- #include <errno.h>
- #include <signal.h>
- #include <stdio.h>
- #include <string.h>
- #include <sys/resource.h>
- #include <sys/time.h>
- #include <sys/types.h>
- #include <unistd.h>
- #include <sys/mman.h>
- #include <rtdm/rtdm.h>
- #include <native/task.h>
- #include <native/sem.h>
- #include <native/mutex.h>
- #include <native/timer.h>
- #include <rtdk.h>
- #include <pthread.h>
- #include "ecrt.h"
- RT_TASK my_task;
- static int run = 1;
- // EtherCAT
- static ec_master_t *master = NULL;
- static ec_master_state_t master_state = {};
- static ec_domain_t *domain1 = NULL;
- static ec_domain_state_t domain1_state = {};
- static uint8_t *domain1_pd = NULL;
- static ec_slave_config_t *sc_el2008_1 = NULL;
- static ec_slave_config_t *sc_el2008_2 = NULL;
- static ec_slave_config_t *sc_el2008_3 = NULL;
- static ec_slave_config_t *sc_stm = NULL;
- // process data
- #define BusCoupler01_Pos 0, 0
- #define DigOutSlave01_Pos 0, 1
- #define DigOutSlave02_Pos 0, 2
- #define DigOutSlave03_Pos 0, 3
- #define DigOutSlave04_Pos 0, 4
- #define Beckhoff_EK1100 0x00000002, 0x044c2c52
- #define Beckhoff_EL2008 0x00000002, 0x07d83052
- #define stm32_lan9252 0x00000009, 0x00009252
- // offsets for PDO entries 所谓偏移,也相当于一个操作符号,不需要去写初始化,用户层只使用其地址
- static unsigned int off_dig_out0;
- static unsigned int off_dig_out1;
- static unsigned int off_dig_out2;
- static unsigned int off_dig_out3;
- static unsigned int off_dig_out4;
- static unsigned int off_dig_out5;
- // process data
- const static ec_pdo_entry_reg_t domain1_regs[] = {
- {DigOutSlave01_Pos, Beckhoff_EL2008, 0x7000, 0x01, &off_dig_out0, NULL},
- {DigOutSlave02_Pos, Beckhoff_EL2008, 0x7000, 0x01, &off_dig_out1, NULL},
- {DigOutSlave03_Pos, Beckhoff_EL2008, 0x7000, 0x01, &off_dig_out2, NULL},
- {DigOutSlave04_Pos, stm32_lan9252, 0x7010, 0x01, &off_dig_out3, NULL},
- {DigOutSlave04_Pos, stm32_lan9252, 0x6000, 0x01, &off_dig_out4, NULL},
- {DigOutSlave04_Pos, stm32_lan9252, 0x6020, 0x11, &off_dig_out5, NULL},
- /* Slave 1, "EL2008"
- * Vendor ID: 0x00000002
- * Product code: 0x07d83052
- * Revision number:"#x00100000"
- ec_pdo_entry_info_t slave_1_pdo_entries[] = {
- {0x7000, 0x01, 1}, /* Output */
- {0x7010, 0x01, 1}, /* Output */
- {0x7020, 0x01, 1}, /* Output */
- {0x7030, 0x01, 1}, /* Output */
- {0x7040, 0x01, 1}, /* Output */
- {0x7050, 0x01, 1}, /* Output */
- {0x7060, 0x01, 1}, /* Output */
- {0x7070, 0x01, 1} /* Output */
- ec_pdo_info_t slave_1_pdos[] = {
- {0x1600, 1, slave_1_pdo_entries + 0}, /* Channel 1 */
- {0x1601, 1, slave_1_pdo_entries + 1}, /* Channel 2 */
- {0x1602, 1, slave_1_pdo_entries + 2}, /* Channel 3 */
- {0x1603, 1, slave_1_pdo_entries + 3}, /* Channel 4 */
- {0x1604, 1, slave_1_pdo_entries + 4},
- {0x1605, 1, slave_1_pdo_entries + 5},
- {0x1606, 1, slave_1_pdo_entries + 6},
