- #ifndef __LCD_INIT_H
- #define __LCD_INIT_H
- #include "lcd.h"
- #include "g32a1xxx_pins.h"
- #define USE_HORIZONTAL 1 //设置横屏或者竖屏显示 0或1为竖屏 2或3为横屏
- #if USE_HORIZONTAL==0||USE_HORIZONTAL==1
- #define LCD_W 128
- #define LCD_H 160
- #else
- #define LCD_W 160
- #define LCD_H 128
- #endif
- #define BOARD_LCD_MOSI_GPIO GPIOD
- #define BOARD_LCD_PORT_MOSI_BASE PMD
- #define BOARD_LCD_GPIO_MOSI_PIN (5U)
- #define BOARD_LCD_SCLK_GPIO GPIOD
- #define BOARD_LCD_PORT_SCLK_BASE PMD
- #define BOARD_LCD_GPIO_SCLK_PIN (1U)
- #define BOARD_LCD_CS_GPIO GPIOD
- #define BOARD_LCD_PORT_CS_BASE PMD
- #define BOARD_LCD_GPIO_CS_PIN (2U)
- #define BOARD_LCD_DC_GPIO GPIOD
- #define BOARD_LCD_PORT_DC_BASE PMD
- #define BOARD_LCD_GPIO_DC_PIN (3U)
- #define BOARD_LCD_RES_GPIO GPIOD
- #define BOARD_LCD_PORT_RES_BASE PMD
- #define BOARD_LCD_GPIO_RES_PIN (8U)
- #define BOARD_LCD_BLK_GPIO GPIOD
- #define BOARD_LCD_PORT_BLK_BASE PMD
- #define BOARD_LCD_GPIO_BLK_PIN (9U)
- //-----------------LCD端口定义----------------
- #define LCD_SCLK_Clr() PINS_WritePin(BOARD_LCD_SCLK_GPIO,BOARD_LCD_GPIO_SCLK_PIN,0)//SCL SCLK
- #define LCD_SCLK_Set() PINS_WritePin(BOARD_LCD_SCLK_GPIO,BOARD_LCD_GPIO_SCLK_PIN,1)
- #define LCD_CS_Clr() PINS_WritePin(BOARD_LCD_CS_GPIO,BOARD_LCD_GPIO_CS_PIN,0)//CS
- #define LCD_CS_Set() PINS_WritePin(BOARD_LCD_CS_GPIO,BOARD_LCD_GPIO_CS_PIN,1)
- #define LCD_MOSI_Clr() PINS_WritePin(BOARD_LCD_MOSI_GPIO,BOARD_LCD_GPIO_MOSI_PIN,0)//SDA MOSI
- #define LCD_MOSI_Set() PINS_WritePin(BOARD_LCD_MOSI_GPIO,BOARD_LCD_GPIO_MOSI_PIN,1)
- #define LCD_DC_Clr() PINS_WritePin(BOARD_LCD_DC_GPIO,BOARD_LCD_GPIO_DC_PIN,0)//DC
- #define LCD_DC_Set() PINS_WritePin(BOARD_LCD_DC_GPIO,BOARD_LCD_GPIO_DC_PIN,1)
- #define LCD_RES_Clr() PINS_WritePin(BOARD_LCD_RES_GPIO,BOARD_LCD_GPIO_RES_PIN,0)//RES
- #define LCD_RES_Set() PINS_WritePin(BOARD_LCD_RES_GPIO,BOARD_LCD_GPIO_RES_PIN,1)
- #define LCD_BLK_Clr() PINS_WritePin(BOARD_LCD_BLK_GPIO,BOARD_LCD_GPIO_BLK_PIN,0)//BLK
- #define LCD_BLK_Set() PINS_WritePin(BOARD_LCD_BLK_GPIO,BOARD_LCD_GPIO_BLK_PIN,1)
- void LCD_GPIO_Init(void);//初始化GPIO
- void LCD_Writ_Bus(uint8_t dat);//模拟SPI时序
- void LCD_WR_DATA8(uint8_t dat);//写入一个字节
- void LCD_WR_DATA(uint16_t dat);//写入两个字节
- void LCD_WR_REG(uint8_t dat);//写入一个指令
- void LCD_Address_Set(uint16_t x1,uint16_t y1,uint16_t x2,uint16_t y2);//设置坐标函数
- void LCD_Init(void);//LCD初始化
- #endif
lcd_init.c
- #include "lcd_init.h"
- #include "board.h"
- #include "g32a1xxx_clock.h"
- #include "osif.h"
- 函数说明:LCD串行数据写入函数
- 入口数据:dat 要写入的串行数据
- 返回值: 无
- void LCD_Writ_Bus(u8 dat)
- u8 i;
