stm32f0 spi lcd12864 花屏(真的不行了求助)
7394|8
 楼主| wago2008 发表于 2013-4-24 18:19 | 显示全部楼层 |阅读模式
  1. void Lcd_Init()
  3.         SPI_InitTypeDef  SPI_InitStructure;
  4.         GPIO_InitTypeDef GPIO_InitStructure;
  5.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); //使能GPIOB时钟
  6.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE); //使能GPIOC时钟
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//使能SP1时钟(必须先使能时钟,否则配置无效)
  8.         GPIO_PinAFConfig(GPIOB,GPIO_PinSource3,GPIO_AF_0);
  9.           GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_0);
  10.         //PB3 时钟 PB5 spi 输出
  11.         // 配置SPI1的SCK, MOSI
  12.         GPIO_InitStructure.GPIO_Pin        =GPIO_Pin_3 |GPIO_Pin_5;
  13.         GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF;                //复用功能
  14.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  15.         //GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
  16.         //GPIO_InitStructure.GPIO_PuPd =GPIO_PuPd_UP;
  17.         GPIO_Init(GPIOB,&GPIO_InitStructure);
  18.         //PC10 片选
  19.         GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10 ;
  20.         GPIO_InitStructure.GPIO_Mode =GPIO_Mode_OUT;
  21.         GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  22.         GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
  23.         GPIO_InitStructure.GPIO_PuPd =GPIO_PuPd_NOPULL;
  24.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  25.         //给指定的端口写1
  26.         //GPIO_SetBits(GPIOB,GPIO_Pin_3|GPIO_Pin_5);
  27.         //给指定的端口写1
  28.         //GPIO_SetBits(GPIOC,GPIO_Pin_10);
  29.         SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;                                //一线只发
  30.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                        //设置SPI工作模式:设置为主SPI
  31.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;        //设置SPI的数据大小:SPI发送接收8位帧结构
  32.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                         //选择了串行时钟的稳态:时钟悬空低
  33.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                        //数据捕获于第二个时钟沿
  34.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                                        //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
  35.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;                //定义波特率预分频的值:波特率预分频值为256
  36.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
  37.         SPI_InitStructure.SPI_CRCPolynomial = 7;                                        //CRC值计算的多项式
  38.         //SPI_RxFIFOThresholdConfig(SPI1,SPI_RxFIFOThreshold_QF);//配置 SPI 的 FIFO 接收阈值(接收8bits就置 SPI_I2S_FLAG_RXNE)
  39.         //GPIO_PinAFConfig(GPIOB,GPIO_PinSource3|GPIO_PinSource5,GPIO_AF_0);//连接到外设
  40.         SPI_Init(SPI1, &SPI_InitStructure);                                                         //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
  41.         SPI_Cmd(SPI1, ENABLE);                //使能SPI外设
  42.         //设置LCD
  43.         GPIO_ResetBits(GPIOC,GPIO_Pin_10);
  44.         Delay(5);
  45.             LCD_Send(0x30, DC_CMD);        ///*30---基本指令动作*/
  46.         Delay(1);
  47.             LCD_Send(0x0C, DC_CMD);        ///*开显示,关游标*/
  48.         Delay(1);
  49.             LCD_Send(0x06, DC_CMD);        ///*光标的移动方向*/
  50.         Delay(1);
