[DemoCode下载] [M032] Drive WS2812B LED Strip
637|0
 楼主| 奔跑的牛 发表于 2022-1-13 14:09 | 显示全部楼层 |阅读模式
  • Application: This sample code is an implementation of controlling the SPI transfer protocol of M032 from PC side via USB HID interface to drive WS2812B LED strip.
  • BSP Version: M031 BSP CMSIS V3.03.000
  • Hardware: NuMaker-M032KI Ver1.0
This sample code uses M032 series microcontrollers to drive WS2812B through MOSI of SPI0 or USPI0 to light RGB-LED strip. A user can control LED strip through USB interface using the PC AP Tool “LEDDongle_v1_0.exe”.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0927163135
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
