以root登陆LUNUX系统,出现以下提示: Your session only lasted less then 10 seconds.If you have not logged out yourself, this could mean that there is some installation problem or that you may be out of diskspace.Try logging in with one of the failsafe sessions to see if you can fix this problem. view details (~/.xsession-errors file) /etc/X11/xdm/Xsession:line 89:/bin/bash不存在? 硬盘看见绝对够,是什么问题呢?以其他用户可以登陆!
