- HAL_StatusTypeDef HAL_I2C_Master_Receive_touch(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
- uint32_t tickstart = 0x00U;
- /* Init tickstart for timeout management*/
- tickstart = HAL_GetTick();
- if(hi2c->State == HAL_I2C_STATE_READY)
- /* Wait until BUSY flag is reset */
- // if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BUSY, SET, I2C_TIMEOUT_BUSY_FLAG, tickstart) != HAL_OK)
- // return HAL_BUSY;
- /* Process Locked */
- __HAL_LOCK(hi2c);
- /* Check if the I2C is already enabled */
- if((hi2c->Instance->CR1 & I2C_CR1_PE) != I2C_CR1_PE)
- /* Enable I2C peripheral */
- __HAL_I2C_ENABLE(hi2c);
- /* Disable Pos */
- hi2c->Instance->CR1 &= ~I2C_CR1_POS;
- hi2c->State = HAL_I2C_STATE_BUSY_RX;
- hi2c->Mode = HAL_I2C_MODE_MASTER;
- hi2c->ErrorCode = HAL_I2C_ERROR_NONE;
- /* Prepare transfer parameters */
- hi2c->pBuffPtr = pData;
- hi2c->XferCount = Size;
- hi2c->XferOptions = I2C_NO_OPTION_FRAME;
- hi2c->XferSize = hi2c->XferCount;
- /* Send Slave Address */
- if(I2C_MasterRequestRead(hi2c, DevAddress, Timeout, tickstart) != HAL_OK)
- if(hi2c->ErrorCode == HAL_I2C_ERROR_AF)
- /* Process Unlocked */
- __HAL_UNLOCK(hi2c);
- return HAL_ERROR;
- else
- return HAL_TIMEOUT;
- if(hi2c->XferSize == 0U)
- /* Clear ADDR flag */
- __HAL_I2C_CLEAR_ADDRFLAG(hi2c);
- /* Generate Stop */
- hi2c->Instance->CR1 |= I2C_CR1_STOP;
- else if(hi2c->XferSize == 1U)
- /* Disable Acknowledge */
- hi2c->Instance->CR1 &= ~I2C_CR1_ACK;
- else if(hi2c->XferSize == 2U)
- /* Enable Pos */
- hi2c->Instance->CR1 |= I2C_CR1_POS;
- else
- /* Enable Acknowledge */
- hi2c->Instance->CR1 |= I2C_CR1_ACK;
- while(hi2c->XferSize > 0U)
- if(hi2c->XferSize <= 3U)
- /* One byte */
- if(hi2c->XferSize == 1U)
- /* Wait until RXNE flag is set */
- if(I2C_WaitOnRXNEFlagUntilTimeout(hi2c, Timeout, tickstart) != HAL_OK)
- if(hi2c->ErrorCode == HAL_I2C_ERROR_TIMEOUT)
- else
- return HAL_ERROR;
- /* Read data from DR */
- (*hi2c->pBuffPtr++) = hi2c->Instance->DR;
- hi2c->XferSize--;
- hi2c->XferCount--;
- /* Two bytes */
- /* Wait until BTF flag is set */
- if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_BTF, RESET, Timeout, tickstart) != HAL_OK)
- hi2c->XferSize--;
- hi2c->XferSize--;
- /* 3 Last bytes */
- else
- hi2c->XferSize--;
