- * [url=home.php?mod=space&uid=288409]@file[/url] Examples_LL/RTC/RTC_Alarm/Src/main.c
- * [url=home.php?mod=space&uid=187600]@author[/url] MCD Application Team
- * [url=home.php?mod=space&uid=247401]@brief[/url] This example code shows how to use STM32G4xx RTC LL API to configure
- * an alarm.
- * Peripheral initialization done using LL unitary services functions.
- * @attention
- * <h2><center>© Copyright (c) 2020 STMicroelectronics.
- * All rights reserved.</center></h2>
- * This software component is licensed by ST under BSD 3-Clause license,
- * the "License"; You may not use this file except in compliance with the
- * License. You may obtain a copy of the License at:
- * opensource.org/licenses/BSD-3-Clause
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- /** @addtogroup STM32G4xx_LL_Examples
- /** @addtogroup RTC_Alarm
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Oscillator time-out values */
- #define LSI_TIMEOUT_VALUE ((uint32_t)2) /* 2 ms */
- #define LSE_TIMEOUT_VALUE ((uint32_t)5000) /* 5 s */
- #define RTC_TIMEOUT_VALUE ((uint32_t)1000) /* 1 s */
- /* Defines related to Clock configuration */
- /* Uncomment to enable the adequate Clock Source */
- #define RTC_CLOCK_SOURCE_LSE
- /*#define RTC_CLOCK_SOURCE_LSI*/
- #ifdef RTC_CLOCK_SOURCE_LSI
- /* ck_apre=LSIFreq/(ASYNC prediv + 1) with LSIFreq=32 kHz RC */
- #define RTC_ASYNCH_PREDIV ((uint32_t)0x7F)
- /* ck_spre=ck_apre/(SYNC prediv + 1) = 1 Hz */
- #define RTC_SYNCH_PREDIV ((uint32_t)0x00FF)
- #endif
- #ifdef RTC_CLOCK_SOURCE_LSE
- /* ck_apre=LSEFreq/(ASYNC prediv + 1) = 256Hz with LSEFreq=32768Hz */
- #endif
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Buffers used for displaying Time and Date */
- uint8_t aShowTime[] = "hh:ms:ss";
- uint8_t aShowDate[] = "dd/mm/aaaa";
- #if (USE_TIMEOUT == 1)
- uint32_t Timeout = 0; /* Variable used for Timeout management */
- #endif /* USE_TIMEOUT */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- void Configure_RTC(void);
- void Configure_RTC_Alarm(void);
- uint32_t Enter_RTC_InitMode(void);
- uint32_t Exit_RTC_InitMode(void);
- uint32_t WaitForSynchro_RTC(void);
- void Show_RTC_Calendar(void);
- void LED_Init(void);
- void LED_On(void);
- void LED_Blinking(uint32_t Period);
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program
- * @param None
- * @retval None
- int main(void)
- /* Configure the system clock to 170 MHz */
- SystemClock_Config();
- /* Initialize LED2 */
- LED_Init();
- /*##-1- Configure the RTC peripheral #######################################*/
- Configure_RTC();
- /*##-2- Configure Alarm ####################################################*/
- /* Configure RTC Alarm */
- Configure_RTC_Alarm();
- /* Infinite loop */
- while (1)
- /*##-3- Display the updated Time and Date ################################*/
- Show_RTC_Calendar();
- * @brief Configure RTC.
- * [url=home.php?mod=space&uid=536309]@NOTE[/url] Peripheral configuration is minimal configuration from reset values.
- * Thus, some useless LL unitary functions calls below are provided as
- * commented examples - setting is default configuration from reset.
- * @param None
- * @retval None
- /*##-1- Enables the PWR Clock and Enables access to the backup domain #######*/
- /* To change the source clock of the RTC feature (LSE, LSI), you have to:
- - Enable the power clock
- - Enable write access to configure the RTC clock source (to be done once after reset).
