- \file system_gd32f1x0.c
- \brief CMSIS Cortex-M3 Device Peripheral Access Layer Source File for
- GD32F1x0 Device Series
- /* Copyright (c) 2012 ARM LIMITED
- All rights reserved.
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions are met:
- - Redistributions of source code must retain the above copyright
- notice, this list of conditions and the following disclaimer.
- - Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in the
- documentation and/or other materials provided with the distribution.
- - Neither the name of ARM nor the names of its contributors may be used
- to endorse or promote products derived from this software without
- specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
- LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- POSSIBILITY OF SUCH DAMAGE.
- /* This file refers the CMSIS standard, some adjustments are made according to GigaDevice chips */
- #include "gd32f1x0.h"
- /* system frequency define */
- #define __IRC8M (IRC8M_VALUE) /* internal 8 MHz RC oscillator frequency */
- #define __HXTAL (HXTAL_VALUE) /* high speed crystal oscillator frequency */
- #define __SYS_OSC_CLK (__IRC8M) /* main oscillator frequency */
- /* select a system clock by uncommenting the following line */
- //#define __SYSTEM_CLOCK_8M_HXTAL (__HXTAL)
- //#define __SYSTEM_CLOCK_8M_IRC8M (__IRC8M)
- //#define __SYSTEM_CLOCK_72M_PLL_HXTAL (uint32_t)(72000000)
- #define __SYSTEM_CLOCK_72M_PLL_IRC8M_DIV2 (uint32_t)(72000000)
- #define SEL_IRC8M 0x00
- #define SEL_HXTAL 0x01
- #define SEL_PLL 0x02
- /* set the system clock frequency and declare the system clock configuration function */
- #ifdef __SYSTEM_CLOCK_8M_HXTAL
- uint32_t SystemCoreClock = __SYSTEM_CLOCK_8M_HXTAL;
- static void system_clock_8m_hxtal(void);
- #elif defined (__SYSTEM_CLOCK_72M_PLL_HXTAL)
- uint32_t SystemCoreClock = __SYSTEM_CLOCK_72M_PLL_HXTAL;
- static void system_clock_72m_hxtal(void);
- #elif defined (__SYSTEM_CLOCK_72M_PLL_IRC8M_DIV2)
- uint32_t SystemCoreClock = __SYSTEM_CLOCK_72M_PLL_IRC8M_DIV2;
- static void system_clock_72m_irc8m(void);
- #else
- uint32_t SystemCoreClock = __SYSTEM_CLOCK_8M_IRC8M;
- static void system_clock_8m_irc8m(void);
- #endif /* __SYSTEM_CLOCK_8M_HXTAL */
- /* configure the system clock */
- static void system_clock_config(void);
- \brief setup the microcontroller system, initialize the system
- \param[in] none
- \param[out] none
- \retval none
- void SystemInit (void)
- /* enable IRC8M */
- RCU_CTL0 |= RCU_CTL0_IRC8MEN;
- while(0U == (RCU_CTL0 & RCU_CTL0_IRC8MSTB)){
- /* reset RCU */
- #ifdef GD32F130_150
- RCU_CFG0 &= ~(RCU_CFG0_SCS | RCU_CFG0_AHBPSC | RCU_CFG0_APB1PSC | RCU_CFG0_APB2PSC |\