- {0x1607, 1, slave_1_pdo_entries + 7} /* Channel 8 */
- ec_sync_info_t slave_el2008_syncs[] = {
- {0, EC_DIR_OUTPUT, 8, slave_1_pdos + 0, EC_WD_ENABLE},
- {0xff}
- /* Master 0, Slave 4, "LAN9252-EVB-HBI"
- * Vendor ID: 0x00000009
- * Product code: 0x00009252
- * Revision number: 0x00000001
- ec_pdo_entry_info_t slave_stm_pdo_entries[] = {
- {0x7010, 0x01, 1}, /* LED 1 */
- {0x7010, 0x02, 1}, /* LED 2 */
- {0x7010, 0x03, 1}, /* LED 3 */
- {0x7010, 0x04, 1}, /* LED 4 */
- {0x7010, 0x05, 1}, /* LED 5 */
- {0x7010, 0x06, 1}, /* LED 6 */
- {0x7010, 0x07, 1}, /* LED 7 */
- {0x7010, 0x08, 1}, /* LED 8 */
- {0x0000, 0x00, 8}, /* Gap */
- {0x6000, 0x01, 1}, /* Switch 1 */
- {0x6000, 0x02, 1}, /* Switch 2 */
- {0x6000, 0x03, 1}, /* Switch 3 */
- {0x6000, 0x04, 1}, /* Switch 4 */
- {0x6000, 0x05, 1}, /* Switch 5 */
- {0x6000, 0x06, 1}, /* Switch 6 */
- {0x6000, 0x07, 1}, /* Switch 7 */
- {0x6000, 0x08, 1}, /* Switch 8 */
- {0x6020, 0x01, 1}, /* Underrange */
- {0x6020, 0x02, 1}, /* Overrange */
- {0x6020, 0x03, 2}, /* Limit 1 */
- {0x6020, 0x05, 2}, /* Limit 2 */
- {0x1802, 0x07, 1}, /* TxPDOState */
- {0x1802, 0x09, 1}, /* TxPDO Toggle */
- {0x6020, 0x11, 16}, /* Analog input */
- ec_pdo_info_t slave_stm_pdos[] = {
- {0x1601, 9, slave_stm_pdo_entries + 0}, /* DO RxPDO-Map */
- {0x1a00, 9, slave_stm_pdo_entries + 9}, /* DI TxPDO-Map */
- {0x1a02, 8, slave_stm_pdo_entries + 18}, /* AI TxPDO-Map */
- //sm0 for MBoxOut;sm1 for MBoxIn;sm2 for Outputs;sm3 for Inputs
- ec_sync_info_t slave_stm_syncs[] = {
- {0, EC_DIR_OUTPUT, 0, NULL, EC_WD_DISABLE},
- {1, EC_DIR_INPUT, 0, NULL, EC_WD_DISABLE},
- {2, EC_DIR_OUTPUT, 1, slave_stm_pdos + 0, EC_WD_ENABLE},
- {3, EC_DIR_INPUT, 2, slave_stm_pdos + 1, EC_WD_DISABLE},
- {0xff}
- * Realtime task
- void rt_check_domain_state(void)
- ec_domain_state_t ds = {};
- ecrt_domain_state(domain1, &ds);
- if (ds.working_counter != domain1_state.working_counter) {
- rt_printf("Domain1: WC %u.\n", ds.working_counter);
- if (ds.wc_state != domain1_state.wc_state) {
- rt_printf("Domain1: State %u.\n", ds.wc_state);
- domain1_state = ds;
- void rt_check_master_state(void)
- ec_master_state_t ms;
- ecrt_master_state(master, &ms);
- if (ms.slaves_responding != master_state.slaves_responding) {
- rt_printf("%u slave(s).\n", ms.slaves_responding);
- if (ms.al_states != master_state.al_states) {
- rt_printf("AL states: 0x%02X.\n", ms.al_states);
- if (ms.link_up != master_state.link_up) {
- rt_printf("Link is %s.\n", ms.link_up ? "up" : "down");
- master_state = ms;
- #define _ms 1000000
- void my_task_proc(void *arg)
- int cycle_counter = 0;
- unsigned int blink = 0;
- rt_task_set_periodic(NULL, TM_NOW, 1*_ms); // ns
- while (cycle_counter<10000) {
- rt_task_wait_period(NULL);
- cycle_counter++;