- LCD_CS_Clr();
- for(i=0;i<8;i++)
- LCD_SCLK_Clr();
- if(dat&0x80)
- LCD_MOSI_Set();
- else
- LCD_MOSI_Clr();
- LCD_SCLK_Set();
- dat<<=1;
- LCD_CS_Set();
- 函数说明:LCD写入数据
- 入口数据:dat 写入的数据
- 返回值: 无
- void LCD_WR_DATA8(u8 dat)
- LCD_Writ_Bus(dat);
- 函数说明:LCD写入数据
- 入口数据:dat 写入的数据
- 返回值: 无
- void LCD_WR_DATA(u16 dat)
- LCD_Writ_Bus(dat>>8);
- 函数说明:LCD写入命令
- 入口数据:dat 写入的命令
- 返回值: 无
- void LCD_WR_REG(u8 dat)
- LCD_DC_Clr();//写命令
- LCD_DC_Set();//写数据
- 函数说明:设置起始和结束地址
- 入口数据:x1,x2 设置列的起始和结束地址
- y1,y2 设置行的起始和结束地址
- 返回值: 无
- void LCD_Address_Set(u16 x1,u16 y1,u16 x2,u16 y2)
- if(USE_HORIZONTAL==0)
- LCD_WR_REG(0x2a);//列地址设置
- LCD_WR_DATA(x1+2);
- LCD_WR_DATA(x2+2);
- LCD_WR_REG(0x2b);//行地址设置
- LCD_WR_DATA(y1+1);
- LCD_WR_DATA(y2+1);
- LCD_WR_REG(0x2c);//储存器写
- else if(USE_HORIZONTAL==1)
- else if(USE_HORIZONTAL==2)
- LCD_WR_DATA(x1+1);
- LCD_WR_DATA(x2+1);
- LCD_WR_DATA(y1+2);
- LCD_WR_DATA(y2+2);
- else
- /* Enable Clock to Port D */
- CLOCK_SYS_ConfigModuleClock(PMD_CLK, NULL);
- PINS_SetMuxModeSel(BOARD_LCD_PORT_MOSI_BASE, BOARD_LCD_GPIO_MOSI_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(BOARD_LCD_PORT_SCLK_BASE, BOARD_LCD_GPIO_SCLK_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(BOARD_LCD_PORT_CS_BASE, BOARD_LCD_GPIO_CS_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(BOARD_LCD_PORT_DC_BASE, BOARD_LCD_GPIO_DC_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(BOARD_LCD_PORT_RES_BASE, BOARD_LCD_GPIO_RES_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(BOARD_LCD_PORT_BLK_BASE, BOARD_LCD_GPIO_BLK_PIN, PM_MUX_AS_GPIO);
- PINS_SetPinIntSel(BOARD_LCD_PORT_MOSI_BASE, BOARD_LCD_GPIO_MOSI_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(BOARD_LCD_PORT_SCLK_BASE, BOARD_LCD_GPIO_SCLK_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(BOARD_LCD_PORT_CS_BASE, BOARD_LCD_GPIO_CS_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(BOARD_LCD_PORT_DC_BASE, BOARD_LCD_GPIO_DC_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(BOARD_LCD_PORT_RES_BASE, BOARD_LCD_GPIO_RES_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(BOARD_LCD_PORT_BLK_BASE, BOARD_LCD_GPIO_BLK_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPins(BOARD_LCD_MOSI_GPIO, 1U << BOARD_LCD_GPIO_MOSI_PIN);
- PINS_SetPins(BOARD_LCD_SCLK_GPIO, 1U << BOARD_LCD_GPIO_SCLK_PIN);
- PINS_SetPins(BOARD_LCD_CS_GPIO, 1U << BOARD_LCD_GPIO_CS_PIN);
- PINS_SetPins(BOARD_LCD_DC_GPIO, 1U << BOARD_LCD_GPIO_DC_PIN);
- PINS_SetPins(BOARD_LCD_RES_GPIO, 1U << BOARD_LCD_GPIO_RES_PIN);
- PINS_SetPins(BOARD_LCD_BLK_GPIO, 1U << BOARD_LCD_GPIO_BLK_PIN);
