pms150g按键
860|0
 楼主| 34af9uc 发表于 2022-10-15 21:10 | 显示全部楼层 |阅读模式
//                     pms150g
//                 ______   ______
//           3.3v-|1-vdd \_/ gnd-8|-gnd
//               -|2-pa7     pa0-7|-
//               -|3-pa6     pa4-6|-led
//               -|4-pa5_____pa3-5|-anjian
#include        "extern.h"
led_1                bit                pa.0;
led_2                bit                pa.4;
anjian_1                bit                pa.5;
byte                kaiji;
void                anjian();
void                xianshi();
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
$                led_1                out,High;
$                led_2                out,High;
$                anjian_1                in,Pull;
kaiji                =0;
while (1)
xianshi();
anjian();
void        Interrupt (void)
        pushaf;
        if (Intrq.T16)
        {        //        T16 Trig
                //        User can add code
                Intrq.T16        =        0;
        popaf;
void                anjian()
if(anjian_1==0)
if(kaiji==0){kaiji=1;} else{kaiji=0;}
while(anjian_1==0){nop;nop;}
void                xianshi()
if(kaiji==0)
led_1                =1;
led_2                =0;
if(kaiji==1)
led_1                =0;
.delay 4000000;
led_2                =1;
点灯.zip
554 Bytes, 下载次数: 6
319
