急问有没有单片机里面有三个比较器?
3150|5
 楼主| yangxiaona 发表于 2008-4-9 09:42 | 显示全部楼层 |阅读模式
最好体积小一点,小于20个引脚
农民讲习所 发表于 2008-4-9 09:50 | 显示全部楼层
AVR
使用AD多路开关,可9路比较器输入。比较器+可使用内部基准,也可使用PWM产生DA做比较基准。
jetson001 发表于 2008-4-9 09:54 | 显示全部楼层
Microchip的PIC
PartPIC18F1230PIC18F1330
ManufacturerMicrochipMicrochip
P.Memory (Kbytes)4 flash8 flash
P.Memory (KWords)24
Self-Write FlashYesYes
RAM (Bytes)   EEPROM (Bytes)256
128
256
128
I/O Pins1616
Max CPU Speed   Internal OSC40MHz, (10MIPS)
8 MHz, 32 kHz
40MHz, (10MIPS)
8 MHz, 32 kHz
CodeGuard?Security
System Mgmt FeaturesWDT, nanoWatt-[Low Speed, Fast Wake, Active Ctrl]BOR, WDT, nanoWatt-[Low Speed, Fast Wake, Active Ctrl]
Analog Peripherals3-Comparators; 1A/D, 4x10-bit @ 100ksps3-Comparators; 1A/D, 4x10-bit @ 100ksps
Digital Comm. Peripherals1-A/E/USART1-A/E/USART
ConnectivityLINLIN
Capture/Compare PWM
Digital Timers2x16-bit2x16-bit
Application Peripherals6-MtrCtrl. PWM6-MtrCtrl. PWM
Debug/DevelopmentICSP, Integrated ICDdebugICSP, Integrated ICDdebug
Operating Voltage  Temperature Range(癈)(2V-5.5V)
(-40 to +125)
(2V-5.5V)
(-40 to +125)
Packages (Pins)PDIP, QFN, SOIC, SSOP (18)PDIP, QFN, SOIC, SSOP (18)
Other FeaturesMotor Control PWM
3 analog comparators
8 MHz internal oscillator
LIN USART; High Perf. 8-Bit;
Motor Control PWM
8 MHz Inernal Oscillator
dztb 发表于 2008-4-9 10:25 | 显示全部楼层
CY的PSOC
CY的PSOC我好像也见过有,PIC的不错
 楼主| yangxiaona 发表于 2008-4-9 12:31 | 显示全部楼层
请问若要是用avr的话,有哪几种型号的呢?
