[技术讨论] 数字电源 C2000 替代
2073|3
 楼主| 微信15323794243 发表于 2024-5-22 16:46 | 显示全部楼层 |阅读模式
Outline Specifications
•Built-in Arm® Cortex ® -M7 core
•12-bit A/D converter
Single- and double-precision FPUs
  Minimum conversion time 0.5μs (2.0Msps)
•Clock frequency: 160 MHz
  3 units, 32 channels
•Internal memory
•Variable Gain Amplifier (VGA)
Instruction Flash ROM: 512 KB
  5 units
Flash ROM for data: 64 KB
•Comparator: 5 units
Instruction RAM: 64 KB
  Window/2 level/1 levell switchable
RAM for data: 64 KB
•Functional Safety
•DMA controller: 2 units / 16 channels
  ROM/RAM ECC function
•Timer
  Memory data protection function
General-purpose 16-bit timer: 20 channels
  Register access protect function
PWM for power control: 12 units / 24 channels
  Clock monitor function
(including high-resolution output [208 ps] 9 units/18 channels)
  Window type WDT function
Matrix converter control PWM: 1 unit / 18 channels
  CRC operation function
•Communication
  A/D converter Diagnostic function
  Synchronous/IIC: 1 channel
  Supply voltage detection function
  Synchronous/UART: 2 channels
  Power-on reset function
  Synchronous/UART/LIN: 1 channel
•Power supply voltage: 5V single power supply
  Synchronous/UART/SPI: 3 channels
•Operating temperature: Tc= -40 to 110°C
  Synchronous/UART/data share: 1 channel
  SM-Bus: 1 channel
  CAN-FD: 2 channels
@coco7890 :比TI的便宜20%,加我微,名字上面号码就是  发表于 2024-6-6 09:20
@QX18963773746 :价位在多少呀?  发表于 2024-6-5 12:48
QX320F280049,国产C2000  发表于 2024-6-4 10:17
