[麦麦茶水间] 【每周分享】AD7124采集工作流程
1159|6
liao6 发表于 2025-8-22 09:14 | 显示全部楼层 |阅读模式
@21小跑堂、#申请原创#
本文介绍软件设置工作流程:
一、初始化参数
        初始化采用官方提供的驱动程序,直接调用AD7124_Setup(&g_ad7124dev,ad7124_regs)即可,寄存器配置需要根据自己需求进行相应配置,双通道采集配置参数如下:
ad7124_st_reg ad7124_regs[AD7124_REG_NO] =
    {0x00, 0x00,     1, 2}, /* AD7124_Status */
    {0x01, 0x14C0,   2, 1}, /* AD7124_ADC_Control 全功率模式,连续转换0x04C0 ADC_CONTROL的DOUT_RDY_DEL位置1*/
    {0x02, 0x0000,   4, 2}, /* AD7124_Data */
    {0x03, 0x0000,   3, 1}, /* AD7124_IOCon1 */
    {0x04, 0x0000,   2, 1}, /* AD7124_IOCon2 */
    {0x05, 0x02,     1, 2}, /* AD7124_ID */
    {0x06, 0x0000,   3, 2}, /* AD7124_Error */
    {0x07, 0x0044,   3, 1}, /* AD7124_Error_En *///进行CRC校验
    {0x08, 0x00,     1, 2}, /* AD7124_Mclk_Count */
    {0x09, 0x8011,   2, 1}, // 读取通道0 8011
    {0x0A, 0x0001,   2, 1}, /* AD7124_Channel_1  读取通道2 8031*/
    {0x0B, 0x0001,   2, 1}, /* AD7124_Channel_2 */
    {0x0C, 0x0001,   2, 1}, /* AD7124_Channel_3 */
    {0x0D, 0x0001,   2, 1}, /* AD7124_Channel_4 */
    {0x0E, 0x0001,   2, 1}, /* AD7124_Channel_5 */
    {0x0F, 0x0001,   2, 1}, /* AD7124_Channel_6 */
    {0x10, 0x0001,   2, 1}, /* AD7124_Channel_7 */
    {0x11, 0x0001,   2, 1}, /* AD7124_Channel_8 */
    {0x12, 0x0001,   2, 1}, /* AD7124_Channel_9 */
    {0x13, 0x0001,   2, 1}, /* AD7124_Channel_10 */
    {0x14, 0x0001,   2, 1}, /* AD7124_Channel_11 */
    {0x15, 0x0001,   2, 1}, /* AD7124_Channel_12 */
    {0x16, 0x0001,   2, 1}, /* AD7124_Channel_13 */
    {0x17, 0x0001,   2, 1}, /* AD7124_Channel_14 */
    {0x18, 0x0001,   2, 1}, /* AD7124_Channel_15 */
    {0x19, 0x01E0,   2, 1}, /* AD7124_Config_0 *///PGA  1  0x01E0
    {0x1A, 0x0000,   2, 1}, /* AD7124_Config_1 */
    {0x1B, 0x0000,   2, 1}, /* AD7124_Config_2 */
    {0x1C, 0x0000,   2, 1}, /* AD7124_Config_3 */
    {0x1D, 0x0000,   2, 1}, /* AD7124_Config_4 */
    {0x1E, 0x0000,   2, 1}, /* AD7124_Config_5 */
    {0x1F, 0x0000,   2, 1}, /* AD7124_Config_6 */
    {0x20, 0x0000,   2, 1}, /* AD7124_Config_7 */
    //滤波和采样速度
    {0x21, 0x010001, 3, 1},  //0x010001
    {0x22, 0x000000, 3, 1}, /* AD7124_Filter_1 */
    {0x23, 0x000000, 3, 1}, /* AD7124_Filter_2 */
    {0x24, 0x000000, 3, 1}, /* AD7124_Filter _3 */
    {0x25, 0x000000, 3, 1}, /* AD7124_Filter_4 */
    {0x26, 0x000000, 3, 1}, /* AD7124_Filter_5 */
    {0x27, 0x000000, 3, 1}, /* AD7124_Filter_6 */
    {0x28, 0x000000, 3, 1}, /* AD7124_Filter_7 */
    {0x29, 0x800000, 3, 1}, /* AD7124_Offset_0 */
    {0x2A, 0x800000, 3, 1}, /* AD7124_Offset_1 */
    {0x2B, 0x800000, 3, 1}, /* AD7124_Offset_2 */
    {0x2C, 0x800000, 3, 1}, /* AD7124_Offset_3 */
    {0x2D, 0x800000, 3, 1}, /* AD7124_Offset_4 */
    {0x2E, 0x800000, 3, 1}, /* AD7124_Offset_5 */
    {0x2F, 0x800000, 3, 1}, /* AD7124_Offset_6 */
    {0x30, 0x800000, 3, 1}, /* AD7124_Offset_7 */
    {0x31, 0x500000, 3, 1}, /* AD7124_Gain_0 */
    {0x32, 0x500000, 3, 1}, /* AD7124_Gain_1 */
    {0x33, 0x500000, 3, 1}, /* AD7124_Gain_2 */
    {0x34, 0x500000, 3, 1}, /* AD7124_Gain_3 */
    {0x35, 0x500000, 3, 1}, /* AD7124_Gain_4 */
    {0x36, 0x500000, 3, 1}, /* AD7124_Gain_5 */
    {0x37, 0x500000, 3, 1}, /* AD7124_Gain_6 */
    {0x38, 0x500000, 3, 1}, /* AD7124_Gain_7 */
这是读通道0数据,读通道1数据只需要修改0x09寄存器数据为0x8031(因为AVSS接地线),参数的设置需要详细看手册才能明白。
二、采集数据
