SPI Disadvantages
Requires more pins on IC packages than PC, even in the three-wire variant
No in-band addressing; out-of-band chip select signals are required on shared buses
No hardware flow control by the slave
No hardware slave acknowledgment
Typically supports only one master device
No error-checking protocol is defined
Only handles short distances compared to RS-232, RS-485, or Can-bus
Many existing variations