- PINS_SetPinDir(BOARD_LCD_MOSI_GPIO, BOARD_LCD_GPIO_MOSI_PIN, 1U);
- PINS_SetPinDir(BOARD_LCD_SCLK_GPIO, BOARD_LCD_GPIO_SCLK_PIN, 1U);
- PINS_SetPinDir(BOARD_LCD_CS_GPIO, BOARD_LCD_GPIO_CS_PIN, 1U);
- PINS_SetPinDir(BOARD_LCD_DC_GPIO, BOARD_LCD_GPIO_DC_PIN, 1U);
- PINS_SetPinDir(BOARD_LCD_RES_GPIO, BOARD_LCD_GPIO_RES_PIN, 1U);
- PINS_SetPinDir(BOARD_LCD_BLK_GPIO, BOARD_LCD_GPIO_BLK_PIN, 1U);
- LCD_RES_Clr();//复位
- OSIF_TimeDelay(10);
- LCD_RES_Set();
- LCD_BLK_Set();//打开背光
- OSIF_TimeDelay(120);
- LCD_WR_REG(0x11); //Sleep out
- LCD_WR_REG(0xB1);
- LCD_WR_DATA8(0x05);
- LCD_WR_DATA8(0x3C);
- LCD_WR_REG(0xB2);
- LCD_WR_REG(0xB3);
- LCD_WR_REG(0xB4);
- LCD_WR_DATA8(0x03);
- LCD_WR_REG(0xC0);
- LCD_WR_DATA8(0x28);
- LCD_WR_DATA8(0x08);
- LCD_WR_DATA8(0x04);
- LCD_WR_REG(0xC1);
- LCD_WR_DATA8(0XC0);
- LCD_WR_REG(0xC2);
- LCD_WR_DATA8(0x0D);
- LCD_WR_DATA8(0x00);
- LCD_WR_REG(0xC3);
- LCD_WR_DATA8(0x8D);
- LCD_WR_DATA8(0x2A);
- LCD_WR_REG(0xC4);
- LCD_WR_DATA8(0xEE);
- LCD_WR_REG(0xC5);
- LCD_WR_DATA8(0x1A);
- LCD_WR_REG(0x36); //MX, MY, RGB mode
- if(USE_HORIZONTAL==0)LCD_WR_DATA8(0x00);
- else if(USE_HORIZONTAL==1)LCD_WR_DATA8(0xC0);
- else if(USE_HORIZONTAL==2)LCD_WR_DATA8(0x70);
- else LCD_WR_DATA8(0xA0);
- LCD_WR_REG(0xE0);
- LCD_WR_DATA8(0x22);
- LCD_WR_DATA8(0x07);
- LCD_WR_DATA8(0x0A);
- LCD_WR_DATA8(0x2E);
- LCD_WR_DATA8(0x30);
- LCD_WR_DATA8(0x25);
- LCD_WR_DATA8(0x26);
- LCD_WR_DATA8(0x3A);
- LCD_WR_DATA8(0x01);
- LCD_WR_DATA8(0x13);
- LCD_WR_REG(0xE1);
- LCD_WR_DATA8(0x16);
- LCD_WR_DATA8(0x06);
- LCD_WR_DATA8(0x2D);
- LCD_WR_DATA8(0x23);
- LCD_WR_DATA8(0x27);
- LCD_WR_DATA8(0x3B);
- LCD_WR_REG(0x3A); //65k mode
- LCD_WR_REG(0x29); //Display on
main.c
- #include "user_config.h"
- #include <stdio.h>
- #include "osif.h"
- #include "lcd.h"
- #include "pic.h"
- typedef struct
- unsigned char Index[2];
- unsigned char Msk[32];
- }typFNT_GB16;
- extern const typFNT_GB16 tfont16[];
- #define LED_GPIO GPIOD
- #define BLUE_LED_PIN (0U)
- #define RED_LED_PIN (15U)
- #define GREEN_LED_PIN (16U)
- #define WHITE_LED_PIN (~0x00018001)
- * [url=home.php?mod=space&uid=247401]@brief[/url] Pins module initialization LED light
- void PINS_Led_Init()
- /* Set pin mode */
- PINS_SetMuxModeSel(LED_RED_PORT_BASE, LED_RED_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(LED_GREEN_PORT_BASE, LED_GREEN_PIN, PM_MUX_AS_GPIO);
- PINS_SetMuxModeSel(LED_BLUE_PORT_BASE, LED_BLUE_PIN, PM_MUX_AS_GPIO);
- /* Set pin interrupt */
- PINS_SetPinIntSel(LED_RED_PORT_BASE, LED_RED_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(LED_GREEN_PORT_BASE, LED_GREEN_PIN, PM_DMA_INT_DISABLED);
