那&符号是表示与的意思, &只有1&1的时候才是1,其他都是0,而 | 则相反,只有0 | 0的时候才是0
电路图
ULN2003达林顿管——输入和输出是相反的
代码呈现:
#include "reg52.h"
sbit HC138_A=P2^5;
sbit HC138_B=P2^6;
sbit HC138_C=P2^7;
void Delay(unsigned int t)
while(t--);
while(t--);
void HC138(unsigned char n)
switch(n)
case 4: //P2=(P2&0xlf)|0x80;
HC138_C=1;
HC138_B=0;
HC138_A=0;
break;
case 5: //P2=(P2&0xlf)|0xa0;
HC138_C=1;
HC138_B=0;
HC138_A=1;
break;
case 6: //P2=(P2&0xlf)|0xc0;
HC138_C=1;
HC138_B=1;
HC138_A=0;
break;
case 7: //P2=(P2&0xlf)|0xe0;
HC138_C=1;
HC138_B=1;
HC138_A=1;
break;
void abcdef(unsigned char channel,unsigned char dat)
HC138(channel);
P0=dat;
void LEDRunning()
unsigned char i;
for(i=0;i<3;i++)
abcdef(4,0x00);
Delay(60000);
Delay(60000);
abcdef(4,0xff);
Delay(60000);
Delay(60000);
for(i=1;i<=8;i++)
P0=0xff<<i;
Delay(60000);
Delay(60000);
abcdef(5,0x10);
Delay(60000);
Delay(60000);
abcdef(5,0x00);
for(i=1;i<=8;i++)
abcdef(4,~(0xff<<i));
Delay(60000);
Delay(60000);
abcdef(5,0x40);
Delay(60000);
Delay(60000);
abcdef(5,0x00);
Delay(60000);
Delay(60000);
void InitSystem()
abcdef(5,0x00);
void main()
InitSystem();
while(1)
LEDRunning();
