- #include <stdio.h>
- #include <stdlib.h>
- // 线性表的顺序存储结构
- #define ListSize 100
- typedef char DataType;
- typedef struct{
- DataType data[ListSize];
- int length;
- }SeqList;
- SeqList mylist;//global value
- //在指定位置插入元素
- void InsertList(SeqList *L,int pos,DataType val)
- int i,q=0;
- if(pos<1 || pos>L->length+1) // 假如顺序表为 1,2,3,4,5,可以插入的位置是1,2,3,4,5,6
- printf("position error\n");
- return;
- if(L->length>=ListSize){ //当length=ListSize时,表示顺序表已满
- printf("overflow\n");
- return;
- for( i=L->length ;i>=pos;i--){ //当i的位置为1——length+1时需要移动length-i+1
- L->data[i]=L->data[i-1];
- q++;
- L->data[pos-1]=val;
- printf("循环体执行了%d次,理论上计算值为n-i+1次%d\n",q,L->length-pos+1);
- L->length ++;
- printf("在顺序表中插入新的元素%c在表中%d的位置",val,pos);
- DataType DeleteList(SeqList *L,int pos)//在顺序表L中第i个位置之前插入一个新的元素下
- int i,q=0;
- DataType x;
- if(pos<1 || pos>L->length)
- exit (0); //程序非正常退出,并给一个统一的返回值0,在stdlib.h中有定义
- x=L->data[pos-1];
- /* for(i=pos-1;i+1<L->length ;i++){
- q++;
- L->data[i]=L->data[i+1];
- for(i=pos;i<L->length;i++) {
- q++;
- L->data[i-1]=L->data[i];
- L->length --;
- printf("表中位置%d的元素%c已经被删除了\n",pos,x);
- printf("循环体执行了%d次,理论上计算值为n-i次%d\n",q,L->length+1-pos);
- return x;
- void PrintList(SeqList *L) //打印输出顺序表
- int i;
- for(i=0;i<L->length;i++){
- printf("%c,",L->data[i]);
- printf("\n");
- //创建一个顺序表
- CreateList(SeqList *L)
- int i=0;
- L->length=0;
- char ch;
- ch=getchar();
- printf("创建的顺序表如下:");
- while(ch!='\n'){
- L->data[i]=ch;
- L->length++;
- ch=getchar();
- i++;
- printf("表长length=n=%d\n",L->length);
- //顺序表逆置
- void Converts(SeqList *L){
- int i;
- DataType temp;
- for(i=0;i<L->length/2;i++)
- temp=L->data[i];
- L->data[i]=L->data[L->length-1-i];
- L->data[L->length-1-i]=temp;
- return;
- void MaxMin(SeqList *L,DataType*max,DataType *min,int *k,int *j){
- int i;
- *max=L->data[0];*min=L->data[0];
- *k=*j=0;
- for(i=1;i<L->length;i++) {
- if(L->data[i]>*max){
- *max=L->data[i];*k=i;
- else if (L->data[i]<*min){
- *min=L->data[i];*j=i;
- int main()
- int max=0,min=0,k=0,j=0;
- CreateList(&mylist);
- InsertList(&mylist,9,'A');
- PrintList(&mylist);
- DeleteList(&mylist,9);
- Converts(&mylist);
- MaxMin(&mylist,&max,&min,&k,&j);
- printf("max=%c,min=%c,k=%d,j=%d",max,min,k,j);
- return 0;