- PINS_SetPinIntSel(LED_BLUE_PORT_BASE, LED_BLUE_PIN, PM_DMA_INT_DISABLED);
- /* GPIO Initialization */
- PINS_SetPins(LED_RED_GPIO_BASE, 1U << LED_RED_PIN);
- PINS_SetPins(LED_GREEN_GPIO_BASE, 1U << LED_GREEN_PIN);
- PINS_SetPins(LED_BLUE_GPIO_BASE, 1U << LED_BLUE_PIN);
- /* Set pin as output */
- PINS_SetPinDir(LED_RED_GPIO_BASE, LED_RED_PIN, 1U);
- PINS_SetPinDir(LED_GREEN_GPIO_BASE, LED_GREEN_PIN, 1U);
- PINS_SetPinDir(LED_BLUE_GPIO_BASE, LED_BLUE_PIN, 1U);
- void Display_title(void)
- LCD_Fill(0,0,LCD_W,LCD_H,LIGHTBLUE);
- LCD_ShowIntNum(8,10,2025,4,BLUE,GREEN,16);
- LCD_ShowChinese(40,10,&tfont16[0],BLUE,GREEN,16,0);
- LCD_ShowChinese(56,10,&tfont16[1],BLUE,GREEN,16,0);
- LCD_ShowChinese(72,10,&tfont16[2],BLUE,GREEN,16,0);
- LCD_ShowChinese(88,10,&tfont16[3],BLUE,GREEN,16,0);
- LCD_ShowChinese(104,10,&tfont16[4],BLUE,GREEN,16,0);
- LCD_ShowChinese(8,30,&tfont16[5],BLUE,GREEN,16,0);
- LCD_ShowChinese(24,30,&tfont16[6],BLUE,GREEN,16,0);
- LCD_ShowChinese(40,30,&tfont16[7],BLUE,GREEN,16,0);
- LCD_ShowChinese(56,30,&tfont16[8],BLUE,GREEN,16,0);
- LCD_ShowString(72,30,"A1465",RED,GREEN,16,0);
- LCD_ShowChinese(8,50,&tfont16[9],BLUE,GREEN,16,0);
- LCD_ShowChinese(24,50,&tfont16[10],BLUE,GREEN,16,0);
- LCD_ShowChinese(40,50,&tfont16[11],BLUE,GREEN,16,0);
- LCD_ShowChinese(56,50,&tfont16[12],BLUE,GREEN,16,0);
- LCD_ShowChinese(72,50,&tfont16[13],BLUE,GREEN,16,0);
- LCD_ShowChinese(88,50,&tfont16[14],BLUE,GREEN,16,0);
- LCD_ShowChinese(104,50,&tfont16[15],BLUE,GREEN,16,0);
- LCD_ShowString(43,140,"2025-01-05",BLUE,GREEN,16,0);
- OSIF_TimeDelay(500);
- * [url=home.php?mod=space&uid=247401]@brief[/url] Main function
- int main(void)
- /* Initialize clock */
- CLOCK_SYS_Init(&g_clockConfig);
- /* led init */
- PINS_Led_Init();
- /* uart init */
- COM_Init();
- /* Initialize LCD */
- LCD_Init();
- OSIF_TimeDelay(200U);
- LCD_Fill(0,0,LCD_W,LCD_H,YELLOW);
- OSIF_TimeDelay(200);
- LCD_Fill(0,0,LCD_W,LCD_H,WHITE);
- PINS_WritePins(LED_GPIO,WHITE_LED_PIN);
- while (1)
- PINS_ClrPins(LED_RED_GPIO_BASE, 1U << LED_RED_PIN);
- PINS_ClrPins(LED_GREEN_GPIO_BASE, 1U << LED_GREEN_PIN);
- PINS_ClrPins(LED_BLUE_GPIO_BASE, 1U << LED_BLUE_PIN);
- LCD_ShowPicture(0,0,128,160,gImage_1);
- OSIF_TimeDelay(800);
- Display_title();
五、画图效果
画图采用“Img2Lcd”工具,轻松实现由图片转C代码的处理,至于中文字符的生成,可借助“PCtoLCD2002”工具,如见以下附件,具体使用方法这里不再赘述。
Image2Lcd 2.9.zip
(506.51 KB, 下载次数: 2)
PCtoLCD2002.zip
(886.17 KB, 下载次数: 2)
使用工具导入图片后设置如下,导出则是C数组,直接调用则行。
屏上画出来的效果如下:
驱动程序点屏效果展现如下:
点屏.zip
(1.16 MB, 下载次数: 2)
