int mcu_ad_cov_sig(unsigned char ch_num)
unsigned int i;
unsigned int ad_result;
CLK_PCKENR2 = CLK_PCKENR2 | 0X01; //使能外设ADC的时钟,之后对ADC的寄存器操作有效
ADC1_CR1 = 0X01; //开启AD模块电源,使用Sing mode;
ADC1_CR2 = 0X02; //使用MCU系统时钟频率作ADC的时钟;
//AD转换软启动;
//AD采样时间24个系统时钟;
ADC1_SQR1_DMAOFF = 1; //禁止DMA传输;
switch (ch_num)
case 0:{ADC1_SQR4 = 0X02; break;} //测量充放电流值,in1
case 1:{ADC1_SQR4 = 0X10; break;} //测量BAT1,in4
case 2:{ADC1_SQR4 = 0X20; break;} //测量BAT2,in5
case 3:{ADC1_SQR4 = 0X40; break;} //测量BAT3,in6
case 4:{ADC1_SQR3 = 0X04; break;} //测量BAT4,in10
case 5:{ADC1_SQR3 = 0X08; break;} //测量BAT5,in11
case 6:{ADC1_SQR3 = 0X10; break;} //测量BAT6,in12
case 7:{ADC1_SQR3 = 0X20; break;} //测量BAT7,in13
case 8:{ADC1_SQR3 = 0X40; break;} //测量BAT8,in14
case 9:{ADC1_SQR3 = 0X80; break;} //测量BAT9,in15
case 10:{ADC1_SQR2 = 0X01; break;} //测量BAT10,in16
case 11:{ADC1_SQR2 = 0X02; break;} //测量BAT11,in17
case 12:{ADC1_SQR2 = 0X04; break;} //测量BAT12,in18
case 13:{ADC1_SQR2 = 0X08; break;} //测量BAT13,in19
case 14:{ADC1_SQR2 = 0X10; break;} //测量BAT14,in20
case 15:{ADC1_SQR2 = 0X20; break;} //测量BAT15,in21
case 16:{ADC1_SQR2 = 0X40; break;} //测量BAT16,in22
ADC1_CR1_START = 1; //启动AD转换
for(i=0;i<15;i++) //加入固定延时,等待AD转换完成
{asm("nop");}
ad_result = ADC1_DRH << 8 ;
ad_result = ad_result + ADC1_DRL; //读取AD转换值
ADC1_SQR4 = 0x00;
ADC1_SQR3 = 0x00;
ADC1_SQR2 = 0x00; //AD转换完成后,清除AD选中的通道
ADC1_CR1 = 0x00; //关闭AD模块电源
CLK_PCKENR2 = CLK_PCKENR2 & 0xFE; //关闭AD时钟
return ad_result; //返回AD值
void main()
for(i=0;i<count;i++)
ad[i] = mcu_ad_cov_sig(ch_num);
sum = sum + ad[i];
for(j=0;j<25000;j++)
asm("nop");
asm("nop");
在MAIN()函数中,如果我不加25000这个 NOP 延时,8次的采样值只有第一个是正确的,其余7个值都是一致便小,而且值的大小都很接近
难道STM8L的 AD转换需要加这么长的延时么????
望知情人告知如何做???? 谢谢