- - Reset the Back up Domain
- - Configure the needed RTC clock source */
- LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_PWR);
- LL_PWR_EnableBkUpAccess();
- /*##-2- Configure LSE/LSI as RTC clock source ###############################*/
- /* Enable LSE only if disabled.*/
- if (LL_RCC_LSE_IsReady() == 0)
- LL_RCC_ForceBackupDomainReset();
- LL_RCC_ReleaseBackupDomainReset();
- LL_RCC_LSE_Enable();
- Timeout = LSE_TIMEOUT_VALUE;
- while (LL_RCC_LSE_IsReady() != 1)
- if (LL_SYSTICK_IsActiveCounterFlag())
- Timeout --;
- if (Timeout == 0)
- /* LSE activation error */
- LED_Blinking(LED_BLINK_ERROR);
- LL_RCC_SetRTCClockSource(LL_RCC_RTC_CLKSOURCE_LSE);
- /*##-3- Enable RTC peripheral Clocks #######################################*/
- /* Enable RTC Clock */
- LL_RCC_EnableRTC();
- #elif defined(RTC_CLOCK_SOURCE_LSI)
- if (LL_RCC_LSI_IsReady() == 0)
- LL_RCC_LSI_Enable();
- Timeout = LSI_TIMEOUT_VALUE;
- while (LL_RCC_LSI_IsReady() != 1)
- Timeout --;
- if (Timeout == 0)
- /* LSI activation error */
- LL_RCC_SetRTCClockSource(LL_RCC_RTC_CLKSOURCE_LSI);
- #else
- #error "configure clock for RTC"
- #endif
- /*##-4- Disable RTC registers write protection ##############################*/
- LL_RTC_DisableWriteProtection(RTC);
- /*##-5- Enter in initialization mode #######################################*/
- if (Enter_RTC_InitMode() != RTC_ERROR_NONE)
- /* Initialization Error */
- /*##-6- Configure RTC ######################################################*/
- /* Configure RTC prescaler and RTC data registers */
- /* Set Hour Format */
- LL_RTC_SetHourFormat(RTC, LL_RTC_HOURFORMAT_AMPM);
- /* Set Asynch Prediv (value according to source clock) */
- LL_RTC_SetAsynchPrescaler(RTC, RTC_ASYNCH_PREDIV);
- /* Set Synch Prediv (value according to source clock) */
- LL_RTC_SetSynchPrescaler(RTC, RTC_SYNCH_PREDIV);
- /* Set OutPut */
- /* Reset value is LL_RTC_ALARMOUT_DISABLE */
- //LL_RTC_SetAlarmOutEvent(RTC, LL_RTC_ALARMOUT_DISABLE);
- /* Set OutPutPolarity */
- /* Reset value is LL_RTC_OUTPUTPOLARITY_PIN_HIGH */
- //LL_RTC_SetOutputPolarity(RTC, LL_RTC_OUTPUTPOLARITY_PIN_HIGH);
- /* Set OutPutType */
- /* Reset value is LL_RTC_ALARM_OUTPUTTYPE_OPENDRAIN */
- //LL_RTC_SetAlarmOutputType(RTC, LL_RTC_ALARM_OUTPUTTYPE_OPENDRAIN);
- /*##-7- Exit of initialization mode #######################################*/
- Exit_RTC_InitMode();
- /*##-8- Enable RTC registers write protection #############################*/
- LL_RTC_EnableWriteProtection(RTC);
- * @brief Configure the current time and date.
- * @note Peripheral configuration is minimal configuration from reset values.
