STM32F105R8+TJA1050 CAN接口调试不通
8692|17
 楼主| dingyi21 发表于 2012-12-5 18:48 | 显示全部楼层 |阅读模式
我最近在用STM32F105和TJA1050调试CAN通讯我都整了一天不知道是什么原因,一下是我的硬件电路图和和CAN程序配置:
void CAN_Config(void)
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_DeInit(CAN2);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN1 cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
  CAN_InitStructure.CAN_Prescaler = 4;
  CAN_Init(CAN1, &CAN_InitStructure);
  CAN_Init(CAN2, &CAN_InitStructure);
  /* CAN1 filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 0;                                   //
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* CAN2 filter init */
  CAN_FilterInitStructure.CAN_FilterNumber = 14;                               //
  /* Transmit */
  TxMessage.StdId = 0x321;
  TxMessage.ExtId = 0x01;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 1;
  CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE);
  CAN_ITConfig(CAN2,CAN_IT_FMP0, ENABLE);
中断函数如下:
void CAN1_RX0_IRQHandler(void)
  CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
  if ((RxMessage.StdId == 0x321)&&(RxMessage.IDE == CAN_ID_STD)&&(RxMessage.DLC == 1)&&(RxMessage.Data[0] == 0xAA))
      USRAT_Send_String("----------YES-------CAN1\n", 24, 1);
        USRAT_Send_String(&RxMessage.Data[0], 1, 1);
  else
        USRAT_Send_String("ON1",4, 1);
  CAN_ClearITPendingBit(CAN1,  CAN_IT_EPV);
void CAN2_RX0_IRQHandler(void)
  CAN_Receive(CAN2, CAN_FIFO0, &RxMessage);
  if ((RxMessage.StdId == 0x321)&&(RxMessage.IDE == CAN_ID_STD)&&(RxMessage.DLC == 1)&&(RxMessage.Data[0] == 0x55))
         USRAT_Send_String("----------YES-------CAN2\n", 26, 1);
  else
     USRAT_Send_String("ON", 3, 1);
CAN_ClearITPendingBit(CAN2,  CAN_IT_EPV);
主函数调用如下:
TxMessage.Data[0] = 0xAA;
               CAN_Transmit(CAN2, &TxMessage);
                delayms(100);
                  TxMessage.Data[0] = 0x55;
               CAN_Transmit(CAN1, &TxMessage);
 楼主| dingyi21 发表于 2012-12-5 18:49 | 显示全部楼层
硬件图如:
airwill 发表于 2012-12-5 19:23 | 显示全部楼层
硬件应该没有什么问题
没有看到 IO 口的初始化, can 的时钟初始化.
建议借助仿真器帮助, 来调试
硬件应该没有什么问题
建议借助仿真器帮助, 来调试
硬件应该没有什么问题
建议借助仿真器帮助, 来调试
IJK 发表于 2012-12-5 22:13 | 显示全部楼层
建议先参考ST的CAN例子。
另外LZ的问题是什么?  发送有问题,还是接收有问题?
 楼主| dingyi21 发表于 2012-12-6 08:28 | 显示全部楼层
我的IO和时钟初始化如:
  /* CAN1 and CAN2 Periph clocks enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1 | RCC_APB1Periph_CAN2, ENABLE);
        /* Configure CAN1 RX pin */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        /* Configure CAN2 RX pin */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* Configure CAN1 TX pin */
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        /* Configure CAN2 TX pin */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
我看了F107的例程但是没看书来由啥问题。  还请各位仁兄帮忙呀!
 楼主| dingyi21 发表于 2012-12-6 09:48 | 显示全部楼层
我知道是怎么回事了,结果是硬件有问题。  现在CAN1和CAN2收发都可以了。
zhg340122 发表于 2012-12-6 11:31 | 显示全部楼层
这样配置RX管脚看看!
jiaxinhui 发表于 2012-12-6 20:37 | 显示全部楼层
楼主可以参考下,我发过的一个关于STM32 CAN 通讯的例程,接口芯片用的也是TJA1050
https://bbs.21ic.com/icview-348466-1-1.html
 楼主| dingyi21 发表于 2012-12-8 17:15 | 显示全部楼层
多谢了。
liqixiao 发表于 2013-3-5 13:21 | 显示全部楼层
可否告知一下是什么硬件问题,我现在也遇到问题了
wangzhiai8 发表于 2013-5-18 12:29 | 显示全部楼层
请问你这个问题解决了吗?我现在也是这样的问题,头大死了。
amd1217 发表于 2013-5-31 15:08 | 显示全部楼层
终端电阻120没接。。
飞言走笔 发表于 2013-7-2 13:52 | 显示全部楼层
能说下是什么硬件问题吗?如何解决的?谢谢了~~
因为我也遇到了这方面的问题
 楼主| dingyi21 发表于 2013-7-6 09:10 | 显示全部楼层
硬件问题是在CAN总线上不应接那两个保护二极管,应该是在总线之间接120R的电阻的。
hkcj 发表于 2013-7-6 16:17 | 显示全部楼层
问题解决了吗   楼主   先排查一下是否是硬件的问题    之后再查一查   底层驱动  是否有哪里设置的问题
jhc8711 发表于 2014-10-31 14:12 | 显示全部楼层
硬件问题是在CAN总线上不应接那两个保护二极管,应该是在总线之间接120R的电阻的。 ...
你这两个管子大小选错了吧
