update pcb
4053|5
 楼主| missdanger 发表于 2007-4-12 22:37 | 显示全部楼层 |阅读模式
&nbsp;&nbsp;在做完原理图以后生成PCB的时候提示节点找不到,可那些节点我都没用到,这是怎么回事啊?<br />&nbsp;&nbsp;具体错误见下:<br />ERRORS:&nbsp;6&nbsp;macros&nbsp;can&nbsp;not&nbsp;be&nbsp;executed:<br />-------------------------------------------------------------------------<br />Macro&nbsp;1:&nbsp;New&nbsp;Node<br />Add&nbsp;node&nbsp;D1-1&nbsp;to&nbsp;net&nbsp;AREFN<br />Error:&nbsp;Node&nbsp;not&nbsp;found<br /><br />Macro&nbsp;2:&nbsp;New&nbsp;Node<br />Add&nbsp;node&nbsp;D2-2&nbsp;to&nbsp;net&nbsp;AREFN<br />Error:&nbsp;Node&nbsp;not&nbsp;found<br /><br />Macro&nbsp;3:&nbsp;New&nbsp;Node<br />Add&nbsp;node&nbsp;-A&nbsp;to&nbsp;net&nbsp;NetR18_1<br />Error:&nbsp;Node&nbsp;not&nbsp;found<br /><br />Macro&nbsp;4:&nbsp;New&nbsp;Node<br />Add&nbsp;node&nbsp;D1-2&nbsp;to&nbsp;net&nbsp;VSS<br />Error:&nbsp;Node&nbsp;not&nbsp;found<br /><br />Macro&nbsp;5:&nbsp;New&nbsp;Node<br />Add&nbsp;node&nbsp;D2-1&nbsp;to&nbsp;net&nbsp;VSS<br />Error:&nbsp;Node&nbsp;not&nbsp;found<br /><br />Macro&nbsp;6:&nbsp;New&nbsp;Node<br />Add&nbsp;node&nbsp;-K&nbsp;to&nbsp;net&nbsp;VSS<br />Error:&nbsp;Node&nbsp;not&nbsp;found
syzdq 发表于 2007-4-13 12:37 | 显示全部楼层
原理图元件和PCB封装库引脚名称不对应。
 楼主| missdanger 发表于 2007-4-13 12:47 | 显示全部楼层
那请问怎么改原理图里的引脚名称啊?
syzdq 发表于 2007-4-13 12:54 | 显示全部楼层
修改库
 楼主| missdanger 发表于 2007-4-13 13:15 | 显示全部楼层
知道了,谢谢啊
baihua0452 发表于 2007-4-13 17:31 | 显示全部楼层
修改原理图库或者PCB库就行了
