[APM32F1] APM32F103C8T6定时器主从模式
814|2
 楼主| 叶萌 发表于 2022-10-24 17:46 | 显示全部楼层 |阅读模式
定时器1和定时器4设置为主从模式,为何不行,请大佬帮我看看?定时器1PWM输出
3mhz的方波,然后同时可以触发定时器4生成5khz的中断。代码如下:
void  InitTime1Config(void)
        GPIO_Config_T GPIO_ConfigStruct;
    TMR_BaseConfig_T TMR_TimeBaseStruct;
    TMR_OCConfig_T OCcongigStruct;
    RCM_EnableAPB2PeriphClock((RCM_APB2_PERIPH_T)(RCM_APB2_PERIPH_GPIOA | RCM_APB2_PERIPH_TMR1 ));
    GPIO_ConfigStruct.pin = GPIO_PIN_8;
    GPIO_ConfigStruct.mode = GPIO_MODE_AF_PP;
    GPIO_ConfigStruct.speed = GPIO_SPEED_50MHz;
    GPIO_Config(GPIOA, &GPIO_ConfigStruct);
    TMR_TimeBaseStruct.clockDivision = TMR_CLOCK_DIV_1;
    TMR_TimeBaseStruct.countMode = TMR_COUNTER_MODE_UP;
    TMR_TimeBaseStruct.division = 0;
    TMR_TimeBaseStruct.period = 19;
    TMR_ConfigTimeBase(TMR1, &TMR_TimeBaseStruct);
        TMR_SelectSinglePulseMode(TMR1,TMR_SPM_SINGLE);
        TMR_SelectSlaveMode(TMR1,TMR_SLAVE_MODE_TRIGGER);
        TMR_EnableMasterSlaveMode(TMR1);
        TMR_SelectOutputTrigger(TMR1,TMR_TRGO_SOURCE_UPDATE);
    OCcongigStruct.idleState = TMR_OC_IDLE_STATE_RESET;
    OCcongigStruct.mode = TMR_OC_MODE_PWM1;
    OCcongigStruct.nIdleState = TMR_OC_NIDLE_STATE_RESET;
    OCcongigStruct.nPolarity = TMR_OC_NPOLARITY_HIGH;
    OCcongigStruct.outputNState = TMR_OC_NSTATE_DISABLE;
    OCcongigStruct.outputState = TMR_OC_STATE_DISABLE;
    OCcongigStruct.polarity = TMR_OC_POLARITY_LOW;
    OCcongigStruct.pulse = 10;
    TMR_ConfigOC1(TMR1, &OCcongigStruct);
    TMR_ConfigOC1Preload(TMR1, TMR_OC_PRELOAD_ENABLE);
    TMR_EnableAUTOReload(TMR1);
    TMR_Enable(TMR1);
    TMR_EnablePWMOutputs(TMR1);
void  InitTime4Config(void)
    TMR_BaseConfig_T TMR_BaseConfigStruct;
    RCM_EnableAPB1PeriphClock(RCM_APB1_PERIPH_TMR4);
    TMR_BaseConfigStruct.clockDivision = TMR_CLOCK_DIV_1;
    TMR_BaseConfigStruct.countMode = TMR_COUNTER_MODE_UP;
    TMR_BaseConfigStruct.division = 29;
    TMR_BaseConfigStruct.period = 9;
    TMR_BaseConfigStruct.repetitionCounter = 0;
    TMR_ConfigTimeBase(TMR4, &TMR_BaseConfigStruct);
        TMR_SelectSlaveMode(TMR4,TMR_SLAVE_MODE_EXTERNALL);
        TMR_EnableMasterSlaveMode(TMR4);
        TMR_SelectInputTrigger(TMR4,TMR_TRIGGER_SOURCE_ITR0);
    TMR_EnableInterrupt(TMR4, TMR_INT_UPDATE);
    NVIC_EnableIRQRequest(TMR4_IRQn, 0, 0);
    TMR_Enable(TMR4);
 楼主| 叶萌 发表于 2022-10-25 08:33 | 显示全部楼层
MarkJin 发表于 2022-11-9 15:33 来自手机 | 显示全部楼层
需要购买,加我17520541676
