sim900 GPS模块 使用问题,现象:不稳定
4616|7
 楼主| hzjk 发表于 2013-1-17 20:47 | 显示全部楼层 |阅读模式
各位兄弟,我公司现在用 sim900  GPS模块 开发一款产品,主要是发彩信(同时向某个特定的邮箱以及手机发送),彩信内容是图片,图片大小 在50k byte
目前的问题是产品不够稳定,主要表现在: AT+CMMSSEND 这个命令上。
正常情况下,mcu 向 sim900 发送 AT+CMMSSEND 这个命令后 等待大约一分钟 sim900 就会有一个ok 的响应;
但是 有时(大约10%的几率),始终没有ok 的响应,同时也没有任何的响应。
sim 卡我用的是移动的,信号质量我也查过,基本上都大于20.
所以感觉很奇怪,为什么会失败,请指教!
如果没有响应,我会等10分钟,然后会再发一次,基本上再发一次还是会出现同样的现象
 楼主| hzjk 发表于 2013-1-17 20:59 | 显示全部楼层
Passed GSM init
Cam reset in 38400!
Cam reset ok!
Cam set Baud:115200bps
Cam set 320*240 ok!
Cam set compression!
Cam stop photo ok!
Passed Cam init
Passed Timer
Update the tel
This is SIM900_MMS_CAM project!
+CMTI: "SM",1
$AT+CMGF=1
OK
AT+CMGR=1
+CMGR: "REC UNREAD","139********","","12/11/17,17:45:21+32"
62CD7167
OK
AT+CMGF=1
OK
AT+CMGR=1
+CMGR: "REC READ","***********","","12/11/17,17:45:21+32"
62CD7167
OK
Begin take the first photo.$First take a photo.ok,sizes=%d
AT
OK
AT+CMMSINIT
OK
AT+CMMSCURL="mmsc.monternet.com"
OK
AT+CMMSCID=1
OK
AT+CMMSPROTO="10.0.0.172",80
OK
AT+SAPBR=3,1,"Contype","GPRS"
OK
AT+SAPBR=3,1,"APN","CMWAP"
OK
AT+SAPBR=1,1
OK
AT+CMMSEDIT=1
OK
$Begin trans picture.
AT+CMMSDOWN="PIC",9804,5300
CONNECT
9804Cam_ReadPicData!
OK
picture transmit ok.
Stop taking photos.
Take photos again.
AT+CMMSDOWN="PIC",12532,5300
CONNECT
12532Cam_ReadPicData!
OK
Stop taking photos.
Take photos again.
AT+CMMSDOWN="PIC",12836,5300
CONNECT
12836Cam_ReadPicData!
OK
Stop taking photos.
Take photos again.
AT+CMMSDOWN="PIC",12148,5300
CONNECT
12148Cam_ReadPicData!
OK
$AT+CMMSDOWN="TITLE",7,5000
CONNECT
Find the title' CONNECT
OK
pass title ok
AT+CMMSRECP="***********"  // 一个电话,我隐掉了
OK
AT+CMMSSENDCFG=6,3,0,0,2,4
OK
Send!
$AT+CMMSVIEW
+CMMSVIEW: 2,"","139********","","","2000-01-01,00:01:42","4300610074006300680065006400",47496
1,"image0.jpg",7,9804
2,"image1.jpg",7,12532
3,"image2.jpg",7,12836
4,"image3.jpg",7,12148
OK
$$$AT+CMMSSEND
2 lou 是程序打印
 楼主| hzjk 发表于 2013-1-18 15:53 | 显示全部楼层
顶起来
koukou1229 发表于 2013-1-19 15:37 | 显示全部楼层
顶一个!
Richard-wang 发表于 2013-1-22 10:27 | 显示全部楼层
安防监控项目?
 楼主| hzjk 发表于 2013-1-24 14:32 | 显示全部楼层
是的,主要是监视,彩信发送图片。在家测试的时候,都是ok的,在家测试了接近20台,测试了上百次。都是可以的。
HFY2013 发表于 2013-7-3 14:36 | 显示全部楼层
是的,这个问题,我也听很多同行反映过了,但是他们转到GU900D模块上面测试,非常地稳定,而且响应速度很快!我这里有资料,需要请联系:116871232
