[技术问答] I2C读写:keil代码与arduino代码,帮看看有什么问题
1984|16
 楼主| kylongmu 发表于 2022-2-20 20:03 | 显示全部楼层 |阅读模式
  1. int chdrv_read_byte(ch_dev_t *dev_ptr, uint16_t mem_addr, uint8_t *data) {
  2.         return (chbsp_i2c_mem_read(dev_ptr, mem_addr, data, 1));
  3. }
  4. int chbsp_i2c_mem_read(ch_dev_t *dev_ptr, uint16_t u16_mem_addr, uint8_t *pu8_data, uint16_t u16_num_bytes)
  5. {
  6.     int i32_error = 1;      // default is error return
  7.     uint8_t u8_i2c_addr = ch_get_i2c_address(dev_ptr);
  8.     i32_error = i2c_master_read_register(u8_i2c_addr, u16_mem_addr, u16_num_bytes, pu8_data);
  9.     return i32_error;
  10. }
  11. uint64_t i2c_master_read_register(uint8_t u8_Address, uint8_t u8_RegisterAddr, uint16_t u16_RegisterLen, uint8_t *pu8_RegisterValue)
  12. {
  13.     return !(u16_RegisterLen == I2C_ReadMultiBytesOneReg(I2C0, u8_Address, u8_RegisterAddr, pu8_RegisterValue, u16_RegisterLen));
  14. }
  15. uint32_t I2C_ReadMultiBytesOneReg(I2C_T *i2c, uint8_t u8SlaveAddr, uint8_t u8DataAddr, uint8_t au8Rdata[], uint32_t u32rLen)
  16. {
  17.     uint8_t u8Xfering = 1u, u8Err = 0u, u8Ctrl = 0u;
  18.     uint32_t u32rxLen = 0u;
  19.     I2C_START(i2c);                                                /* Send START */
  20.     while (u8Xfering && (u8Err == 0u))
  21.     {
  22.         I2C_WAIT_READY(i2c) {}
  23.         switch (I2C_GET_STATUS(i2c))
  24.         {
  25.             case 0x08u:
  26.                 I2C_SET_DATA(i2c, (uint8_t)(u8SlaveAddr << 1u | 0x00u));      /* Write SLA+W to Register I2CDAT */
  27.                 u8Ctrl = I2C_CTL_SI;                             /* Clear SI */
  28.                 break;
  29.             case 0x18u:                                             /* Slave Address ACK */
  30.                 I2C_SET_DATA(i2c, u8DataAddr);                     /* Write Lo byte address of register */
  31.                 break;
  32.             case 0x20u:                                             /* Slave Address NACK */
  33.             case 0x30u:                                             /* Master transmit data NACK */
  34.                 u8Ctrl = I2C_CTL_STO_SI;                         /* Clear SI and send STOP */
  35.                 u8Err = 1u;
  36.                 break;
  37.             case 0x28u:
  38.                 u8Ctrl = I2C_CTL_STA_SI;                         /* Send repeat START */
  39.                 break;
  40.             case 0x10u:
  41.                 I2C_SET_DATA(i2c, (uint8_t)((u8SlaveAddr << 1u) | 0x01u));    /* Write SLA+R to Register I2CDAT */
  42.                 u8Ctrl = I2C_CTL_SI;                             /* Clear SI */
  43.                 break;
  44.             case 0x40u:                                             /* Slave Address ACK */
  45.                 u8Ctrl = I2C_CTL_SI_AA;                          /* Clear SI and set ACK */
  46.                 break;
  47.             case 0x48u:                                             /* Slave Address NACK */
  48.                 u8Ctrl = I2C_CTL_STO_SI;                         /* Clear SI and send STOP */
  49.                 u8Err = 1u;
  50.                 break;
  51.             case 0x50u:
  52.                 au8Rdata[u32rxLen++] = (uint8_t) I2C_GET_DATA(i2c);   /* Receive Data */
  53.                 if (u32rxLen < (u32rLen - 1u))
  54.                 {
  55.                     u8Ctrl = I2C_CTL_SI_AA;                      /* Clear SI and set ACK */
  56.                 }
  57.                 else
  58.                 {
  59.                     u8Ctrl = I2C_CTL_SI;                         /* Clear SI */
  60.                 }
  61.                 break;
  62.             case 0x58u:
  63.                 au8Rdata[u32rxLen++] = (uint8_t) I2C_GET_DATA(i2c);   /* Receive Data */
  64.                 u8Ctrl = I2C_CTL_STO_SI;                         /* Clear SI and send STOP */
  65.                 u8Xfering = 0u;
  66.                 break;
  67.             case 0x38u:                                             /* Arbitration Lost */
  68.             default:                                               /* Unknow status */
  69.                 u8Ctrl = I2C_CTL_STO_SI;                         /* Clear SI and send STOP */
  70.                 u8Err = 1u;
  71.                 break;
  72.         }
  73.         I2C_SET_CONTROL_REG(i2c, u8Ctrl);                          /* Write controlbit to I2C_CTL register */
  74.     }
  75.     return u32rxLen;                                               /* Return bytes length that have been received */
  76. }
以上代码来自于新唐m263的例子,功能是从I2C设备读取内部寄存器一个字节。
  1.                 ret_val = chdrv_write_byte(dev_ptr, 0x07, 2);
  2. int chdrv_write_byte(ch_dev_t *dev_ptr, uint16_t mem_addr, uint8_t data_value) {
