100KHZ 以上的 LCR 电桥要如何实现呢?
2783|2
 楼主| PSIR 发表于 2012-10-25 17:12 | 显示全部楼层 |阅读模式
以下的截图出自 HP 的阻抗量测手册 2-7 页。
上图是一般手持式的 LCR 表改采用的自动平衡电挢结构,量测频率最高到 100KHZ,网路上流传的 DIY LCR 电挢都是此种原理。
下图是量测频率 100KHZ 以上的结构图,相信桌上型的 LCR 电挢是这样做,所以电路看起来才会那么庞大。
不知道上图的自动平衡为何频率限制在 100KHZ 以下?我在实做时也发现这样的情形,只要一高过 100KHZ 量测结果就不准。
下图看起来是加了很多校正电路,到底高频率的 LCR 电挢为什么那么难做?也很难找到参考资料,大家可以讨论一下吗?谢谢。
AD797 发表于 2012-10-25 22:24 | 显示全部楼层
HP手册上讲的很清楚啊
This circuit configurationcannot be used at frequencies higher than 100 kHz because of the performance limits of the operational amplifier.
 楼主| PSIR 发表于 2012-10-26 17:08 | 显示全部楼层
大家好,手册上这一段说明 100 kHz 结构的原理,一直看不懂他在说什么,
能否帮我研究看看,**有点长,小弟在此谢过。
Low frequency instruments, below 100 kHz, employ a simple operational amplifier to configure the
null detector and the equivalent of OSC2 as shown in Figure 2-5 (b). This circuit configuration
amplifier. The instruments that cover frequencies above 100 kHz have an auto balancing
bridge circuit consisting of a null detector, 0°/90° phase detectors, and a vector modulator as shown
in Figure 2-5 (c). When an unbalance current is detected with the null detector, the phase detectors
in the next stage separate the current into 0° and 90° vector components. The phase detector output
signals go through loop filters (integrators) and are applied to the vector modulator to drive the
0°/90° component signals. The 0°/90° component signals are compounded and the resultant
signal is fed back through range resistor (Rr) to cancel the current flowing through the DUT. Even if
the balancing control loop has phase errors, the unbalance current component, due to the phase
errors, is also detected and fed back to cancel the error in the range resistor current. Consequently,
the unbalance current converges to exactly zero, ensuring Ix = Ir over a broad frequency range up to
110 MHz.