- // receive EtherCAT frames
- ecrt_master_receive(master);
- ecrt_domain_process(domain1);
- rt_check_domain_state();
- if (!(cycle_counter % 1000)) {
- rt_check_master_state();
- blink = !blink;
- printf("ad input... %d\n",EC_READ_U16(domain1_pd + off_dig_out5));
- EC_WRITE_U8(domain1_pd + off_dig_out0, blink ? 0xFF: 0x00);
- EC_WRITE_U8(domain1_pd + off_dig_out1, blink ? 0xFF: 0x00);
- EC_WRITE_U8(domain1_pd + off_dig_out2, blink ? 0xFF: 0x00);
- EC_WRITE_U8(domain1_pd + off_dig_out3, EC_READ_U8(domain1_pd + off_dig_out4));
- // send process data
- ecrt_domain_queue(domain1);
- ecrt_master_send(master);
- run = 0;
- * Signal handler
- void signal_handler(int sig)
- run = 0;
- * Main function=
- int main(int argc, char *argv[])
- int ret;
- /* Perform auto-init of rt_print buffers if the task doesn't do so */
- rt_print_auto_init(1);
- // rt_print_init(1000,"LEE_RT");
- signal(SIGTERM, signal_handler);
- signal(SIGINT, signal_handler);
- mlockall(MCL_CURRENT | MCL_FUTURE);
- printf("Requesting master...\n");
- master = ecrt_request_master(0);
- if (!master) {
- return -1;
- printf("Creating slave configurations...\n");
- // Create configuration for bus coupler EK1100
- ec_slave_config_t *sc;
- sc = ecrt_master_slave_config(master, BusCoupler01_Pos, Beckhoff_EK1100);
- if (!sc) {
- return -1;
- //获从站服配置
- sc_el2008_1 = ecrt_master_slave_config(master, DigOutSlave01_Pos, Beckhoff_EL2008);
- sc_el2008_2 = ecrt_master_slave_config(master, DigOutSlave02_Pos, Beckhoff_EL2008);
- sc_el2008_3 = ecrt_master_slave_config(master, DigOutSlave03_Pos, Beckhoff_EL2008);
- sc_stm = ecrt_master_slave_config(master, DigOutSlave04_Pos, stm32_lan9252);
- //过程数据SM配置
- ecrt_slave_config_pdos(sc_el2008_1, EC_END, slave_el2008_syncs);
- ecrt_slave_config_pdos(sc_el2008_2, EC_END, slave_el2008_syncs);
- ecrt_slave_config_pdos(sc_el2008_3, EC_END, slave_el2008_syncs);
- ecrt_slave_config_pdos(sc_stm, EC_END, slave_stm_syncs);
- //创建过程数据域
- domain1 = ecrt_master_create_domain(master);
- ecrt_domain_reg_pdo_entry_list(domain1, domain1_regs);
- printf("Activating master...\n");
- ecrt_master_activate(master);
- if (!(domain1_pd = ecrt_domain_data(domain1))) {
- fprintf(stderr, "Failed to get domain1 data pointer.\n");
- return -1;
- ret = rt_task_create(&my_task, "my_task", 0, 99, T_FPU);
- if (ret < 0) {
- fprintf(stderr, "Failed to create task: %s\n", strerror(-ret));
- return -1;
- printf("Starting my_task...\n");
- ret = rt_task_start(&my_task, &my_task_proc, NULL);
- if (ret < 0) {
- fprintf(stderr, "Failed to start task: %s\n", strerror(-ret));
- return -1;
- while (run) {
- sched_yield();
- printf("Deleting realtime task...\n");
- rt_task_delete(&my_task);
- printf("End of Program\n");
- ecrt_release_master(master);
- return 0;