  3.         uint8_t message[] = { sizeof(data_value), data_value };                // insert byte count (1) at start of data
  4.         int ch_err = chbsp_i2c_mem_write(dev_ptr, mem_addr, message, sizeof(message));
  5.         return ch_err;
  6. }
  7. int chbsp_i2c_mem_write(ch_dev_t *dev_ptr, uint16_t mem_addr, uint8_t *pu8_data, uint16_t u16_num_bytes)
  8. {
  9.     int i32_error = 0;
  10.     i32_error = i2c_master_write_register(dev_ptr->i2c_address, mem_addr, u16_num_bytes, pu8_data);
  11.     return i32_error;
  12. }
  13. uint64_t i2c_master_write_register(uint8_t u8_Address, uint8_t u8_RegisterAddr, uint16_t u16_RegisterLen, uint8_t *pu8_RegisterValue)
  14. {
  15.     return !(u16_RegisterLen == I2C_WriteMultiBytesOneReg(I2C0, u8_Address, u8_RegisterAddr, pu8_RegisterValue, u16_RegisterLen));
  16. }
  17. uint32_t I2C_WriteMultiBytesOneReg(I2C_T *i2c, uint8_t u8SlaveAddr, uint8_t u8DataAddr, uint8_t au8Data[], uint32_t u32wLen)
  18. {
  19.     uint8_t u8Xfering = 1u, u8Err = 0u, u8Ctrl = 0u;
  20.     uint32_t u32txLen = 0u;
  21.     I2C_START(i2c);                                              /* Send START */
  22.     while (u8Xfering && (u8Err == 0u))
  23.     {
  24.         I2C_WAIT_READY(i2c) {}
  25.         switch (I2C_GET_STATUS(i2c))
  26.         {
  27.             case 0x08u:
  28.                 I2C_SET_DATA(i2c, (uint8_t)(u8SlaveAddr << 1u | 0x00u));    /* Write SLA+W to Register I2CDAT */
  29.                 u8Ctrl = I2C_CTL_SI;
  30.                 break;
  31.             case 0x18u:                                           /* Slave Address ACK */
  32.                 I2C_SET_DATA(i2c, u8DataAddr);                   /* Write Lo byte address of register */
  33.                 break;
  34.             case 0x20u:                                           /* Slave Address NACK */
  35.             case 0x30u:                                           /* Master transmit data NACK */
  36.                 u8Ctrl = I2C_CTL_STO_SI;                       /* Clear SI and send STOP */
  37.                 u8Err = 1u;
  38.                 break;
  39.             case 0x28u:
  40.                 if (u32txLen < u32wLen)
  41.                 {
  42.                     I2C_SET_DATA(i2c, au8Data[u32txLen++]);
  43.                 }
  44.                 else
  45.                 {
  46.                     u8Ctrl = I2C_CTL_STO_SI;                   /* Clear SI and send STOP */
  47.                     u8Xfering = 0u;
  48.                 }
  49.                 break;
  50.             case 0x38u:                                           /* Arbitration Lost */
  51.             default:                                             /* Unknow status */
  52.                 u8Ctrl = I2C_CTL_STO_SI;                       /* Clear SI and send STOP */
  53.                 u8Err = 1u;
  54.                 break;
  55.         }
  56.         I2C_SET_CONTROL_REG(i2c, u8Ctrl);                        /* Write controlbit to I2C_CTL register */
  57.     }
  58.     return u32txLen;                                             /* Return bytes length that have been transmitted */
  59. }
以上代码来自于新唐m263的例子,功能是从I2C设备写入内部寄存器2个字节。感觉好绕,最后底层的I2C代码我已看不出时序,现在用arduino来取代,代码如下:
  1. int chbsp_i2c_mem_write(ch_dev_t *dev_ptr, uint16_t mem_addr, uint8_t *data, uint16_t num_bytes){
  2.     TwoWire* pWire;
  3.     pWire=chbsp_i2c_get_device(dev_ptr);
  4.         if (pWire != NULL) {
  5.                 pWire->beginTransmission(dev_ptr->i2c_address);
  6.                 pWire->write(lowByte(mem_addr)); // LSB
  7.                 pWire->write(data,num_bytes);
  8.                 info = pWire->endTransmission();
  9.         }
  10. }
  11. int chbsp_i2c_mem_read(ch_dev_t *dev_ptr, uint16_t mem_addr, uint8_t *data, uint16_t num_bytes){
  12.     TwoWire* pWire = NULL;
  13.         int retval = 0;
  14.     pWire=chbsp_i2c_get_device(dev_ptr);
  15.         if (pWire != NULL) {
  16.                 pWire->beginTransmission(dev_ptr->i2c_address);
  17.             pWire->write(lowByte(mem_addr));
  18.             pWire->endTransmission();
  19.                 int receivedBytes = pWire->requestFrom((int)dev_ptr->i2c_address,(int)num_bytes,1);
  20.             if(receivedBytes != num_bytes)
  21.             {
  22.                 Serial.printf("did not receive enough bytes %dmem %dnum %drec %d\n.",mem_addr,num_bytes,receivedBytes,dev_ptr->i2c_address);
  23.                 retval = 1;
  24.             }else{
  25.                     for(int i = 0; i < num_bytes; i++)
  26.                     {
  27.                         data[i] = pWire->read();    // receive a byte as character
  28.                     }
  29.             }
  30.         }else{
  31.                 retval = 1;
  32.         }
  33.     return retval;
  34. }
但是我的arduino代码执行不正确,写入收到NACK,读出返回0字节,新唐的底层I2C实在看不懂,有大侠帮看看问题出在哪里,谢谢!
