ZCC5090EA:(repleaces CS5090EA) ,5V升压充电管理芯片
438|0
 楼主| HPT-Lt 发表于 2025-4-24 17:11 | 显示全部楼层 |阅读模式
ZCC5090EA是一款专为双节锂电池串联应用设计的升压充电管理IC,具有显著的特性。这款芯片的输入电压为5V,能够提供最大1.5A的充电电流,满足快速充电的需求。ZCC5090EA集成功率MOS,采用异步开关架构,使其在应用时仅需极少的外围器件,有效减少整体方案尺寸,降低BOM成本。其升压开关充电转换器的工作频率为500KHz,转换效率为90%。此外,ZCC5090EA内置四个环路来控制充电过程,分别为恒流(CC)环路、恒压(CV)环路、芯片温度调节环路、可智能调节充电电流,防止拉垮适配器输出,并匹配所有适配器的输入自适应环路。ZCC5090EA集成30V OVP功能,输入端口能够稳定可靠承受30V以内的耐压冲击,并在输入超过6V时停止充电,非常适用于TYPE-C接口的应用。同时芯片BAT输出端口耐压30V,极大提高了系统的可靠性。ZCC5090EA提供了纤小的ESOP8L封装类型供客户选择,其额定的工作温度范围为-40℃至85℃。
The ZCC5090EA is a boost charging management IC specifically designed for the series application of dual-cell lithium batteries, featuring notable characteristics. This chip has an input voltage of 5V and can provide a maximum charging current of 1.5A, meeting the needs for fast charging. The ZCC5090EA integrates power MOS and uses an asynchronous switch architecture, which requires very few peripheral components when applied, effectively reducing the overall solution size and lowering BOM costs. Its boost switch charging converter operates at a frequency of 500KHz with a conversion efficiency of 90%. Additionally, the ZCC5090EA has four built-in loops to control the charging process, namely the constant current (CC) loop, constant voltage (CV) loop, chip temperature regulation loop, and an intelligent charging current adjustment loop that prevents overloading the adapter output and matches the input of all adapters with an adaptive loop. The ZCC5090EA integrates a 30V OVP function, and its input port can stably and reliably withstand voltage surges up to 30V, stopping charging when the input exceeds 6V, making it particularly suitable for applications with TYPE-C interfaces. At the same time, the chip's BAT output port can withstand 30V, greatly enhancing the system's reliability. The ZCC5090EA offers a compact ESOP8L package type for customer selection, with a rated operating temperature range of -40℃ to 85℃.
