看看如何读写此东东
2051|0
 楼主| Gem654321 发表于 2008-11-1 10:57 | 显示全部楼层 |阅读模式
自己有一个东东,有9个引脚,用了7个,每个引脚功能描述如下
1:N_Boot_link ,Enables field programming of internal processor
   5V wrt DGND, active low signal ,0V when in use.
2: + link_Ser_out,RS422 Signal,+5V,0V
3: - link_Ser_out,RS422 Signal,+5V,0V
4: +link_Ser_In ,RS422 Signal,+5V,0V
5: -link_Ser_In ,RS422 Signal,+5V,0V
6: N_Wdogdis ,Stops Watchdog from timing out during field programming of the internal    processor,5V wrt DGND,active Low signal,0V when in use
7: Link_Reset,Reset processor, 0V,active high signal ,5V wrt DGND when in use
我现在想用一个合适的读写电路和软件,对这个东东内部的程序进行读写,在此求助各位高手支招。谢谢