  51.             LCD_Send(0x80, DC_CMD);        //使用基本命令
  52.         Delay(1);
  53.             LCD_Send(0x01, DC_CMD);        ///*清屏,地址指针指向00H*/
  54.         Delay(1);
  55.         //SPI1_ReadWriteByte(0xff); //启动传输
  56. }
  57. // 向LCD发送数据
  58. void LCD_Send(unsigned char data, DCType dc)
  59. {
  60.         Delay(1);
  61.           //这里一定要加延时
  62.         if (dc==DC_CMD)                                           // 写指令
  63.                 SPI_Send(SERIAL_WCMD);                  // 写入到IR
  64.         else
  65.                    SPI_Send(SERIAL_WDATA );
  66.         SPI_Send(0xf0&data);
  67.         SPI_Send(data<<4);
  68. }
  69. //SPI发送1个数据
  70. void SPI_Send(unsigned char data)
  71. {
  72.          while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  73.          SPI_SendData8(SPI1, data);
  74. }
  75. /*  x:  第几列    y: 第几行 */
  76. void LCD_Set_XY(unsigned char x, unsigned char y)
  77. {
  78.         unsigned char address;
  79.         switch(y){
  80.                 case 0:
  81.                         address = 0x80 + x;
  82.                         break;
  83.                 case 1:
  84.                         address = 0x90 + x;
  85.                         break;
  86.                 case 2:
  87.                         address = 0x88 + x;
  88.                         break;
  89.                 case 3:
  90.                         address = 0x98 + x;
  91.                         break;
  92.                 default:
  93.                         address = 0x80 + x;
  94.                         break;
  95.         }
  96.         LCD_Send(address,DC_CMD);
  97.         return;
  98. }
  99. void LCD_PutString(unsigned char x, unsigned char y, char *str)
  100. {
  101.         LCD_Set_XY(x,y);
  102.         while(*str)
  103.         {
  104.                 LCD_Send(*str++,DC_DATA);
  105.                 Delay(1);
  106.         }
  107.         return;
  108. }
  109. /*--------------清DDRAM------------------*/
  110. void LCD_Clrram (void)
  111. {
  112.   LCD_Send (0x30,DC_CMD);
  113.   Delay(1);
  114.   LCD_Send (0x01,DC_CMD);
  115.   Delay(1);
  116. }
  1. int main(void)
  3. Init_Main();
  4. Lcd_Init();
  5. LCD_Clrram ();
  6.                 Delay(50);
  7.                  LCD_PutString(0,0, "工资涨涨");
  8.                      LCD_PutString(0,1, "工资涨涨");
  9.                      LCD_PutString(0,2, "工资涨涨");
  10.                     Delay(5000);
  11.                 LCD_Clrram ();
  12.                 Delay(50);
  13.                 LCD_Clrram ();
  14.                 Delay(50);
现象:开机第一次不能显示,在随后可以显示文字,随后再一次乱码,这是那里出了问题,请大侠们赐教。
uet_cache 发表于 2013-4-24 19:08 | 显示全部楼层
你的主程序没有大循环?
cjhk 发表于 2013-4-24 19:15 | 显示全部楼层
不是很了解   帮楼主顶一个   希望有高手能帮忙解决一下   顶一个
 楼主| wago2008 发表于 2013-4-25 08:49 | 显示全部楼层
你的主程序没有大循环?
笔误,最后跟个while(1){},我怀疑是时序问题,我再试试,谢谢回复
uet_cache 发表于 2013-4-25 09:02 | 显示全部楼层
你如果要看波形,需要不断操作屏。。不然,一旦不执行屏操作,波形自然就 没 了
 楼主| wago2008 发表于 2013-4-25 09:08 | 显示全部楼层
上个故障图,有没高手一下能看出问题,谢谢各位
12864花屏
12864花屏
 楼主| wago2008 发表于 2013-4-25 17:11 | 显示全部楼层
问题解决了,防不胜防啊,硬件把片选和led控制管脚重复用了,所以出现一会片选一会不片选,开始不显示是因为操作了片选没有给个延时
feng_910 发表于 2013-6-9 10:25 | 显示全部楼层
问题解决了,防不胜防啊,硬件把片选和led控制管脚重复用了,所以出现一会片选一会不片选,开始不显示是因 ...
你好,我的程序也出现了类似的问题,请问你说管脚复用是怎么解决的?谢谢!
 楼主| wago2008 发表于 2013-6-9 16:32 | 显示全部楼层
硬件开发把led和片选脚用的一样了,所以是硬件冲突了,让他重飞线了个管脚,你是AF管脚复用?是不是你用之前没有AF复用配置管脚?
