[其他ST产品] STM32 不断进入串口中断问题 解决方法
816|13
 楼主| c17 发表于 2023-4-30 20:15 | 显示全部楼层 |阅读模式
STM32 有时候会不断进入中断,解决方法如下
  1. 1.串口初始化配置时,需要打开ORE 溢出中断,如下红色代码所示
  2. void Usart_Init(void)
  3. {
  4.
  5.
  6.     GPIO_InitTypeDef GPIO_InitStructure;
  7.     NVIC_InitTypeDef NVIC_InitStructure;
  8.     USART_InitTypeDef USART_InitStructure;
  9.
  10.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);                          // 开启串口时钟
  11.
  12.     GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_1);
  13.     GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_1);
  14.
  15.     GPIO_InitStructure.GPIO_Pin     = GPIO_Pin_9 | GPIO_Pin_10;
  16.     GPIO_InitStructure.GPIO_Speed   = GPIO_Speed_50MHz;
  17.     GPIO_InitStructure.GPIO_Mode    = GPIO_Mode_AF;
  18.     GPIO_InitStructure.GPIO_OType   = GPIO_OType_PP;
  19.     GPIO_InitStructure.GPIO_PuPd    = GPIO_PuPd_UP;
  20.     GPIO_Init(GPIOA,&GPIO_InitStructure);
  21.
  22.
  23.
  24.     USART_InitStructure.USART_BaudRate = 57600;                     // 配置波特率为115200
  25.     USART_InitStructure.USART_StopBits = USART_WordLength_8b;       // 配置数据长度为8
  26.     USART_InitStructure.USART_StopBits = USART_StopBits_1;          //设置停止位
  27.     USART_InitStructure.USART_Parity    = USART_Parity_No;          // 配置奇偶校验为NONE
  28.     USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; // 配置硬件流为NONE
  29.     USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; // 打开Rx接收和Tx发送功能
  30.
  31.     USART_Init(USART1,&USART_InitStructure);                        // 配置
  32.
  33.
  34.     USART_Cmd(USART1,ENABLE);
  35.
  36.     NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;               // 选择中断通道
  37.     NVIC_InitStructure.NVIC_IRQChannelPriority = 2;                 // 抢断优先1
  38.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                 // 使能中断
  39.
  40.     NVIC_Init(&NVIC_InitStructure);
  41.
  42. USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);                  // 打开中断
  43.     USART_ITConfig(USART1, USART_IT_ORE, ENABLE);                  // 打开中断
  44.
  45.
  46. }
在中断中,检测溢出中断并作处理,代码如下所示
  1. void USART1_IRQHandler(void)
  3.     u8 dat;
  4.
  5. if (USART_GetITStatus(USART1, USART_IT_ORE) == SET)
  6.     {
  7.         USART_ClearITPendingBit(USART1,USART_IT_ORE);
  8.         USART_ReceiveData( USART1 );
  9.
  10.     }
  11.     if( USART_GetITStatus(USART1,USART_IT_RXNE) != RESET )              // 等价于if( !RI ) 检查串口数据是否已就位
  12.     {
  13.         USART_ClearITPendingBit(USART1,USART_IT_RXNE);
  14.         dat = USART_ReceiveData( USART1 );
  15.         uart_rec_buf[uart_len++]=dat;
  16.         RX_TIM=UART_INIT_TIM;
  17.
  18.     }
  19.
  20. }
这样就可以解决,串口不断进入中断的问题
Clyde011 发表于 2024-6-16 07:08 | 显示全部楼层
电源电压处于1.6V到5.5V之间
公羊子丹 发表于 2024-6-16 08:01 | 显示全部楼层
电压范围称为工作电源电压
万图 发表于 2024-6-16 09:04 | 显示全部楼层
内部电路工作电圧是通过内部电压调节器调节电源电压得到的
Uriah 发表于 2024-6-16 10:07 | 显示全部楼层
单片机的外部都连接有象电池等电源部分
帛灿灿 发表于 2024-6-16 12:03 | 显示全部楼层
通常选择0.01μF~0.1μF的陶瓷电容作为旁路电容。
Bblythe 发表于 2024-6-16 13:06 | 显示全部楼层
主时钟振荡器主要用作CPU的工作时钟
周半梅 发表于 2024-6-16 15:02 | 显示全部楼层
防止因瞬间大电流引起的电源电压下降
Pulitzer 发表于 2024-6-16 16:05 | 显示全部楼层
要在外部连接一个振荡电路提供时钟信号
童雨竹 发表于 2024-6-16 18:01 | 显示全部楼层
与15号引脚连接的C1称为旁路电容
Wordsworth 发表于 2024-6-16 19:04 | 显示全部楼层
时序电路是按时钟信号(CK)的上升沿(信号从L→H的变化)或下降沿(信号从H→L的变化)同步工作的
c17
40
