我现在已经比较清楚如何建立TCP连接,发送TCP数据了,但是现在我想,如果PA0由高电平变化到低电平,那么单片机就向电脑不停地发送十六进制1,这段代码怎么加在程序里面呢?下面贴出我原来的代码,这段代码原本是用于TELNET上面,但是我只要有TCP数据就可以了。-
- #include "ziji.h"
- #include "stm3210c_eval_lcd.h"
- #include "lwip/tcp.h"
- #include <string.h>
- #include <stdio.h>
- #define GREETING "欢迎进入8001端口\n\r\n\r"
- extern const uint8_t STM32F10x_STR[];
- #define HELLO "回答:"
- #define MAX_NAME_SIZE 32
- int length;
- char bytes[MAX_NAME_SIZE];
- static err_t ziji_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err);
- static err_t ziji_accept(void *arg, struct tcp_pcb *pcb, err_t err);
- static void ziji_conn_err(void *arg, err_t err);
- struct pbuf *q;
- struct name *name = (struct name *)arg;
- int done;
- char *c;
- int i;
- if (p != NULL)
- tcp_recved(pcb, p->tot_len);
- if(!name)
- pbuf_free(p);
- return ERR_ARG;
- done = 0;
- for(q=p; q != NULL; q = q->next)
- c = q->payload;
- for(i=0; i<q->len && !done; i++)
- done = ((c == '\r') || (c == '\n'));
- if(name->length < MAX_NAME_SIZE)
- name->bytes[name->length++] = c;
- if(done)
- if(name->bytes[name->length-2] != '\r' || name->bytes[name->length-1] != '\n')
- if((name->bytes[name->length-1] == '\r' || name->bytes[name->length-1] == '\n') && (name->length+1 <= MAX_NAME_SIZE))
- name->length += 1;
- else if(name->length+2 <= MAX_NAME_SIZE)
- name->length += 2;
- else
- name->length = MAX_NAME_SIZE;
- name->bytes[name->length-2] = '\r';
- name->bytes[name->length-1] = '\n';
- tcp_write(pcb, HELLO, strlen(HELLO), 1);
- tcp_write(pcb, name->bytes, name->length, TCP_WRITE_FLAG_COPY);
- tcp_write(pcb, "\n\r", strlen("\n\r"), 1);
- name->length = 0;
- pbuf_free(p);
- else if (err == ERR_OK)
- mem_free(name);
- return tcp_close(pcb);
- return ERR_OK;
- u32_t IPaddress;
- u8_t iptxt[50];
- volatile u8_t iptab[4];
- IPaddress = pcb->remote_ip.addr;
- iptab[0] = (u8_t)(IPaddress >> 24);
- iptab[1] = (u8_t)(IPaddress >> 16);
- iptab[2] = (u8_t)(IPaddress >> 8);
- iptab[3] = (u8_t)(IPaddress);
- LCD_DisplayStringLine(Line5, iptxt);
- tcp_arg(pcb, mem_calloc(sizeof(struct name), 1));
- tcp_err(pcb, ziji_conn_err);
- tcp_recv(pcb, ziji_recv);
- tcp_write(pcb, GREETING, strlen(GREETING), 1);
- return ERR_OK;
- void ziji_init(void)
- struct tcp_pcb *pcb;
- pcb = tcp_new();
- tcp_bind(pcb, IP_ADDR_ANY, 8001);
- pcb = tcp_listen(pcb);
- tcp_accept(pcb, ziji_accept);
- struct name *name;
- name = (struct name *)arg;
- mem_free(name);
请教大家,到底怎么修改呢?