        每两个数求平均代码:
unsigned long int GetAdAvrgValue(U32 * pdata,uint8_t num)
    unsigned long int max, min;
    unsigned long int sum;
    uint8_t i;
    min = pdata[0];                                             // 赋值最小值
    max = pdata[0];                                             // 赋值最大值
    sum = pdata[0];                                             // 赋值累加第一个值
    for(i=1; i<num; i++){
        min = (min > pdata)? pdata:min;                        // 记录最大值
        max = (max < pdata)? pdata:max;                        // 记录最小值
        sum += pdata;                                                    // 数据累加
    if(num > 2){
        return (sum - (max + min))/(num-2);                     // 数据放入处理数组中
    else {
        return sum/num;
手动切换通道代码:
ad7124_st_reg ad7124_regs_ch0[1]=
    {0x09, 0x8011,   2, 1}, // 使能读取通道0  /***测试阶段0x8011***/
ad7124_st_reg ad7124_regs_ch1[1]=
    {0x09, 0x8031,   2, 1}, // 使能读取通道1  /***测试阶段0x8031***/
采集数据代码:
void InsertAdcData(void)
    U16 i,j=0;
    U32 data1s_ch0[50];
        U32 data1s_ch1[50];
    AD7124_WriteRegister(&g_ad7124dev, ad7124_regs_ch0[0]);
    if( AD7124_WaitForConvReady(&g_ad7124dev,5) >= 0 )          //采集通道0数据
        AD7124_ReadRegister(&g_ad7124dev, &ad7124_regs[2]);
        stSysDataVar.gu32_ReadAdValue[0][gu8_ReadAdCnt_ch0++] = (ad7124_regs[2].value>>8)&0xFFFFFF;
    AD7124_WriteRegister(&g_ad7124dev, ad7124_regs_ch1[0]);
    if( AD7124_WaitForConvReady(&g_ad7124dev,5) >= 0 )          //采集通道1数据
        stSysDataVar.gu32_ReadAdValue[2][gu8_ReadAdCnt_ch1++] = (ad7124_regs[2].value>>8)&0xFFFFFF;
    if(gu8_ReadAdCnt_ch0>=ADC_VALUE_COLUMN)                     //每次需要采集100个点
        gu8_ReadAdCnt_ch0=0;
                gu8_ReadAdCnt_ch1=0;
        memcpy(stSysDataVar.gu32_ReadAdValue[1],stSysDataVar.gu32_ReadAdValue[0],ADC_VALUE_COLUMN*4);
                memcpy(stSysDataVar.gu32_ReadAdValue[3],stSysDataVar.gu32_ReadAdValue[2],ADC_VALUE_COLUMN*4);
        for(i=0;i<ADC_VALUE_COLUMN;i+=2)
            data1s_ch0[j] = GetAdAvrgValue(stSysDataVar.gu32_ReadAdValue[1]+i,2);
                        data1s_ch1[j] = GetAdAvrgValue(stSysDataVar.gu32_ReadAdValue[3]+i,2);
            j++;
            if(j>=50)
                j=0;
                                memcpy(stSysDataVar.ADC_AllData,data1s_ch0,50*4);
                                memcpy(stSysDataVar.ADC_AllData+50,data1s_ch1,50*4);
注意:采集数据之前需完成初始化配置,不然会出错。
        这里是通过写0x09寄存器数据进行切换通道,每个通道读取的数据放在二维数组中,采集频率是100HZ,每10毫秒采集一个点,每次采集100个点的数据,采集100个点之后把这些临时数据拷贝到其它序号的二维数组中,这里是为了防止采集到的临时数据还没用就被下一次更新,然后把这100个点数据每两个求平均,得出50个点数据,采集频率就是50HZ了,最后求平均之后的数据赋值于一个数组,前边存通道0后边存通道1 数据,封装好之后供其它函数调用。
@21小跑堂 管理员,你好,求原创审核哦!  发表于 2025-9-17 08:42
huangcunxiake 发表于 2025-8-27 09:51 | 显示全部楼层
这是一个ADC芯片吗
 楼主| liao6 发表于 2025-8-27 15:13 | 显示全部楼层
对啊,ADI的片外ADC芯片。
野玫瑰 发表于 2025-9-4 14:24 | 显示全部楼层
AD7124 采集工作流程如下:先初始化参数,调用官方驱动程序 AD7124_Setup,依据需求配置寄存器,如双通道采集参数。接着进行数据采集,模拟信号经输入选择器接入,预处理、转换后,数字信号经数字滤波器处理,最终通过 SPI 或 I2C 接口输出数据。
野玫瑰 发表于 2025-9-4 14:29 | 显示全部楼层
使用 AD7124 驱动程序采集数据步骤:
初始化硬件接口(SPI/I2C),调用 AD7124_Init () 建立通信。
配置寄存器:通过 AD7124_WriteRegister () 设置通道、增益、滤波模式等参数。
启动转换:调用 AD7124_StartConversion () 开启连续 / 单次转换。
读取数据:轮询或中断检测转换完成,用 AD7124_ReadData () 获取结果。
数据处理:根据配置参数将原始值转换为实际物理量。
1101274536 发表于 2025-10-20 16:41 | 显示全部楼层
你的完整代码发给我参考一下把
