程序很简单,就是先初始化GPIO,然后模式设置,结果程序就卡在while(I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));一直不出来。麻烦大家帮我分析一下!
#include <stm32f4xx.h>
static void IIC1_GPIO_Configuration(void)
//打开B口的时钟,PB6->SCL,PB7->SDA
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
//先将对应寄存器配置为缺省值
GPIO_StructInit(&GPIO_InitStructure);
//选中6,7管脚
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6|GPIO_Pin_7;
//复用功能
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;
//IIC最大速度为400K
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
//开漏输出
GPIO_InitStructure.GPIO_OType=GPIO_OType_OD;
//不带上拉
GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_NOPULL;
//将IO配置应用于对应寄存器
GPIO_Init(GPIOB,&GPIO_InitStructure);
//管脚映射
GPIO_PinAFConfig(GPIOB,GPIO_Pin_6,GPIO_AF_I2C1);
GPIO_PinAFConfig(GPIOB,GPIO_Pin_7,GPIO_AF_I2C1);
static void IIC1_MODE_Configuration(void)
I2C_InitTypeDef I2C_InitStrycture;
//打开IIC1时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
//典型IIC速度为100K
I2C_InitStrycture.I2C_ClockSpeed=100000;
//IIC模式
I2C_InitStrycture.I2C_Mode=I2C_Mode_I2C;
I2C_InitStrycture.I2C_DutyCycle=I2C_DutyCycle_2;
//在STM32作为从机时的应答地址,做主机时不需理会
I2C_InitStrycture.I2C_OwnAddress1=0x00;
//使能IIC应答
I2C_InitStrycture.I2C_Ack=I2C_Ack_Enable;
//应答地址为7位(从机)
I2C_InitStrycture.I2C_AcknowledgedAddress=I2C_AcknowledgedAddress_7bit;
//使能IIC
I2C_Cmd(I2C1,ENABLE);
//配置寄存器
I2C_Init(I2C1,&I2C_InitStrycture);
//允许一字节一应答的时序
I2C_AcknowledgeConfig(I2C1, ENABLE);
void IIC1_Init(void)
IIC1_GPIO_Configuration();
IIC1_MODE_Configuration();
主程序很简单(串口程序就不贴出来了)
USART1_Init();
IIC1_Init();
printf("\r\n 开始测试 \n\r");
printf("写入数据\n\r");
就这么简短的几句话,卡在那里了。配置检查了很久都没有看出问题来! |
