[MM32生态] MM32G0001使用USART1发送数据
6982|0
 楼主| Zuocidian 发表于 2025-8-1 09:41 | 显示全部楼层 |阅读模式
查询MM32G0001规格书,可以复用PA12与PA3作为USART1的TX/RX引脚
需要注意,配置引脚后得使用引脚复用函数GPIO_PinAFConfig设置相应的复用功能
void USART1_Init(void)
    //相关GPIO与USART1时钟使能
    RCC_APB1PeriphClockCmd(RCC_APB1ENR_USART1 , ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBENR_GPIOA, ENABLE);
    //配置PA12 (TX) 引脚
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        //复用推挽输出
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
        //引脚配置好后得使用引脚复用函数设置复用功能
        //复用AF1(USART_TX)
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource12, GPIO_AF_1);
    //配置PA3 (RX) 引脚
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        //浮空输入
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_FLOATING;
        //复用AF1(USART_RX)
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1);
    //USART参数配置
        USART_InitTypeDef USART_InitStructure;
        //波特率
    USART_InitStructure.USART_BaudRate = 115200;
        //8位数据
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        //1停止位
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
        //无校验位
    USART_InitStructure.USART_Parity = USART_Parity_No;
        //无硬件流控
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        //启用发送/接收
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART1, &USART_InitStructure);
        //使能USART1
    USART_Cmd(USART1, ENABLE);
//包装一下USART1发送函数
void USART1_Send(uint8_t Byte)
        USART_SendData(USART1,Byte);
        while(USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);
//发送数组
void USART1_SendArray(uint8_t *Arrya,uint16_t Length)
        uint16_t i;
        for(i = 0; i < Length;i++)
                USART1_Send(Arrya);
//发送字符串
void USART1_SendString(char *String)
        uint8_t i;
        for(i = 0; String != '\0'; i++)
                USART1_Send(String);
原文链接:https://blog.csdn.net/qq_67421329/article/details/149310594