- * @param None
- * @param None
- * @retval None
- /*##-1- Disable RTC registers write protection ############################*/
- /*##-2- Enter in initialization mode ######################################*/
- /*##-3- Configure the Date ################################################*/
- /* Note: __LL_RTC_CONVERT_BIN2BCD helper macro can be used if user wants to*/
- /* provide directly the decimal value: */
- /* LL_RTC_DATE_Config(RTC, LL_RTC_WEEKDAY_MONDAY, */
- /* __LL_RTC_CONVERT_BIN2BCD(31), (...)) */
- /* Set Date: Friday December 29th 2016 */
- LL_RTC_DATE_Config(RTC, LL_RTC_WEEKDAY_FRIDAY, 0x29, LL_RTC_MONTH_DECEMBER, 0x16);
- /*##-4- Configure the Time ################################################*/
- /* Set Time: 11:59:55 PM*/
- LL_RTC_TIME_Config(RTC, LL_RTC_TIME_FORMAT_PM, 0x11, 0x59, 0x55);
- /*##-5- Configure the RTC Alarm peripheral #################################*/
- /* Set Alarm to 12:00:25
- RTC Alarm Generation: Alarm on Hours, Minutes and Seconds (ignore date/weekday)*/
- LL_RTC_ALMA_ConfigTime(RTC, LL_RTC_ALMA_TIME_FORMAT_AM, 0x12, 0x00, 0x25);
- LL_RTC_ALMA_SetMask(RTC, LL_RTC_ALMA_MASK_DATEWEEKDAY);
- /* Note: following interfaces may be used but not needed as default values are used.*/
- //LL_RTC_ALMA_SetSubSecond(RTC, 0x00);
- //LL_RTC_ALMA_SetSubSecondMask(RTC, 0);
- //LL_RTC_ALMA_DisableWeekday(RTC);
- //LL_RTC_ALMA_SetDay(RTC, 0x01);
- /* Enable Alarm*/
- LL_RTC_ALMA_Enable(RTC);
- /* Clear the Alarm interrupt pending bit */
- LL_RTC_ClearFlag_ALRA(RTC);
- /* Enable IT Alarm */
- LL_RTC_EnableIT_ALRA(RTC);
- /* RTC Alarm Interrupt Configuration: EXTI configuration */
- LL_EXTI_EnableIT_0_31(LL_EXTI_LINE_17);
- LL_EXTI_EnableRisingTrig_0_31(LL_EXTI_LINE_17);
- /*##-6- Configure the NVIC for RTC Alarm ###############################*/
- NVIC_SetPriority(RTC_Alarm_IRQn, 0x0F);
- NVIC_EnableIRQ(RTC_Alarm_IRQn);
- if (Exit_RTC_InitMode() != RTC_ERROR_NONE)
- * @brief Enter in initialization mode
- * @note In this mode, the calendar counter is stopped and its value can be updated
- * @param None
- * @retval RTC_ERROR_NONE if no error
- /* Set Initialization mode */
- LL_RTC_EnableInitMode(RTC);
- Timeout = RTC_TIMEOUT_VALUE;
- /* Check if the Initialization mode is set */
- while (LL_RTC_IsActiveFlag_INIT(RTC) != 1)
- Timeout --;
- if (Timeout == 0)
- return RTC_ERROR_TIMEOUT;
- return RTC_ERROR_NONE;
- * @brief Exit Initialization mode
- * @param None
- LL_RTC_DisableInitMode(RTC);
- /* Wait for synchro */
- /* Note: Needed only if Shadow registers is enabled */
- /* LL_RTC_IsShadowRegBypassEnabled function can be used */
- return (WaitForSynchro_RTC());
- * @brief Wait until the RTC Time and Date registers (RTC_TR and RTC_DR) are
- * synchronized with RTC APB clock.
- * @param None
- * @retval RTC_ERROR_NONE if no error (RTC_ERROR_TIMEOUT will occur if RTC is
- * not synchronized)
- /* Clear RSF flag */
- LL_RTC_ClearFlag_RS(RTC);
- /* Wait the registers to be synchronised */
- while (LL_RTC_IsActiveFlag_RS(RTC) != 1)
- Timeout --;
- if (Timeout == 0)
- * @brief Display the current time and date.
- * @param None
- * @retval None
- /* Note: need to convert in decimal value in using __LL_RTC_CONVERT_BCD2BIN helper macro */
- /* Display time Format : hh:mm:ss */
- sprintf((char *)aShowTime, "%.2d:%.2d:%.2d", __LL_RTC_CONVERT_BCD2BIN(LL_RTC_TIME_GetHour(RTC)),
- __LL_RTC_CONVERT_BCD2BIN(LL_RTC_TIME_GetMinute(RTC)),
- __LL_RTC_CONVERT_BCD2BIN(LL_RTC_TIME_GetSecond(RTC)));
- /* Display date Format : mm-dd-yy */
- sprintf((char *)aShowDate, "%.2d-%.2d-%.2d", __LL_RTC_CONVERT_BCD2BIN(LL_RTC_DATE_GetMonth(RTC)),
- __LL_RTC_CONVERT_BCD2BIN(LL_RTC_DATE_GetDay(RTC)),
- 2000 + __LL_RTC_CONVERT_BCD2BIN(LL_RTC_DATE_GetYear(RTC)));
- * @brief Initialize LED2.
