- #include "mcc_generated_files/system/system.h"
- #include "oled/oled.h"
- #include "oled/oledpic.h"
- Main application
- int main(void)
- float numberfu=12.5;
- SYSTEM_Initialize();
- // If using interrupts in PIC18 High/Low Priority Mode you need to enable the Global High and Low Interrupts
- // If using interrupts in PIC Mid-Range Compatibility Mode you need to enable the Global Interrupts
- // Use the following macros to:
- // Enable the Global Interrupts
- INTERRUPT_GlobalInterruptEnable();
- // Disable the Global Interrupts
- //INTERRUPT_GlobalInterruptDisable();
- OLED_Init();
- OLED_Allfill();
- OLED_Clear();
- OLED_ShowPic(90,0,122,4,BMP1);
- OLED_ShowHzbig(0,0,0);
- OLED_ShowStr(33,0,"Hello",16);
- HAL_Delay(1000);
- OLED_Clear();
- OLED_ShowFloat(50,0,numberfu,3,16);
- OLED_ShowHanzi(50,2,0);
- OLED_ShowHanzi(34,2,1);
- for(uint32_t number=500;number<600;number++)
- OLED_ShowNum(80,2,number,4,16);
- HAL_Delay(10);
- OLED_ShowChar(4,0,'H',16);
- OLED_ShowChar(4,2,'M',16);
- HAL_Delay(2100);
- while(1)
