KB/4KB, MPUGP2X(第二颗内核)
ARM9EARMv5TEARM946E-S可变动,tightly coupled memories, MPUNintendo DS,Nokia N-Gage Conexant 802.11 chips
ARM966E-S无高速缓存,TCMsST Micro STR91xF,包含Ethernet
ARM968E-S无高速缓存,TCMs
ARMv5TEJARM926EJ-SJazelle DBX可变动,TCMs, MMU220 MIPS @ 200 MHz移动电话:Sony Ericsson(K, W系列),Siemens 和 Benq(x65 系列和新版的)
ARMv5TEARM996HS无振荡器处理器无高速缓存,TCMs, MPU
ARM10EARMv5TEARM1020E(VFP),六级流水线32KB/32KB, MMU
ARM1022E(VFP)16KB/16KB, MMU
ARMv5TEJARM1026EJ-SJazelle DBX可变动,MMU or MPU
XScaleARMv5TE80200/IOP310/IOP315I/O处理器
80219400/600MHzThecus N2100
IOP321600 BogoMips @ 600 MHzIyonix
IOP33x
IOP34x1-2核,RAID加速器32K/32K L1, 512K L2, MMU
PXA210/PXA250应用处理器,七级流水线Zaurus SL-5600
PXA25532KB/32KB, MMU400 BogoMips @ 400 MHzGumstix,Palm Tungsten E2
PXA26x可达 400 MHzPalm Tungsten T3
PXA27x800 MIPS @ 624 MHzHTC Universal, Zaurus SL-C1000,3000,3100,3200, Dell Axim x30, x50,和 x51 系列
PXA800(E)F
Monahans1000 MIPS @ 1.25 GHzMavell PXA300/PXA310/PXA320, Max frequency : PXA300@624Mhz, PXA310/PXA320@806Mhz
PXA900Blackberry 8700, Blackberry Pearl (8100)
IXC1100Control Plane Processor
IXP2400/IXP2800
IXP2850
IXP2325/IXP2350
IXP42xNSLU2
IXP460/IXP465
ARM11ARMv6ARM1136J(F)-SSIMD, Jazelle DBX, (VFP),八级流水线可变动,MMU?? @ 532-665MHz (i.MX31 SoC)Nokia N93,Zune,Nokia N800
ARMv6T2ARM1156T2(F)-SSIMD, Thumb-2, (VFP),九级流水线可变动,MPU
ARMv6KZARM1176JZ(F)-SSIMD, Jazelle DBX, (VFP)可变动,MMU+TrustZone
ARMv6KARM11 MPCore1-4核对称多处理器,SIMD, Jazelle DBX, (VFP)可变动,MMU
CortexARMv7-ACortex-A8Application profile, VFP, NEON, Jazelle RCT, Thumb-2, 13-stage pipeline可变动 (L1+L2), MMU+TrustZoneup to 2000(2.0 DMIPS/MHz 从600 MHz到超过1 GHz的速度)Texas Instruments OMAP3
Cortex-A9
Cortex-A9 MPCore
ARMv7-RCortex-R4(F)Embedded profile, (FPU)可变动高速缓存,MMU可选配600 DMIPSBroadcom is a user
ARMv7-MCortex-M3Microcontroller profile无高速缓存,(MPU)120 DMIPS @ 100MHzLuminary Micro微控制器家族
ARMv6-MCortex-M0
Cortex-M1
ARMv7-MECortex-M4Optional 8 region MPU with sub regions and background region1.25 DMIPS/MHz
