[国产单片机] 合泰单片机驱动MAX7219
2472|0
 楼主| 比神乐 发表于 2024-5-27 15:03 | 显示全部楼层 |阅读模式
  1. #include "HT66F0185.h"
  2. #define uint8 unsigned char
  3. #define uint16 unsigned int
  4. #define CLK_0 _pd1=0
  5. #define CLK_1  _pd1=1
  6. #define LOAD_0 _pd0=0
  7. #define LOAD_1   _pd0=1
  8. #define DIN_0 _pa1=0
  9. #define DIN_1 _pa1=1
  10. #define NoOp 0x00  //??2ù×÷??'??÷
  11. #define Digit0 0x01 // êy??1ü1??'??÷
  12. #define Digit1 0x02 // êy??1ü2??'??÷
  13. #define Digit2 0x03 // êy??1ü3??'??÷
  14. #define Digit3 0x04 // êy??1ü4??'??÷
  15. #define Digit4 0x05 // êy??1ü5??'??÷
  16. #define Digit5 0x06 // êy??1ü6??'??÷
  17. #define Digit6 0x07 // êy??1ü7??'??÷
  18. #define Digit7 0x08 // êy??1ü8??'??÷
  19. #define DecodeMode 0x09  // ò?????ê???'??÷
  20. #define Intensity 0x0a // áá?è??'??÷
  21. #define ScanLimit 0x0b // é¨?è??êy??'??÷
  22. #define ShutDown 0x0c // μí1|o???ê???'??÷
  23. #define DisplayTest 0x0f // ??ê?2aê???'??÷
  24. #define ShutdownMode 0x00 // μí1|o?·?ê?
  25. #define NormalOperation 0x01 // ?y3?2ù×÷·?ê?
  26. #define ScanDigit 0x07 // é¨?è??êyéè??????ê?8??êy??1ü
  27. #define DecodeDigit 0xff // ò???éè????8???ù?aBCD??
  28. #define IntensityGrade 0x0a // áá?è??±eéè??
  29. #define TestMode 0x01 // ??ê?2aê???ê?
  30. #define TextEnd 0x00  // ??ê?2aê??áê??????'?y3?1¤×÷??ê?
  31. /*****************************************************************************
  32. * Function implementation - global ('extern') and local ('static')
  33. ******************************************************************************/
  34. uint8 DisBuffer[8]={0,0,0,0,0,0,0,0}; // ??ê??o'???
  35. //******************?óê±toá??**************************************
  36. void delay(uint16 t)
  37. {
  38. uint16 i;
  39. while(t--)
  40. {
  41. /* ??óú12Mê±?ó?????óê±1ms */
  42. for (i=0;i<36;i++)
  43. {}
  44. }
  45. }
  46. //*************?òMAX7219D'è?×??ú?¨8????********************
  47. void SendChar (uint8 ch)
  48. {
  49. uint8 i,temp;
  50. delay(1);
  51. for (i=0;i<8;i++)
  52. {
  53. temp=ch&0x80;
  54. ch=ch<<1;
  55. if(temp)
  56. {
  57. DIN_1;
  58. delay(1);
  59. CLK_0;
  60. delay(1);
  61. CLK_1;
  62. delay(1);
  63. }
  64. else
  65. {
  66. DIN_0;
  67. delay(1);
  68. CLK_0;
  69. delay(1);
  70. CLK_1;
  71. delay(1);
  72. }
  73. }
  74. }
  75. //**************?òMAX7219D'è?×??¨16????*****************************
  76. void WriteWord (uint8 addr,uint8 num)
  77. {
  78. LOAD_0;
  79. delay(1);
  80. SendChar(addr);
  81. delay(1);
  82. SendChar(num);
  83. delay(1);
  84. LOAD_1; // ??'????àó|??'??÷
  85. }
  86. //*********************** MAX72193?ê??¯ ******************
  87. void InitDisplay (void)
  88. {
  89. WriteWord (ScanLimit,ScanDigit);// éè??é¨?è???T
  90. WriteWord (DecodeMode,DecodeDigit);// éè??ò?????ê?
  91. WriteWord (Intensity,IntensityGrade); // éè??áá?è
  92. WriteWord (ShutDown,NormalOperation); // éè???a?y3?1¤×÷??ê?
  93. }
  94. void delay_ms(uint16 ms)
  95. {
  96.                 //1ms
  97.                 GCC_DELAY(2000);
  98. }
  99. void main()
  100. {
  101.         _wdtc=0xa8;
  102.         _pdc=0;
  103.         _pac=0;
  104.         InitDisplay (); // MAX7219???
  105. WriteWord(DisplayTest,TestMode);// ??????,????LED
  106. delay(1500); // ???1.5s
  107. WriteWord (DisplayTest,TextEnd);// ????????
  108. WriteWord (Digit0,0);
  109. WriteWord (Digit1,1);
  110. WriteWord (Digit2,2);
  111. WriteWord (Digit3,3);
  112.         while(1)
  113.         {
  114.
  115.                 WriteWord(DisplayTest,TestMode);// ??????,????LED
  116. delay(150); // ???1.5s
  117. WriteWord (DisplayTest,TextEnd);// ????????
  118. WriteWord (Digit0,0);
  119. WriteWord (Digit1,1);
  120. WriteWord (Digit2,2);
  121. WriteWord (Digit3,3);
  122.         }
  123. }
效果图
不知道怎么回事,仿真调试可以,去掉仿真器,给板子通电就不行了。
