[N32G03x] N32G031 ADC采样50Hz正弦波有效值波动严重
1503|12
 楼主| 发顺丰顺丰 发表于 2022-11-1 08:25 | 显示全部楼层 |阅读模式
现象:芯片计算出来的有效值波动较大,最大最小值偏差59%。抓了ADC输入信号是稳定的。均方根算法验证过是正确的,带入固定数据算得也是对的。采样方式:软件触发,0.625ms使能1次,共采集16次,在定时器中使能 ADC_EnableSoftwareStartConv(ADC,ENABLE);
AD读取方式:AD中断里读取ADC_GetDat(ADC);
初始化:
void ADC_Initial(void)
          ErrorStatus HSIStartUpStatus;
          ADC_InitType ADC_InitStructure;
    NVIC_InitType NVIC_InitStructure;
    /* Configure and enable ADC interrupt */
    NVIC_InitStructure.NVIC_IRQChannel                   = ADC_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPriority           = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    /* Enable ADC clocks */
    RCC_EnableAHBPeriphClk(RCC_AHB_PERIPH_ADC, ENABLE);
    /* enable ADC 1M clock */
    RCC_EnableHsi(ENABLE);
    /* Wait til1 HSI is ready*/
    HSIStartUpStatus = RCC_WaitHsiStable();
    if(HSIStartUpStatus == SUCCESS)
    else
        /* If HSI fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error*/
        /* Go to infinitel1oop*/
        while(1)
    RCC_ConfigAdc1mClk(RCC_ADC1MCLK_SRC_HSI, RCC_ADC1MCLK_DIV8);
    /* RCC_ADCHCLK_DIV16*/
    ADC_ConfigClk(ADC_CTRL3_CKMOD_AHB, RCC_ADCHCLK_DIV16);
    /* ADC configuration ------------------------------------------------------*/
    ADC_InitStructure.MultiChEn      = ENABLE;
    ADC_InitStructure.ContinueConvEn = DISABLE;
    ADC_InitStructure.ExtTrigSelect  = ADC_EXT_TRIGCONV_NONE;
    ADC_InitStructure.DatAlign       = ADC_DAT_ALIGN_R;
    ADC_InitStructure.ChsNumber      = 1;
    ADC_Init(ADC, &ADC_InitStructure);
    /* ADC regular channels configuration */
    ADC_ConfigRegularChannel(ADC, ADC_CH_4_PA4, 1, ADC_SAMP_TIME_29CYCLES5);
//    ADC_ConfigRegularChannel(ADC, ADC_CH_5_PA5, 2, ADC_SAMP_TIME_29CYCLES5);
    /* Regular discontinuous mode channel number configuration */
    ADC_ConfigDiscModeChannelCount(ADC, 1);
    /* Enable regular discontinuous mode */
    ADC_EnableDiscMode(ADC, ENABLE);
    /* Enable interrupt */
    ADC_ConfigInt(ADC, ADC_INT_ENDC, ENABLE);
                ADC_EnableVrefint(ENABLE);
    /* Enable ADC */
    ADC_Enable(ADC, ENABLE);
    /*wait ADC is ready to use*/
    while(!ADC_GetFlagStatusNew(ADC, ADC_FLAG_RDY))
    /*wait ADC is powered on*/
    while(ADC_GetFlagStatusNew(ADC, ADC_FLAG_PD_RDY))
sy12138 发表于 2022-11-1 10:05 | 显示全部楼层
采集的是多大的电压
 楼主| 发顺丰顺丰 发表于 2022-11-1 12:40 | 显示全部楼层
采集的是多大的电压
交流信号是0.4V,直流偏置1.25V
朝生 发表于 2022-11-1 17:07 | 显示全部楼层
感觉是输入信号频率太高导致的,50Hz的正弦波,说实话用内置ADC性能跟不上。
朝生 发表于 2022-11-1 17:09 | 显示全部楼层
你可以尝试把输入频率调小一些看看误差会不会减小。
Pretext 发表于 2022-11-1 17:09 | 显示全部楼层
内置ADC本来不稳定,不过误差这么大还是有点问题的。
xch 发表于 2022-11-1 21:13 | 显示全部楼层
采样方式:软件触发,0.625ms使能1次,共采集16次?  为啥不采集32次?
国产ADC有毛病的。用完整周期数据可以比较好过滤。
xch 发表于 2022-11-1 21:37 | 显示全部楼层
交流信号是0.4V,直流偏置1.25V
是理论值还是测量值?
 楼主| 发顺丰顺丰 发表于 2022-11-2 08:32 | 显示全部楼层
是理论值还是测量值?
测量值,直流偏置纹波10mV左右,交流信号也是很稳
 楼主| 发顺丰顺丰 发表于 2022-11-2 08:34 | 显示全部楼层
国产ADC有毛病的。用完整周期数据可 ...
16点 32点都试过,也不稳,调整了一下,误差在8%左右,用其它单片机可以做到1%
一周一天班 发表于 2022-11-3 10:25 | 显示全部楼层
VDDA(基准)不稳?
xch 发表于 2022-11-3 17:30 | 显示全部楼层
16点 32点都试过,也不稳,调整了一下,误差在8%左右,用其它单片机可以做到1% ...
将交流电压改成0,看看直流电压采集准不准
AloneKaven 发表于 2022-11-4 22:14 | 显示全部楼层
把输入频率调小一些看看