- RCU_CFG0_ADCPSC | RCU_CFG0_CKOUTSEL | RCU_CFG0_CKOUTDIV | RCU_CFG0_PLLDV);
- #elif defined (GD32F170_190)
- RCU_CFG0_ADCPSC | RCU_CFG0_CKOUT0SEL | RCU_CFG0_CKOUT0DIV | RCU_CFG0_PLLDV);
- #endif /* GD32F130_150 */
- RCU_CFG0 &= ~(RCU_CFG0_PLLSEL | RCU_CFG0_PLLMF | RCU_CFG0_PLLPREDV);
- RCU_CFG0 &= ~(RCU_CFG0_USBDPSC);
- RCU_CTL0 &= ~(RCU_CTL0_HXTALEN | RCU_CTL0_CKMEN | RCU_CTL0_PLLEN | RCU_CTL0_HXTALBPS);
- RCU_CFG1 &= ~RCU_CFG1_HXTALPREDV;
- RCU_CFG2 &= ~(RCU_CFG2_USART0SEL | RCU_CFG2_CECSEL | RCU_CFG2_ADCSEL);
- RCU_CTL1 &= ~RCU_CTL1_IRC14MEN;
- RCU_CFG2 &= ~RCU_CFG2_IRC28MDIV;
- RCU_CTL1 &= ~RCU_CTL1_IRC28MEN;
- RCU_CFG3 &= ~RCU_CFG3_CKOUT1SEL;
- RCU_CFG3 &= ~RCU_CFG3_CKOUT1DIV;
- RCU_INT = 0x00000000U;
- /* configure system clock */
- system_clock_config();
- \brief configure the system clock
- \param[in] none
- \param[out] none
- \retval none
- system_clock_8m_hxtal();
- system_clock_72m_hxtal();
- system_clock_72m_irc8m();
- #else
- system_clock_8m_irc8m();
- \brief configure the system clock to 8M by HXTAL
- \param[in] none
- \param[out] none
- \retval none
- uint32_t timeout = 0;
- /* enable HXTAL */
- RCU_CTL0 |= RCU_CTL0_HXTALEN;
- /* wait until HXTAL is stable or the startup time is longer than HXTAL_STARTUP_TIMEOUT */
- while((0 == (RCU_CTL0 & RCU_CTL0_HXTALSTB)) && (HXTAL_STARTUP_TIMEOUT != timeout++));
- /* if fail */
- if(0 == (RCU_CTL0 & RCU_CTL0_HXTALSTB))
- return;
- /* HXTAL is stable */
- /* AHB = SYSCLK */
- RCU_CFG0 |= RCU_AHB_CKSYS_DIV1;
- /* APB2 = AHB */
- RCU_CFG0 |= RCU_APB2_CKAHB_DIV1;
- /* APB1 = AHB */
- RCU_CFG0 |= RCU_APB1_CKAHB_DIV1;
- /* select HXTAL as system clock */
- RCU_CFG0 &= ~RCU_CFG0_SCS;
- RCU_CFG0 |= RCU_CKSYSSRC_HXTAL;
- /* wait until HXTAL is selected as system clock */
- while(0 == (RCU_CFG0 & RCU_SCSS_HXTAL));
- \brief configure the system clock to 72M by PLL which selects HXTAL as its clock source
- \param[in] none
- \param[out] none
- \retval none
- uint32_t timeout = 0U;
- uint32_t stab_flag = 0U;
- do{
- timeout++;
- stab_flag = (RCU_CTL0 & RCU_CTL0_HXTALSTB);
- while((0U == stab_flag) && (HXTAL_STARTUP_TIMEOUT != timeout));
- /* if fail */
- if(0U == (RCU_CTL0 & RCU_CTL0_HXTALSTB)){
- return;
- /* APB2 = AHB */
- /* APB1 = AHB */
- /* PLL = HXTAL * 9 = 72 MHz */
- RCU_CFG0 &= ~(RCU_CFG0_PLLSEL | RCU_CFG0_PLLMF | RCU_CFG0_PLLDV);
- RCU_CFG0 |= (RCU_PLLSRC_HXTAL | RCU_PLL_MUL9);
- /* enable PLL */
- RCU_CTL0 |= RCU_CTL0_PLLEN;
- /* wait until PLL is stable */
- while(0U == (RCU_CTL0 & RCU_CTL0_PLLSTB)){
- /* select PLL as system clock */
- RCU_CFG0 |= RCU_CKSYSSRC_PLL;
- /* wait until PLL is selected as system clock */
- while(0U == (RCU_CFG0 & RCU_SCSS_PLL)){
- \brief configure the system clock to 72M by PLL which selects IRC8M/2 as its clock source
