我觉得你分析的对。我记得用atmega162时,在手册里看到过一句“During periods of low VCC, the EEPROM data can be corrupted because the supply voltage is too low for the CPU and the EEPROM to operate properly. These issues are the same as for board level systems using EEPROM, and the same design solutions should be applied”所以你应该弄个大电容单独为78L05提供电能,再弄个二极管,阻止其他同源电路消耗里面的电荷;我觉得你的掉电信息写入过程很长的话,应该用电池。