- * @param None
- * @retval None
- /* Enable the LED2 Clock */
- LED2_GPIO_CLK_ENABLE();
- /* Configure IO in output push-pull mode to drive external LED2 */
- LL_GPIO_SetPinMode(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_MODE_OUTPUT);
- /* Reset value is LL_GPIO_OUTPUT_PUSHPULL */
- //LL_GPIO_SetPinOutputType(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_OUTPUT_PUSHPULL);
- /* Reset value is LL_GPIO_SPEED_FREQ_LOW */
- //LL_GPIO_SetPinSpeed(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_SPEED_FREQ_LOW);
- /* Reset value is LL_GPIO_PULL_NO */
- //LL_GPIO_SetPinPull(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_PULL_NO);
- * @brief Turn-on LED2.
- * @param None
- * @retval None
- void LED_On(void)
- /* Turn LED2 on */
- LL_GPIO_SetOutputPin(LED2_GPIO_PORT, LED2_PIN);
- * @brief Set LED2 to Blinking mode for an infinite loop (toggle period based on value provided as input parameter).
- * @param Period : Period of time (in ms) between each toggling of LED
- * This parameter can be user defined values. Pre-defined values used in that example are :
- * [url=home.php?mod=space&uid=2817080]@ARG[/url] LED_BLINK_FAST : Fast Blinking
- * @arg LED_BLINK_SLOW : Slow Blinking
- * @arg LED_BLINK_ERROR : Error specific Blinking
- * @retval None
- /* Toggle IO in an infinite loop */
- while (1)
- LL_GPIO_TogglePin(LED2_GPIO_PORT, LED2_PIN);
- LL_mDelay(Period);
- * @brief System Clock Configuration
- * The system Clock is configured as follows :
- * System Clock source = PLL (HSI)
- * SYSCLK(Hz) = 170000000
- * HCLK(Hz) = 170000000
- * AHB Prescaler = 1
- * APB1 Prescaler = 1
- * APB2 Prescaler = 1
- * PLL_M = 4
- * PLL_N = 85
- * PLL_P = 2
- * PLL_Q = 2
- * PLL_R = 2
- * Flash Latency(WS) = 4
- * @param None
- * @retval None
- /* Flash Latency configuration */
- LL_FLASH_SetLatency(LL_FLASH_LATENCY_4);
- /* Enable boost mode to be able to reach 170MHz */
- LL_PWR_EnableRange1BoostMode();
- /* HSI configuration and activation */
- LL_RCC_HSI_Enable();
- while(LL_RCC_HSI_IsReady() != 1)
- /* Main PLL configuration and activation */
- LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSI, LL_RCC_PLLM_DIV_4, 85, LL_RCC_PLLR_DIV_2);
- LL_RCC_PLL_Enable();
- LL_RCC_PLL_EnableDomain_SYS();
- while(LL_RCC_PLL_IsReady() != 1)
- /* Sysclk activation on the main PLL */
- LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_2);
- LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
- while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
- LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
- /* Insure 1µs transition state at intermediate medium speed clock based on DWT */
- CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk;
- DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
- while(DWT->CYCCNT < 100);
- /* Set APB1 & APB2 prescaler*/
- LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
- LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_1);
- /* Set systick to 1ms in using frequency set to 170MHz */
- /* This frequency can be calculated through LL RCC macro */
- /* ex: __LL_RCC_CALC_PLLCLK_FREQ(__LL_RCC_CALC_HSI_FREQ(),
- LL_RCC_PLLM_DIV_4, 85, LL_RCC_PLLR_DIV_2)*/
- LL_Init1msTick(170000000);
- /* Update CMSIS variable (which can be updated also through SystemCoreClockUpdate function) */
- LL_SetSystemCoreClock(170000000);
- /* USER IRQ HANDLER TREATMENT */
- * @brief Alarm callback
- * @param None
- * @retval None
- void Alarm_Callback(void)
- /* Turn LED2 on: Alarm generation */
- LED_On();
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(char *file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
