- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * [url=home.php?mod=space&uid=247401]@brief[/url] Demonstrate how to use HIRC as ADC clock source to achieve 1411 ksps ADC conversion rate.
- * SPDX-License-Identifier: Apache-2.0
- * [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2020 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NuMicro.h"
- /* Define global variables and constants */
- volatile uint32_t g_u32AdcIntFlag;
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable HIRC clock (Internal RC 48 MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Wait for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Select HCLK clock source as HIRC and HCLK source divider as 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Switch UART0 clock source to HIRC */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
- /* Enable ADC module clock */
- CLK_EnableModuleClock(ADC_MODULE);
- /* ADC clock source is HCLK = PCLK1 = 48MHz, set divider to 2, ADC clock is 48/2 MHz */
- CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL2_ADCSEL_PCLK1, CLK_CLKDIV0_ADC(2));
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set GPB multi-function pins for UART0 RXD and TXD */
- SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
- SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
- /* Set PB.0 ~ PB.3 to input mode */
- GPIO_SetMode(PB, BIT0|BIT1|BIT2|BIT3, GPIO_MODE_INPUT);
- /* Configure the GPB0 - GPB3 ADC analog input pins. */
- SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB0MFP_Msk | SYS_GPB_MFPL_PB1MFP_Msk |
- SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk);
- SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB0MFP_ADC0_CH0 | SYS_GPB_MFPL_PB1MFP_ADC0_CH1 |
- SYS_GPB_MFPL_PB2MFP_ADC0_CH2 | SYS_GPB_MFPL_PB3MFP_ADC0_CH3);
- /* Disable the GPB0 - GPB3 digital input path to avoid the leakage current. */
- GPIO_DISABLE_DIGITAL_PATH(PB, BIT0|BIT1|BIT2|BIT3);
- /* Lock protected registers */
- SYS_LockReg();
- void ADC_FunctionTest()
- uint32_t u32ChannelCount;
- int32_t i32ConversionData;
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| ADC 1411 ksps continuous scan mode sample code |\n");
- printf("+----------------------------------------------------------------------+\n\n");
- printf("| ADC clock source -> PCLK1 = 48 MHz |\n");
- printf("| ADC clock divider = 2 |\n");
- printf("| ADC clock = 48 MHz / 2 = 24 MHz |\n");
- printf("| ADC extended sampling time = 0 |\n");
- printf("| ADC conversion time = 17 + ADC extended sampling time = 17 |\n");
- printf("| ADC conversion rate = 24 MHz / 17 = 1411 ksps |\n");
- /* Enable ADC converter */
- ADC_POWER_ON(ADC);
- while(1)
- printf(" Press any key to start the continuous scan mode test\n");
- getchar();
- /* Set the ADC operation mode as continuous scan, input mode as single-end and
- enable the analog input channel 0, 1, 2 and 3 */
- ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, BIT0|BIT1|BIT2|BIT3);
- /* Clear the A/D interrupt flag for safe */
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
- /* Enable the sample module interrupt */
- ADC_ENABLE_INT(ADC, ADC_ADF_INT); // Enable sample module A/D interrupt.
- NVIC_EnableIRQ(ADC_IRQn);
- /* Reset the ADC interrupt indicator and trigger sample module 0 to start A/D conversion */
- g_u32AdcIntFlag = 0;
- ADC_START_CONV(ADC);
- /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function) */
- while(g_u32AdcIntFlag == 0);
- /* Get the conversion result */
- for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
- i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
- printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
- printf("\n");
- /* Stop A/D conversion */
- ADC_STOP_CONV(ADC);
- /* Disable the sample module interrupt */
- ADC_DISABLE_INT(ADC, ADC_ADF_INT);
- void ADC_IRQHandler(void)
- g_u32AdcIntFlag = 1;
- ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT); /* Clear the A/D interrupt flag */
- /* Init UART0 */
- void UART0_Init(void)
- /* Reset UART0 */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 baud rate */
- UART_Open(UART0, 115200);
- int32_t main(void)
- /* Init System, IP clock and multi-function I/O. */
- SYS_Init();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\nSystem clock rate: %d Hz", SystemCoreClock);
- /* ADC function test */
- ADC_FunctionTest();
- /* Disable ADC IP clock */
- CLK_DisableModuleClock(ADC_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(ADC_IRQn);
- printf("Exit ADC sample code\n");
- while(1);
