#define KEY0_PORT PORTD
#define KEY0_DDR DDRD
#define KEY0_PIN PIND
#define KEY0 PD0
#define KEY1_PORT PORTD
#define KEY1_DDR DDRD
#define KEY1_PIN PIND
#define KEY1 PD1
#define KEY2_PORT PORTD
#define KEY2_DDR DDRD
#define KEY2_PIN PIND
#define KEY2 PD2
#define KEY3_PORT PORTD
#define KEY3_DDR DDRD
#define KEY3_PIN PIND
#define KEY3 PD3
#define KEY0_STATUS (BIT_STATUS(KEY0_PIN,KEY0))
#define KEY1_STATUS (BIT_STATUS(KEY1_PIN,KEY1))
#define KEY2_STATUS (BIT_STATUS(KEY2_PIN,KEY2))
#define KEY3_STATUS (BIT_STATUS(KEY3_PIN,KEY3))
#define KEY_SERIES_FLAG 200 //按键连发开始所需时间长度
#define KEY_SERIES_DELAY 5 //按键连发的时间间隔长度
//按键属性
#define KEY_DOWN 0xA0
#define KEY_LONG 0xB0
#define KEY_LIAN 0xC0
#define KEY_UP 0xD0
#define KEY_UP 0xD0
#define NO_KEY 0x00
#define KEY0_DOWN 0X01
#define KEY1_DOWN 0X02
#define KEY2_DOWN 0X03
#define KEY3_DOWN 0X04
#define KEY0_PRESS (KEY_DOWN|KEY0_DOWN)
#define KEY1_PRESS (KEY_DOWN|KEY1_DOWN)
#define KEY2_PRESS (KEY_DOWN|KEY2_DOWN)
#define KEY3_PRESS (KEY_DOWN|KEY3_DOWN)
key.c文件一部分
static uchar Get_Key(void)
if (KEY0_STATUS==0) return KEY0_DOWN;
if (KEY1_STATUS==0) return KEY1_DOWN;
if (KEY2_STATUS==0) return KEY2_DOWN;
if (KEY3_STATUS==0) return KEY3_DOWN;
return NO_KEY;
uchar Key_Scan(void)
static uchar Key_State = 0; //按键状态
static uchar Key_Prev = 0; //上一次按键
static uchar Key_Delay = 0; //按键连发时间
static uchar Key_Series = FALSE; //标志连发开始
uchar Key_Press = NO_KEY; //按键值
uchar Key_Return = NO_KEY; //按键返回值
Key_Press = Get_Key();
switch (Key_State)
case 0://按键初始态00
if (Key_Press !=NO_KEY)//有按键按下
Key_State = 1;//转到按键确认
Key_Prev = Key_Press;//保存按键状态
break;
case 1://按键确认态01
if ( Key_Press ==Key_Prev )//确认和上次按键相同
Key_State = 2;//判断按键长按
//返回按键按下键值,按键按下就响应,如果想弹起来再响应
//可以在弹起来后再返回按键值
Key_Return = KEY_DOWN | Key_Prev;
else//按键抬起,是抖动,不响应按键
Key_State = 0;
break;
case 2://按键释放态10
if (Key_Press == NO_KEY )//按键释放了
Key_State = 0;
Key_Delay = 0;
Key_Series = FALSE;
Key_Return = KEY_UP | Key_Prev; //返回按键抬起值
break;
Key_Delay++;
if ((Key_Series==TRUE) && (Key_Delay>KEY_SERIES_DELAY))
Key_Delay = 0;
Key_Return = KEY_LIAN | Key_Press; //返回连发的值
Key_Prev = Key_Press; //记住上次的按键.
break;
if (Key_Delay>KEY_SERIES_FLAG)
Key_Series = TRUE;
Key_Delay = 0;
Key_Return = KEY_LONG | Key_Prev; //返回长按后的值
break;
default :
break;
return Key_Return;
每10ms调用一次按键检测,根据Key_Return的值来判断按键的操作,用状态机省去传统按键的延时去抖,也不在在按键的死等待,对程序时间的利用有很大的帮助,根据按键返回的状态值,事件可以在按键按下响应,也可以在按键弹起来响应,也可以实现连发、长按等功能。
