#申请原创# #技术资源#
参考资料
http://www.microchip.com.cn/newcommunity//Uploads/202008/5f44c72f4e170.pdf
http://www.microchip.com.cn/newcommunity/Uploads/202105/60a4bb701acd0.pdf
说明:PIC汇编器在安装PIC编译器时已经被安装了,在安装目录
添加汇编器
打开MPLAB X IDE
切换到Embedded面板点击Add按钮,打开编译添加窗口
选择pic-as汇编器路径
创建工程
按照普通工程创建一样创建汇编工程即可,只是在选择编译器时需要选择我们添加的pic-as汇编器
编写代码
向工程中新建*.s后缀的汇编文件
注:.s后缀是GUN风格的汇编文件
添加代码
- #include <xc.inc>
- ; CONFIG1
- CONFIG FEXTOSC = OFF ; External Oscillator Mode Selection bits (Oscillator not enabled)
- CONFIG RSTOSC = HFINTOSC_32MHZ; Power-up Default Value for COSC bits (HFINTOSC (32 MHz))
- CONFIG CLKOUTEN = OFF ; Clock Out Enable bit (CLKOUT function is disabled; I/O function on RA4)
- CONFIG VDDAR = HI ; VDD Range Analog Calibration Selection bit (Internal analog systems are calibrated for operation between VDD = 2.3V - 5.5V)
- ; CONFIG2
- CONFIG MCLRE = EXTMCLR ; Master Clear Enable bit (If LVP = 0, MCLR pin is MCLR; If LVP = 1, RA3 pin function is MCLR)
- CONFIG PWRTS = PWRT_OFF ; Power-up Timer Selection bits (PWRT is disabled)
- CONFIG WDTE = OFF ; WDT Operating Mode bits (WDT disabled; SEN is ignored)
- CONFIG BOREN = ON ; Brown-out Reset Enable bits (Brown-out Reset Enabled, SBOREN bit is ignored)
- CONFIG BORV = LO ; Brown-out Reset Voltage Selection bit (Brown-out Reset Voltage (VBOR) set to 1.9V)
- CONFIG PPS1WAY = ON ; PPSLOCKED One-Way Set Enable bit (The PPSLOCKED bit can be set once after an unlocking sequence is executed; once PPSLOCKED is set, all future changes to PPS registers are prevented)
- CONFIG STVREN = ON ; Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
- ; CONFIG3
- ; CONFIG4
- CONFIG BBSIZE = BB512 ; Boot Block Size Selection bits (512 words boot block size)
- CONFIG BBEN = OFF ; Boot Block Enable bit (Boot Block is disabled)
- CONFIG SAFEN = OFF ; SAF Enable bit (SAF is disabled)
- CONFIG WRTAPP = OFF ; Application Block Write Protection bit (Application Block is not write-protected)
- CONFIG WRTB = OFF ; Boot Block Write Protection bit (Boot Block is not write-protected)
- CONFIG WRTC = OFF ; Configuration Registers Write Protection bit (Configuration Registers are not write-protected)
- CONFIG WRTSAF = OFF ; Storage Area Flash (SAF) Write Protection bit (SAF is not write-protected)
- CONFIG LVP = ON ; Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/Vpp pin function is MCLR. MCLRE Configuration bit is ignored.)
- ; CONFIG5
- CONFIG CP = OFF ; User Program Flash Memory Code Protection bit (User Program Flash Memory code protection is disabled)
- ;CONFIG WDTE=OFF // WDT Disabled; SWDTEN is ignored
- ;this must be linked to the reset vector
- PSECT resetVec,class=CODE,reloc=1
- resetVec:
- GOTO main
- PSECT code
- main:
- ; This code example illustrates initializing the PORTA register.
- ; The other ports are initialized in the same manner.
- BANKSEL PORTA ;
- CLRF PORTA ;Clear PORTA
- BANKSEL LATA ;
- CLRF LATA ;Clear Data Latch
- BANKSEL ANSELA ;
- CLRF ANSELA ;Enable digital drivers
- BANKSEL TRISA ;
- MOVLW 00111000B ;Set RA[5:3] as inputs
- MOVWF TRISA ;and set others as outputs
- END
其中CONFIG配置字代码是IDE自动生成的,可以通过如下方法生成:
点击Window菜单 >> Target Memory Views >> Configuration Bits打开配置字UI界面
在配置字面板中,通过相关的下拉框来选择配置字需要设置的功能。此工程中配置为:关闭看门狗,使用内部32MHZ高速时钟
点击生成源代码按钮,并将生成的源代码复制到汇编文件开头即可。
设置链接器选项
- -presetVec=0h,-Map=led.map
编译代码
点击编译按钮
如下,表示编译成功。
调试器设置——使用调试器供电
选择调试器
打开Power设置面板
设置调试器给MCU的供电电压为:5V