- \param[in] none
- \param[out] none
- \retval none
- /* APB2 = AHB */
- /* APB1 = AHB */
- /* PLL = (IRC8M/2) * 18 = 72 MHz */
- RCU_CFG0 &= ~(RCU_CFG0_PLLSEL | RCU_CFG0_PLLMF);
- RCU_CFG0 |= (RCU_PLLSRC_IRC8M_DIV2 | RCU_PLL_MUL12);
- /* enable PLL */
- while(0 == (RCU_CTL0 & RCU_CTL0_PLLSTB));
- while(0 == (RCU_CFG0 & RCU_SCSS_PLL));
- #else
- \brief configure the system clock to 8M by IRC8M
- \param[in] none
- \param[out] none
- \retval none
- /* APB2 = AHB */
- /* APB1 = AHB */
- /* select IRC8M as system clock */
- RCU_CFG0 |= RCU_CKSYSSRC_IRC8M;
- /* wait until IRC8M is selected as system clock */
- while(0 != (RCU_CFG0 & RCU_SCSS_IRC8M));
- \brief update the SystemCoreClock with current core clock retrieved from cpu registers
- \param[in] none
- \param[out] none
- \retval none
- void SystemCoreClockUpdate (void)
- uint32_t sws = 0U;
- uint32_t pllmf = 0U, pllmf4 = 0U, pllsel = 0U, prediv = 0U, idx = 0U, clk_exp = 0U;
- /* exponent of AHB clock divider */
- const uint8_t ahb_exp[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
- sws = GET_BITS(RCU_CFG0, 2, 3);
- switch(sws){
- /* IRC8M is selected as CK_SYS */
- case SEL_IRC8M:
- SystemCoreClock = IRC8M_VALUE;
- break;
- /* HXTAL is selected as CK_SYS */
- // case SEL_HXTAL:
- // SystemCoreClock = HXTAL_VALUE;
- // break;
- /* PLL is selected as CK_SYS */
- case SEL_PLL:
- /* get the value of PLLMF[3:0] */
- pllmf = GET_BITS(RCU_CFG0, 18, 21);
- pllmf4 = GET_BITS(RCU_CFG0, 27, 27);
- /* high 16 bits */
- if(1U == pllmf4){
- pllmf += 17U;
- }else{
- pllmf += 2U;
- /* PLL clock source selection, HXTAL or IRC8M/2 */
- pllsel = GET_BITS(RCU_CFG0, 16, 16);
- if(0U != pllsel){
- prediv = (GET_BITS(RCU_CFG1, 0, 3) + 1U);
- SystemCoreClock = (HXTAL_VALUE / prediv) * pllmf;
- }else{
- SystemCoreClock = (IRC8M_VALUE >> 1) * pllmf;
- break;
- default:
- break;
- /* calculate AHB clock frequency */
- idx = GET_BITS(RCU_CFG0, 4, 7);
- clk_exp = ahb_exp[idx];
- SystemCoreClock >>= clk_exp;
时钟我配置的48MHZ,内部HSI时钟源。
- int main(void)
- //systick_config(); // 初始化Systick为1ms中断
- gpio_config();
- usart_config();
- // timer_capture_config(); // 初始化定时器输入捕获
- // delay_1ms(100);
- LOG_DEBUG("GD32F130G6 Spirometer Ready\r\n");
- LOG_DEBUG("Using TIMER2 capture on PA6 for speed measurement\r\n");
- LOG_DEBUG("Wait for start command (0xA5 0x5A 0x01 0x00)\r\n");
- while (1)
- LOG_DEBUG("L");
- // if(rx_cmd_ready) {
- // LOG_DEBUG("Receive new command\r\n");
- // parse_command();
- // handle_measurement();
- delay_1ms(300);
- LOG_DEBUG("A");
- delay_1ms(300);
- LOG_DEBUG("B");
- delay_1ms(300);
- LOG_DEBUG("C");
- delay_1ms(300);
- LOG_DEBUG("H");
通过串口打印出来的消息可以发现一直在重启
