| | Part No. | VDD | System Clock | Program Memory | Data Memory | I/O | Timer | Interrupt | I2C | A/D | PWM | PFD | UART | Stack | Package | 8-bit | 16-bit | Ext. | Int. | HT46R22 HT46C22 | 2.2V~ 5.5V | 400kHz~ 8MHz | 2Kx14 | 64x8 | 19 | 1 | -- | 1 | 3 | v | 9-bitx8 | 8-bitx1 | v | -- | 6 | 24SKDIP/SOP | HT46R23 HT46C23 | 2.2V~ 5.5V | 400kHz~ 8MHz | 4Kx15 | 192x8 | 23 | -- | 1 | 1 | 3 | v | 10-bitx8 | 8-bitx2 | v | -- | 8 | 24SKDIP/SOP, 28SKDIP/SOP | HT46R232 HT46C232 | 2.2V~ 5.5V | 400kHz~ 8MHz | 4Kx16 | 192x8 | 40 | -- | 2 | 1 | 4 | v | 10-bitx8 | 8-bitx4 | v | -- | 8 | 28SKDIP/SOP, 48SSOP | 1 | v | HT46R24 HT46C24 | 2.2V~ 5.5V | 400kHz~ 8MHz | 8Kx16 | 384x8 | 40 | -- | 2 | 1 | 4 | v | 10-bitx8 | 8-bitx4 | v | -- | 16 | 28SKDIP/SOP, 48SSOP | HT46RU25 HT46CU25 | 2.2V~ 5.5V | 400kHz~ 8MHz | 16Kx16 | 576x8 | 48 | 1 | 2 | 1 | 5 | v | 12-bitx8 | 8-bitx4 | v | v | 16 | 48/56SSOP | HT46RU26 HT46CU26* | 2.2V~ 5.5V | 400kHz~ 8MHz | 32Kx16 | 768x8 | 48 | 1 | 2 | 1 | 5 | v | 12-bitx8 | 8-bitx4 | v | v | 16 | 48/56SSOP | * Under development, available in 3Q, 2008. Note: Part numbers including "C" are mask version devices while "R" are OTP devices.
Part No. | VDD | System Clock | Program Memory | Data Memory | I/O | 8-bit Timer | Interrupt | A/D | PWM | PFD | Stack | Package | Ext. | Int. | HT46R46-H | 3.3V~ 5.5V | 400kHz~ 8MHz | 1Kx14 | 64x8 | 13 | 1 | 1 | 2 | 8-bitx4ch | 8-bitx1 | v | 4 | 18DIP/SOP | HT46R47-H | 3.3V~ 5.5V | 400kHz~ 8MHz | 2Kx14 | 64x8 | 13 | 1 | 1 | 2 | 9-bitx4ch | 8-bitx1 | v | 6 | 18DIP/SOP | Note: 1. These devices are only available in OTP versions. 2. Operating Temperature -40°C ~ 125°C |
Part No. | VDD | System Clock | Program Memory | Data Memory | I/O | 8-bit Timer | Interrupt | A/D | PWM | PFD | Stack | Package | Ext. | Int. | HT46R51A | 2.2V~ 5.5V | 400kHz~ 8MHz | 1Kx15 | 96x8 | 14 | 1 | 1 | 2 | 12-bitx5 | 8-bitx1 | v | 6 | 16NSOP, 18DIP, 20SOP/SSOP | HT46R52A | 2.2V~ 5.5V | 400kHz~ 8MHz | 2Kx15 | 128x8 | 14 | 1 | 1 | 2 | 12-bitx5 | 8-bitx1 | v | 6 | 16NSOP, 18DIP, 20SOP/SSOP | HT46R53A | 2.2V~ 5.5V | 400kHz~ 8MHz | 2Kx15 | 192x8 | 22 | 1 | 1 | 2 | 12-bitx8 | 8-bitx1 | v | 6 | 28SKDIP/SOP | HT46R54A | 2.2V~ 5.5V | 400kHz~ 8MHz | 4Kx15 | 208x8 | 22 | 1 | 1 | 2 | 12-bitx8 | 8-bitx1 | v | 6 | 28SKDIP/SOP | Note: These devices are only available in OTP versions
| 客户服务 客户服务 问题与建议 问题与建议 Tools维修需求申请 Tools维修需求申请 行事历 行事历 产品培训 产品培训 表单下载 表单下载 订阅新闻 订阅新闻 企业专区 企业专区
| | Part No. | Internal Clock | VDD | System Clock | Program Memory | Data Memory | I/O | 8-bit Timer | Interrupt | A/D | PWM | PFD | Stack | Package | Ext. | Int. | HT46R01-1 HT46R01-2 HT46R01-3 | 4MHz 8MHz 12MHz | 2.2V~ 5.5V | 400kHz~ 12MHz | 1Kx14 | 64x8 | 8 | 1 | 1 | 2 | 8-bitx4 | 8-bitx1 | v | 4 | 10MSOP | HT46R02-1 HT46R02-2 HT46R02-3 | 4MHz 8MHz 12MHz | 2.2V~ 5.5V | 400kHz~ 12MHz | 2Kx14 | 96x8 | 8 | 2 | 1 | 3 | 9-bitx4 | 8-bitx1 | v | 6 | 10MSOP | HT46R03-1 HT46R03-2 HT46R03-3 | 4MHz 8MHz 12MHz | 2.2V~ 5.5V | 400kHz~ 12MHz | 4Kx15 | 160x8 | 8 | 2 | 1 | 3 | 12-bitx4 | 8-bitx1 | v | 8 | 10MSOP | Note: 1.These devices are only available in OTP versions. 2.The internal clock in the table is a fully integrated RC oscillator requiring no external components which can be used as the system clock. 3.The chosen internal clock frequency corresponding to the device marking must be specified at the time of ordering. |