kiwis66 发表于 2022-2-21 09:39 | 显示全部楼层
arduino也是开发环境?
 楼主| kylongmu 发表于 2022-2-21 14:55 | 显示全部楼层
arduino也是开发环境?
是的,一个跨平台的,可以找到大量三方库的环境。
jasontu 发表于 2022-2-22 08:20 | 显示全部楼层
nak表示address错误,看下规格书上面的i2c devices是不是正碉的。
可以的话拿个la录下波形
 楼主| kylongmu 发表于 2022-2-22 12:00 | 显示全部楼层
可以的话拿个la录下波形
器件是TDK的CH101,有两个地址区,有一个prog脚来区分:原手册描述
The CH101 contains two separate I2C interfaces, running on two separate slave addresses. The first is for loading firmware into the
on-chip program memory, and the second is for in-application communication with the CH101. The 7-bit programming address is
0x45, and the 7-bit application address default is 0x29. The application address can be reprogrammed to any valid 7-bit I2C address.
m263的官网例子里也是这两个地址。我的arduino程序做了个测试,prog脚高选中读0x45能返回正确值。然后prog脚低电平,把0~127号地址都读了一遍,没有一个能返回的。
la手上没有,先定了一块例子用同款m263开发板,拿来跑一遍看看现象。
TDK的这颗芯片实在难受,手册内容少的可怜,同时这颗芯片I2C操作之复杂,是我目前遇到过最难的,分地址区,传固件,然后是一堆命令来回,而这些东西都是手册上没有的。
以下链接可以看到这个例子原工程:
https://www.nuvoton.com.cn/products/microcontrollers/arm-cortex-m23-mcus/m261-m262-m263-series/m263kiaae/?group=Software&tab=2
 楼主| kylongmu 发表于 2022-2-22 14:58 | 显示全部楼层
刚刚考虑了一下,估计是第一步下载I2C固件有问题,固件没有工作,所以后面与固件通信的操作没有响应。还是只有等m263的开发板来跑一遍看看。
tpgf 发表于 2022-3-3 19:03 | 显示全部楼层
这俩是不同的软件吗
labasi 发表于 2022-3-3 19:10 | 显示全部楼层
应该是地址有错误
paotangsan 发表于 2022-3-3 19:16 | 显示全部楼层
还是参考官网例程吧
renzheshengui 发表于 2022-3-3 19:30 | 显示全部楼层
严格检查时序
wakayi 发表于 2022-3-3 19:37 | 显示全部楼层
这么看着实看不出问题来
wowu 发表于 2022-3-3 19:43 | 显示全部楼层
更改了哪一部分呢
豌豆爹 发表于 2022-3-4 10:47 | 显示全部楼层
多多参考下官方例程总是没错的
 楼主| kylongmu 发表于 2022-3-6 21:57 | 显示全部楼层
测试了官方263例子,读写都正确,arduino那边代码对比检查,实在找不出毛病,先放弃了。
改为移植到stm32l433上,一次成功。
因为263与stm32l433都是1.8V电平直接连接ch101,而arduino那边是用TXS0108EPWR做了个电平转换,目前感觉是这里有可能出问题,也怀疑arduino在连续传固件的时候会中断。先把arduino放一边吧。
 楼主| kylongmu 发表于 2022-3-6 22:03 | 显示全部楼层
目前测试ch101返回的测量数值乱跳,在263上与stm32l4上都是,看了263的例子里用的ch101库还是早期的,很长时间没有更新了,又到TDK那边下了最新的库来自己升级替换,结果测试值还是乱跳,网上搜了一遍没有看到谁用过这颗超声TOF,看来我踩深坑里了
 楼主| kylongmu 发表于 2022-3-6 22:07 | 显示全部楼层
我为啥要反向移植到stm32呢?因为cubemx实在是太方便了,我可以省去很多学习成本。而263这边就费劲多了。当然要是能用arduino来开发,二者皆可抛
kiwis66 发表于 2022-3-11 16:49 | 显示全部楼层
再学习一下
